1 #ifndef __CS_PARAM_SLES_H__
2 #define __CS_PARAM_SLES_H__
431 const char *system_name);
495 double blr_threshold,
497 bool advanced_optim);
586 #if defined(HAVE_PETSC)
599 cs_param_sles_petsc_cmd(
bool use_prefix,
Definition: cs_defs.h:514
Definition: cs_defs.h:515
cs_param_sles_class_t cs_param_sles_get_class_from_amg(cs_param_amg_type_t amg_type)
Retrieve the related solver class from the amg type.
Definition: cs_param_sles.c:3175
void cs_param_sles_mumps(cs_param_sles_t *slesp, bool is_single, cs_param_sles_facto_type_t facto_type)
Set the main memebers of a cs_param_sles_mumps_t structure. This structure is allocated if needed....
Definition: cs_param_sles.c:2995
cs_param_sles_analysis_algo_t
Type of algorithm to consider when using the MUMPS solver to perform the analysis step (renumbering a...
Definition: cs_param_sles.h:150
@ CS_PARAM_SLES_ANALYSIS_AMD
Definition: cs_param_sles.h:152
@ CS_PARAM_SLES_ANALYSIS_QAMD
Definition: cs_param_sles.h:153
@ CS_PARAM_SLES_N_ANALYSIS_ALGOS
Definition: cs_param_sles.h:162
@ CS_PARAM_SLES_ANALYSIS_PORD
Definition: cs_param_sles.h:154
@ CS_PARAM_SLES_ANALYSIS_SCOTCH
Definition: cs_param_sles.h:155
@ CS_PARAM_SLES_ANALYSIS_PTSCOTCH
Definition: cs_param_sles.h:156
@ CS_PARAM_SLES_ANALYSIS_AUTO
Definition: cs_param_sles.h:160
@ CS_PARAM_SLES_ANALYSIS_PARMETIS
Definition: cs_param_sles.h:158
@ CS_PARAM_SLES_ANALYSIS_METIS
Definition: cs_param_sles.h:157
type of factorization to consider when using the MUMPS solver to solve a linear system
Definition: cs_param_sles.h:103
@ CS_PARAM_SLES_FACTO_LU
LU factorization is the most generic factorization available with MUMPS. It can handle general matric...
Definition: cs_param_sles.h:105
@ CS_PARAM_SLES_FACTO_LDLT_SPD
This factorization is devoted to SPD matrices and corresponds to a Cholesky factorization....
Definition: cs_param_sles.h:107
@ CS_PARAM_SLES_FACTO_LDLT_SYM
This factorization is a Cholesky factorization (L.D.Lt) for general symmetric matrices.
Definition: cs_param_sles.h:106
@ CS_PARAM_SLES_N_FACTO_TYPES
Definition: cs_param_sles.h:109
static bool cs_param_sles_is_mumps_set(cs_param_itsol_type_t solver)
Find if a MUMPS-related solver is set or not.
Definition: cs_param_sles.h:352
void cs_param_sles_check_amg(cs_param_sles_t *slesp)
Check if the setting related to the AMG is consistent with the solver class.
Definition: cs_param_sles.c:3274
cs_param_sles_saddle_t * cs_param_sles_saddle_create(void)
Create a cs_param_sles_saddle_t structure and assign a minimalist default settings.
Definition: cs_param_sles.c:2567
cs_param_sles_class_t cs_param_sles_check_class(cs_param_sles_class_t wanted_class)
Check the availability of a solver library and return the requested one if this is possible or an alt...
Definition: cs_param_sles.c:3206
void cs_param_sles_update_cvg_settings(bool use_field_id, const cs_param_sles_t *slesp)
Update the settings associated to a cs_sles_t structure and apply those defined in the given cs_param...
Definition: cs_param_sles.c:3076
void cs_param_sles_free(cs_param_sles_t **p_slesp)
Free a cs_param_sles_t structure.
Definition: cs_param_sles.c:2747
cs_param_sles_t * cs_param_sles_create(int field_id, const char *system_name)
Create a cs_param_sles_t structure and assign a default settings.
Definition: cs_param_sles.c:2699
int cs_param_sles_set(bool use_field_id, cs_param_sles_t *slesp)
Define cs_sles_t structure in accordance with the settings of a cs_param_sles_t structure (SLES = Spa...
