#include "cs_boundary.h"#include "cs_cdo_turbulence.h"#include "cs_equation_param.h"#include "cs_iter_algo.h"#include "cs_math.h"#include "cs_param_sles.h"#include "cs_physical_constants.h"
Include dependency graph for cs_navsto_param.h:Go to the source code of this file.
| struct | cs_navsto_param_sles_t |
| Structure storing the parameters for solving the Navier-Stokes system. More... | |
| struct | cs_navsto_param_boussinesq_t |
| Structure storing the parameters related to the Boussinesq source term in the momentum equation. More... | |
| struct | cs_navsto_param_t |
| Structure storing the parameters related to the resolution of the Navier-Stokes system. More... | |
Macros | |
| #define | CS_NAVSTO_STREAM_EQNAME "streamfunction_eq" |
| typedef cs_flag_t | cs_navsto_param_model_flag_t |
| typedef cs_flag_t | cs_navsto_param_post_flag_t |
| static bool | cs_navsto_param_is_steady (const cs_navsto_param_t *nsp) |
| Ask cs_navsto_param_t structure if the settings correspond to a steady computation. More... | |
| double | cs_navsto_param_get_notay_scaling (void) |
| Retrieve the scaling coefficient used in the Notay's transformation devised in "Algebraic multigrid for Stokes equations" SIAM J. Sci. Comput. Vol. 39 (5), 2017 In this article, this scaling is denoted by alpha. More... | |
| void | cs_navsto_param_set_notay_scaling (double scaling_coef) |
| Set the scaling coefficient used in the Notay's transformation devised in "Algebraic multigrid for Stokes equations" SIAM J. Sci. Comput. Vol. 39 (5), 2017 In this article, this scaling is denoted by alpha. More... | |
| cs_navsto_param_t * | cs_navsto_param_create (const cs_boundary_t *boundaries, cs_navsto_param_model_t model, cs_navsto_param_model_flag_t model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t post_flag) |
| Create a new structure to store all numerical parameters related to the resolution of the Navier-Stokes (NS) system. More... | |
| cs_navsto_param_t * | cs_navsto_param_free (cs_navsto_param_t *param) |
| Free a cs_navsto_param_t structure. More... | |
| void | cs_navsto_param_set (cs_navsto_param_t *nsp, cs_navsto_key_t key, const char *keyval) |
| Set a parameter attached to a keyname in a cs_navsto_param_t structure. More... | |
| void | cs_navsto_param_transfer (const cs_navsto_param_t *nsp, cs_equation_param_t *eqp) |
| Apply the numerical settings defined for the Navier-Stokes system to an equation related to this system. Be aware that the user-defined settings can be modified in this function when a different choice is set between the settings for the Navier-Stokes system and the settings for the momentum equation. The final choice is given by the settings for the Navier-Stokes system. More... | |
| void | cs_navsto_param_log (const cs_navsto_param_t *nsp) |
| Summary of the main cs_navsto_param_t structure. More... | |
| cs_navsto_param_boussinesq_t * | cs_navsto_param_add_boussinesq_term (cs_navsto_param_t *nsp, cs_real_t dilatation_coef, cs_real_t reference_value) |
| Add a new Boussinesq term (source term for the momemtum equation) More... | |
| void | cs_navsto_param_set_boussinesq_array (cs_navsto_param_boussinesq_t *bp, const cs_real_t *var) |
| Set the array of values to consider in the Boussinesq term. More... | |
| cs_navsto_param_sles_t * | cs_navsto_param_get_sles_param (const cs_navsto_param_t *nsp) |
| Retrieve the cs_equation_param_t structure related to the velocity equation (momentum equation in most of the cases) More... | |
| cs_equation_param_t * | cs_navsto_param_get_velocity_param (const cs_navsto_param_t *nsp) |
| const char * | cs_navsto_param_get_model_name (cs_navsto_param_model_t model) |
| Retrieve the name of the model system of equations. More... | |
| const char * | cs_navsto_param_get_coupling_name (cs_navsto_param_coupling_t coupling) |
| Retrieve the name of the coupling algorithm. More... | |
| void | cs_navsto_set_reference_pressure (cs_navsto_param_t *nsp, cs_real_t pref) |
