Set of parameters to check the convergence (or the divergence) of an iterative process (tolerances or max. number of iterations) More...
#include <cs_param_sles.h>
Collaboration diagram for cs_param_sles_cvg_t:Data Fields | |
| double | atol |
| double | rtol |
| double | dtol |
| int | n_max_iter |
| atol |
Absolute tolerance under which the iterative process is stopped
| dtol |
Tolerance above which the iterative process is stated as "diverged". Not used if < 0
| n_max_iter |
Maximal number of iterations before stopping the iterative process
| rtol |
Relative tolerance under which the iterative process is stopped