Definition: cs_param_sles.c:2920
void cs_param_sles_mumps_advanced(cs_param_sles_t *slesp, cs_param_sles_analysis_algo_t analysis_algo, int block_analysis, double mem_coef, double blr_threshold, int ir_steps, bool advanced_optim)
Definition: cs_param_sles.c:3035
void cs_param_sles_saddle_copy(const cs_param_sles_saddle_t *ref, cs_param_sles_saddle_t *dest)
Copy a cs_param_sles_saddle_t structure from ref to dest.
Definition: cs_param_sles.c:2638
void cs_param_sles_saddle_init_schur(const char *basename, cs_param_sles_saddle_t *saddlep)
Initialize a cs_param_sles_t structure for the Schur approximation nested inside a ref cs_param_sles_...
Definition: cs_param_sles.c:2602
void cs_param_sles_log(cs_param_sles_t *slesp)
Log information related to the linear settings stored in the structure.
Definition: cs_param_sles.c:2778
void cs_param_sles_copy_from(cs_param_sles_t *src, cs_param_sles_t *dst)
Copy a cs_param_sles_t structure from src to dst.
Definition: cs_param_sles.c:2872
void cs_param_sles_saddle_free(cs_param_sles_saddle_t **p_saddlep)
Free the structure storing the parameter settings for a saddle-point system.
Definition: cs_param_sles.c:2673
cs_param_resnorm_type_t
Definition: cs_param_types.h:1021
cs_param_saddle_solver_t
Type of solver used to solve a saddle-point system. Up to now, this happens only with CDO cell-based ...
Definition: cs_param_types.h:698
cs_param_precond_type_t
Definition: cs_param_types.h:898
Definition: cs_param_types.h:586
cs_param_precond_block_t
Definition: cs_param_types.h:819
Definition: cs_param_types.h:989
@ CS_PARAM_ITSOL_MUMPS
Definition: cs_param_types.h:1007
cs_param_saddle_precond_t
Type of preconditioner used to solve a saddle-point system. Up to now, this happens only with CDO cel...
Definition: cs_param_types.h:656
cs_param_schur_approx_t
Strategy to build the Schur complement approximation. This appears in block preconditioning or Uzawa ...
Definition: cs_param_types.h:753
cs_param_amg_type_t
Definition: cs_param_types.h:604
Set of parameters to check the convergence (or the divergence) of an iterative process (tolerances or...
Definition: cs_param_sles.h:61
double atol
Definition: cs_param_sles.h:78
double dtol
Definition: cs_param_sles.h:80
int n_max_iter
Definition: cs_param_sles.h:81
double rtol
Definition: cs_param_sles.h:79
Set of parameters to specify additional options to MUMPS For more advanced settings,...
Definition: cs_param_sles.h:173
Definition: cs_param_sles.h:191
double mem_coef
Definition: cs_param_sles.h:195
int ir_steps
Definition: cs_param_sles.h:202
int block_analysis
Definition: cs_param_sles.h:199
bool is_single
Definition: cs_param_sles.h:186
Definition: cs_param_sles.h:184
bool advanced_optim
Definition: cs_param_sles.h:188
Definition: cs_param_sles.h:183
Structure storing all metadata related to the resolution of a saddle-point linear system.
Definition: cs_param_sles.h:262
cs_param_sles_cvg_t cvg_param
Definition: cs_param_sles.h:301
cs_param_saddle_precond_t precond
Definition: cs_param_sles.h:292
cs_param_sles_t * schur_sles_param
Definition: cs_param_sles.h:327
cs_param_saddle_solver_t solver
Definition: cs_param_sles.h:285
cs_param_schur_approx_t schur_approximation
Definition: cs_param_sles.h:320
int verbosity
Definition: cs_param_sles.h:269
Definition: cs_param_sles.h:213
Definition: cs_param_sles.h:245
int field_id
Definition: cs_param_sles.h:216
int verbosity
Definition: cs_param_sles.h:218
void * context_param
Definition: cs_param_sles.h:252
char * name
Definition: cs_param_sles.h:215
cs_param_resnorm_type_t resnorm_type
Definition: cs_param_sles.h:238
Definition: cs_param_sles.h:223
cs_param_precond_type_t precond
Definition: cs_param_sles.h:222
int restart
Definition: cs_param_sles.h:225
cs_param_sles_class_t solver_class
Definition: cs_param_sles.h:221
bool setup_done
Definition: cs_param_sles.h:219
Definition: cs_param_sles.h:226
bool flexible
Definition: cs_param_sles.h:224
cs_param_precond_block_t pcd_block_type
Definition: cs_param_sles.h:232