| Set the value to consider for the reference pressure. More... | |
| cs_xdef_t * | cs_navsto_add_velocity_ic_by_value (cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val) |
| Define the initial condition for the velocity unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set to a constant value. More... | |
| cs_xdef_t * | cs_navsto_add_velocity_ic_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input) |
| Define the initial condition for the velocity unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set according to an analytical function. More... | |
| cs_xdef_t * | cs_navsto_add_pressure_ic_by_value (cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val) |
| Define the initial condition for the pressure unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set to a constant value. More... | |
| cs_xdef_t * | cs_navsto_add_pressure_ic_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input) |
| Define the initial condition for the pressure unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set according to an analytical function. More... | |
| void | cs_navsto_set_fixed_walls (cs_navsto_param_t *nsp) |
| Add the definition of boundary conditions related to a fixed wall into the set of parameters for the management of the Navier-Stokes system of equations. More... | |
| void | cs_navsto_set_symmetries (cs_navsto_param_t *nsp) |
| Add the definition of boundary conditions related to a symmetry into the set of parameters for the management of the Navier-Stokes system of equations. More... | |
| void | cs_navsto_set_outlets (cs_navsto_param_t *nsp) |
| Add the definition of boundary conditions related to outlets into the set of parameters for the management of the Navier-Stokes system of equations. More... | |
| cs_xdef_t * | cs_navsto_set_pressure_bc_by_value (cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values) |
| Set the pressure field on a boundary using a uniform value. More... | |
| cs_xdef_t * | cs_navsto_set_velocity_wall_by_value (cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values) |
| Define the velocity field for a sliding wall boundary using a uniform value. More... | |
| cs_xdef_t * | cs_navsto_set_velocity_inlet_by_value (cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values) |
| Define the velocity field for an inlet boundary using a uniform value. More... | |
| cs_xdef_t * | cs_navsto_set_velocity_inlet_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input) |
| Define the velocity field for an inlet boundary using an analytical function. More... | |
| cs_xdef_t * | cs_navsto_set_velocity_inlet_by_array (cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length) |
| Define the velocity field for an inlet boundary using an array of values. More... | |
| cs_xdef_t * | cs_navsto_set_velocity_inlet_by_dof_func (cs_navsto_param_t *nsp, const char *z_name, cs_flag_t dof_loc, cs_dof_func_t *func, void *func_input) |
| Define the velocity field for an inlet boundary using a DoF function. More... | |
| cs_xdef_t * | cs_navsto_add_source_term_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input) |
| Define a new source term structure defined by an analytical function. More... | |
| cs_xdef_t * | cs_navsto_add_source_term_by_val (cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val) |
| Define a new source term structure defined by a constant value. More... | |
| cs_xdef_t * | cs_navsto_add_source_term_by_array (cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length) |
| Define a new source term structure defined by an array. More... | |
| void | cs_navsto_add_oseen_field (cs_navsto_param_t *nsp, cs_adv_field_t *adv_fld) |
| Add a advection field for the Oseen problem. More... | |
| #define CS_NAVSTO_STREAM_EQNAME "streamfunction_eq" |
| typedef cs_flag_t cs_navsto_param_post_flag_t |
| enum cs_navsto_key_t |
List of available keys for setting the parameters of the Navier-Stokes system.
| Enumerator | |
| CS_NSKEY_DOF_REDUCTION | Set how the DoFs are defined (similar to CS_EQKEY_DOF_REDUCTION) Enable to set this type of DoFs definition for all related equations |
| CS_NSKEY_GD_SCALE_COEF | Set the scaling of the grad-div term when an artificial compressibility algorithm or an Uzawa-Augmented Lagrangian method is used |
| CS_NSKEY_IL_ALGO_ATOL | Absolute tolerance at which the Oseen or Stokes system is resolved. These systems corresponds to an inner linear system to solve when considering the Navier-Stokes system since one has to handle the non-linearity in addition as an outer process. |
| CS_NSKEY_IL_ALGO_DTOL | Divergence tolerance at which the Oseen or Stokes system is resolved. These systems corresponds to an inner linear system to solve when considering the Navier-Stokes system since one has to handle the non-linearity in addition as an outer process. |
| CS_NSKEY_IL_ALGO_RTOL | Relative tolerance at which the Oseen or Stokes system is resolved. These systems corresponds to an inner linear system to solve when considering the Navier-Stokes system since one has to handle the non-linearity in addition as an outer process. |
| CS_NSKEY_IL_ALGO_RESTART | Number of iterations before restarting a Krylov solver as the main solver (useful if the strategy implied a GMRES, flexible GMRES or GCR) |
| CS_NSKEY_MAX_IL_ALGO_ITER | Set the maximal number of iteration for solving the inner linear system. |
| CS_NSKEY_MAX_NL_ALGO_ITER | Set the maximal number of iterations for solving the non-linearity arising from the advection form |
| CS_NSKEY_MAX_OUTER_ITER | Set the maximal number of outer iterations for solving the full system including the turbulence modelling or the thermal system for instance |
| CS_NSKEY_NL_ALGO | Type of algorithm to consider to solve the non-linearity arising from the Navier-Stokes system (Picard or Anderson) |
| CS_NSKEY_NL_ALGO_ATOL | Absolute tolerance at which the non-linearity arising from the advection term is resolved |
| CS_NSKEY_NL_ALGO_DTOL | Threshold at which the non-linear algorithm is set as diverged |
| CS_NSKEY_NL_ALGO_RTOL | Relative tolerance at which the non-linearity arising from the advection term is resolved |
| CS_NSKEY_QUADRATURE | Set the type to use in all functions involving quadrature (similar to CS_EQKEY_BC_QUADRATURE) |
| CS_NSKEY_SCHUR_STRATEGY | Set the way to define the Schur complement approximation (cf. cs_param_schur_approx_t) |
| CS_NSKEY_SLES_STRATEGY | Strategy for solving the SLES arising from the discretization of the Navier-Stokes system |
| CS_NSKEY_SLES_VERBOSITY | Level of verbosity related to the resolution step (inner linear and non-linear algoritms according to the settings) |
| CS_NSKEY_SPACE_SCHEME | Numerical scheme for the space discretization. Available choices are:
| CS_NSKEY_THERMAL_TOLERANCE | Value of the tolerance criterion under which one stops iterating on the Navier-Stokes and thermal systems |
| CS_NSKEY_VERBOSITY | Set the level of details for the specific part related to the Navier-Stokes system |
| CS_NSKEY_N_KEYS | |
Bit values for additional physical modelling related to the Navier-Stokes system of equations.
| Enumerator | |
| CS_NAVSTO_MODEL_STEADY | There is no time dependency in the model |
| CS_NAVSTO_MODEL_GRAVITY_EFFECTS | Take into account the gravity effects (add a constant source term equal to rho*vect(g)) |
| CS_NAVSTO_MODEL_CORIOLIS_EFFECTS | Take into account the Coriolis effects (add a source term) |
| CS_NAVSTO_MODEL_PASSIVE_THERMAL_TRACER | An additional equation is created involving the thermal equation. The advection field is automatically set as the mass flux. By default, the temperature is solved in Celsius and homogeneous Neumann boundary conditions (no flux) are set. This option is not compatible with the option CS_NAVSTO_MODEL_BOUSSINESQ |
| CS_NAVSTO_MODEL_BOUSSINESQ | An additional equation is created involving the thermal equation. The advection field is automatically set as the mass flux. By default, the temperature is solved in Celsius and homogeneous Neumann boundary conditions (no flux) are set. The variation of mass density around a reference value is related to the variation of temperature w.r.t. a reference temperature and it plays a role in the gravity effects (rho.vect(g)) The gradient of temperature is assumed to have a small norm and the mass density variates in a small range. In this case, an additional momentum source term is added. |
| CS_NAVSTO_MODEL_WITH_SOLIDIFICATION | The Navier-Stokes is modified to take into account solidification process. A boussinesq term is added as well as a head loss term derived from a Darcy approximation. Please see the cs_solidification_model_t structure and related structures for more details |
Describe the system of equations related to the Navier-Stokes to be solved.
| Enumerator | |
| CS_NAVSTO_MODEL_STOKES | Stokes equations (mass and momentum) with the classical choice of variables i.e. velocity and pressure. Mass density is assumed to be constant. |
| CS_NAVSTO_MODEL_OSEEN | Like the incompressible Navier-Stokes equations (mass and momentum) but with a velocity field which is given. Thus the advection term in the momentum equation is linear. Unknowns: velocity and pressure. Mass density is assumed to be constant. The advection field is set using cs_navsto_add_oseen_field |
| CS_NAVSTO_MODEL_INCOMPRESSIBLE_NAVIER_STOKES | Navier-Stokes equations: mass and momentum with a constant mass density Mass equation is equivalent to an incompressibility constraint |
| CS_NAVSTO_N_MODELS | |
Bit values for additional generic postprocessing related to the Navier-Stokes module. In what follows, w denotes the vorticity vector, u the velocity vector and k the kinetic energy defined by
| enum cs_navsto_sles_t |
High-level information about the way of settings the SLES for solving the Navier-Stokes system. When the system is treated as a saddle-point problem (monolithic approach in what follows), then one uses these notations: A_{00} is the upper-left block and A_{11} (should be 0 but the preconditioner may have entries for the approximation of the inverse of the Schur complement).
| Enumerator | |
| CS_NAVSTO_SLES_ADDITIVE_GMRES_BY_BLOCK | Associated keyword: "additive_gmres" Available choice when a monolithic approach is used (i.e. with the parameter CS_NAVSTO_COUPLING_MONOLITHIC is set as coupling algorithm) The Navier-Stokes system of equations is solved an additive preconditioner (block diagonal matrix where the block 00 is A_{00}) and the block 11 is set to the identity. Preconditioner/solver for the block 00 is set using the momentum equation. This option is only available with the support to the PETSc library up to now. |
| CS_NAVSTO_SLES_BLOCK_MULTIGRID_CG | Associated keyword: "block_amg_cg" The Navier-Stokes system of equations is solved using a multigrid on each diagonal block as a preconditioner and applying a conjugate gradient as solver. Use this strategy when the saddle-point problem has been reformulated into a "classical" linear system. For instance when a Uzawa or an Artificial Compressibility coupling algorithm is used. (i.e. with the parameter CS_NAVSTO_COUPLING_ARTIFICIAL_COMPRESSIBILITY is set as coupling algorithm). This option is only available with the support to the PETSc library up to now. |
| CS_NAVSTO_SLES_BY_BLOCKS | |
| CS_NAVSTO_SLES_DIAG_SCHUR_GCR | Associated keyword: "diag_schur_gcr" The Stokes or Navier-Stokes system is solved using a GCR algorithm with a block diagonal preconditioner using a Schur approximation for the pressure block (the block 22). The system is stored using a hybrid assembled/unassembled blocks. The velocity block is assembled (with potentially sub-blocks for each component) and the velocity divergence/pressure gradient operators are unassembled. |
| CS_NAVSTO_SLES_DIAG_SCHUR_GMRES | Associated keyword: "diag_schur_gmres" Available choice when a monolithic approach is used (i.e. with the parameter CS_NAVSTO_COUPLING_MONOLITHIC is set as coupling algorithm). The Navier-Stokes system of equations is solved using a block diagonal preconditioner where the block 00 is A_{00} preconditioned with one multigrid iteration and the block 11 is an approximation of the Schur complement preconditioned with one multigrid iteration. The main iterative solver is a flexible GMRES. This option is only available with the support to the PETSc library up to now. |
| CS_NAVSTO_SLES_DIAG_SCHUR_MINRES | Associated keyword: "diag_schur_minres" The Stokes or Navier-Stokes system with an explicit advection is solved using a MINRES algorithm with a block diagonal preconditioner using a Schur approximation for the pressure block (the block 22). The system is stored using a hybrid assembled/unassembled blocks. The velocity block is assembled (with potentially sub-blocks for each component) and the velocity divergence/pressure gradient operators are unassembled. |
| CS_NAVSTO_SLES_EQ_WITHOUT_BLOCK | Associated keyword: "no_block" Use the same mechanism as for a stand-alone equation. In this case, the setting relies on the function cs_equation_set_sles and the different options for solving a linear system such as the choice of the iterative solver or the choice of the preconditioner or the type of residual normalization |
| CS_NAVSTO_SLES_GCR | Associated keyword: "gcr" The Stokes or Navier-Stokes system is solved using a GCR algorithm without preconditioning. The system is stored using a hybrid assembled/unassembled blocks. The velocity block is assembled (with potentially sub-blocks for each component) and the velocity divergence/pressure gradient operators are unassembled. |
| CS_NAVSTO_SLES_GKB_PETSC | Associated keyword: "gkb_petsc" Available choice when a monolithic approach is used (i.e. with the parameter CS_NAVSTO_COUPLING_MONOLITHIC is set as coupling algorithm). The Navier-Stokes system of equations is solved using a Golub-Kahan bi-diagonalization. One assumes that the saddle-point system is symmetric. By default, the block A_{00} may be augmented (this is not the default choice) and is solved with a conjugate gradient algorithm preconditioned with a multigrid. The residual is computed in the energy norm. This option is only available with the support to the PETSc library up to now. |
| CS_NAVSTO_SLES_GKB_GMRES | Associated keyword: "gkb_gmres" Available choice when a monolithic approach is used (i.e. with the parameter CS_NAVSTO_COUPLING_MONOLITHIC is set as coupling algorithm). The Navier-Stokes system of equations is solved using a Golub-Kahan bi-diagonalization (GKB) as preconditioner of a flexible GMRES solver. The GKB algorithm is solved with a reduced tolerance as well as the CG+Multigrid used as an inner solver in the GKB algorithm. One assumes that the saddle-point system is symmetric. The residual for the GKB part is computed in the energy norm. This option is only available with the support to the PETSc library up to now. |
| CS_NAVSTO_SLES_GKB_SATURNE | Associated keyword: "gkb" or "gkb_saturne" Available choice when a monolithic approach is used (i.e. with the parameter CS_NAVSTO_COUPLING_MONOLITHIC is set as coupling algorithm). The Navier-Stokes system of equations is solved using a Golub-Kahan bi-diagonalization. By default, the block A_{00} may be augmented (this is not the default choice) and is solved with the SLES settings given to the momentum equation A conjugate gradient algorithm preconditioned with a multigrid for Stokes for instance. The residual is computed in the energy norm. |
| CS_NAVSTO_SLES_LOWER_SCHUR_GCR | Associated keyword: "lower_schur_gcr" The Stokes or Navier-Stokes system is solved using a GCR algorithm with an lower triangular block preconditioner using a Schur approximation for the pressure block (the block 22). The system is stored using a hybrid assembled/unassembled blocks. The velocity block is assembled (with potentially sub-blocks for each component) and the velocity divergence/pressure gradient operators are unassembled. |
| CS_NAVSTO_SLES_MINRES | Associated keyword: "minres" The Stokes or Navier-Stokes system with an explicit advection is solved using a MINRES algorithm without preconditioning. The system is stored using a hybrid assembled/unassembled blocks. The velocity block is assembled (with potentially sub-blocks for each component) and the velocity divergence/pressure gradient operators are unassembled. |
| CS_NAVSTO_SLES_MULTIPLICATIVE_GMRES_BY_BLOCK | Associated keyword: "multiplicative_gmres" Available choice when a monolithic approach is used (i.e. with the parameter CS_NAVSTO_COUPLING_MONOLITHIC is set as coupling algorithm) The Navier-Stokes system of equations is solved a multiplicative preconditioner (block diagonal matrix where the block 00 is A_{00}) and the block 11 is set to the identity. Block 01 is also considered in the block preconditioner. Preconditioner/solver for the block 00 is set using the momentum equation. This option is only available with the support to the PETSc library up to now. |
| CS_NAVSTO_SLES_MUMPS | Associated keyword: "mumps" Direct solver to solve the full (saddle-point) system arising from the discretization of the Navier-Stokes equations |
| CS_NAVSTO_SLES_NOTAY_TRANSFORM | Associated keyword: "notay" Transform the saddle-point problem into an equivalent system without a zero block for the (2,2) block. This transformation allows one to consider standard preconditionner and iterative Krylow solver. |
| CS_NAVSTO_SLES_SGS_SCHUR_GCR | Associated keyword: "sgs_schur_gcr" The Stokes or Navier-Stokes system is solved using a GCR algorithm with a symmetric Gauss-Seidel block preconditioner using a Schur approximation for the pressure block (the block 22). The system is stored using a hybrid assembled/unassembled blocks. The velocity block is assembled (with potentially sub-blocks for each component) and the velocity divergence/pressure gradient operators are unassembled. |
| CS_NAVSTO_SLES_UPPER_SCHUR_GCR | Associated keyword: "upper_schur_gcr" The Stokes or Navier-Stokes system is solved using a GCR algorithm with an upper triangular block preconditioner using a Schur approximation for the pressure block (the block 22). The system is stored using a hybrid assembled/unassembled blocks. The velocity block is assembled (with potentially sub-blocks for each component) and the velocity divergence/pressure gradient operators are unassembled. |
| CS_NAVSTO_SLES_UPPER_SCHUR_GMRES | Associated keyword: "upper_schur_gmres" Available choice when a monolithic approach is used (i.e. with the parameter CS_NAVSTO_COUPLING_MONOLITHIC is set as coupling algorithm). The Navier-Stokes system of equations is solved using a upper triangular block preconditioner where the block 00 is A_{00} preconditioned with one multigrid iteration and the block 11 is an approximation of the Schur complement preconditioned with a minres. The main iterative solver is a flexible GMRES. This option is only available with the support to the PETSc library up to now. |
| CS_NAVSTO_SLES_USER | Associated keyword: "user" Resolution using a user-defined function. This function fulfills a pre-defined prototype |
| CS_NAVSTO_SLES_UZAWA_SCHUR_GCR | Associated keyword: "uza_schur_gcr" The Stokes or Navier-Stokes system is solved using a GCR algorithm with an Uzawa algorithm tuned for block preconditioning and using a Schur approximation for the pressure block (the block 22). The system is stored using a hybrid assembled/unassembled blocks. The velocity block is assembled (with potentially sub-blocks for each component) and the velocity divergence/pressure gradient operators are unassembled. |
| CS_NAVSTO_SLES_UZAWA_AL | Associated keyword: "uzawa_al" Resolution using an uzawa algorithm with an Augmented Lagrangian approach |
| CS_NAVSTO_SLES_UZAWA_CG | Associated keyword: "uzawa_cg" Resolution using an uzawa algorithm optimized using a conjugate gradient reformulation. Two systems are solved at each iteration (one related to the velocity block, one related to the Schur complement approximation - size of the pressure space). |
| CS_NAVSTO_SLES_N_TYPES | |
| void cs_navsto_add_oseen_field | ( | cs_navsto_param_t * | nsp, |
| cs_adv_field_t * | adv_fld | ||
| [in,out] | nsp | pointer to a cs_navsto_param_t |
| [in,out] | adv_fld | pointer to a cs_adv_field_t |
| cs_xdef_t* cs_navsto_add_pressure_ic_by_analytic | ( | cs_navsto_param_t * | nsp, |
| const char * | z_name, | ||
| cs_analytic_func_t * | analytic, | ||
| void * | input | ||
| [in] | z_name | name of the associated zone (if NULL or "" if all cells are considered) |
| [in] | analytic | pointer to an analytic function |
| cs_xdef_t* cs_navsto_add_pressure_ic_by_value | ( | cs_navsto_param_t * | nsp, |
| cs_real_t * | val | ||
| [in] | val | pointer to the value |
| cs_xdef_t* cs_navsto_add_source_term_by_analytic | ( | cs_navsto_param_t * | nsp, |
| cs_analytic_func_t * | ana, | ||
| void * | input | ||
| [in] | z_name | name of the associated zone (if NULL or "" all cells are considered) |
| [in] | ana | pointer to an analytical function |
| cs_xdef_t* cs_navsto_add_source_term_by_array | ( | cs_navsto_param_t * | nsp, |
| cs_flag_t | loc, | ||
| cs_real_t * | array, | ||
| bool | is_owner, | ||
| bool | full_length | ||
| [in] | is_owner | transfer the lifecycle to the cs_xdef_t structure (true or false) |
| [in] | full_length | if true, array size is allocated and filled to access the full-length array corresponding to all locations where are defined the values |
| cs_xdef_t* cs_navsto_add_source_term_by_val | ( | cs_navsto_param_t * | nsp, |
| [in] | val | pointer to the value to set |
| cs_xdef_t* cs_navsto_add_velocity_ic_by_analytic | ( | cs_navsto_param_t * | nsp, |
| void * | input | ||
| cs_xdef_t* cs_navsto_add_velocity_ic_by_value | ( | cs_navsto_param_t * | nsp, |
| cs_navsto_param_boussinesq_t* cs_navsto_param_add_boussinesq_term | ( | cs_navsto_param_t * | nsp, |
| cs_real_t | dilatation_coef, | ||
| cs_real_t | reference_value | ||
| [in,out] | nsp | pointer to a cs_navsto_param_t struct. |
| [in] | dilatation_coef | value of the dilatation coefficient |
| [in] | reference_value | reference value of the associated variable |
| cs_navsto_param_t* cs_navsto_param_create | ( | const cs_boundary_t * | boundaries, |
| cs_navsto_param_model_t | model, | ||
| cs_navsto_param_model_flag_t | model_flag, | ||
| cs_navsto_param_coupling_t | algo_coupling, | ||
| cs_navsto_param_post_flag_t | post_flag | ||
| [in] | boundaries | pointer to a cs_boundary_t structure |
| [in] | model | type of model related to the NS system |
| [in] | model_flag | additional high-level model options |
| [in] | algo_coupling | algorithm used for solving the NS system |
| [in] | post_flag | predefined post-processings options |
| cs_navsto_param_t* cs_navsto_param_free | ( | cs_navsto_param_t * | param | ) |
| [in,out] | param | pointer to a cs_navsto_param_t structure |
| const char* cs_navsto_param_get_coupling_name | ( | cs_navsto_param_coupling_t | coupling | ) |
| [in] | coupling | a cs_navsto_param_coupling_t |
| const char* cs_navsto_param_get_model_name | ( | cs_navsto_param_model_t | model | ) |
| [in] | model | a cs_navsto_param_model_t |
| double cs_navsto_param_get_notay_scaling | ( | void | ) |
| cs_navsto_param_sles_t* cs_navsto_param_get_sles_param | ( | const cs_navsto_param_t * | nsp | ) |
| cs_equation_param_t* cs_navsto_param_get_velocity_param | ( | const cs_navsto_param_t * | nsp | ) |
inlinestatic |
| void cs_navsto_param_log | ( | const cs_navsto_param_t * | nsp | ) |
| void cs_navsto_param_set | ( | cs_navsto_param_t * | nsp, |
| cs_navsto_key_t | key, | ||
| const char * | keyval | ||
| [in,out] | nsp | pointer to a cs_navsto_param_t structure to set |
| void cs_navsto_param_set_boussinesq_array | ( | cs_navsto_param_boussinesq_t * | bp, |
| const cs_real_t * | var | ||
| [in,out] | bp | pointer to a cs_navsto_param_boussinesq_t structure |
| [in] | var | shared pointer to the array of values to consider |
| void cs_navsto_param_set_notay_scaling | ( | double | scaling_coef | ) |
| [in] | scaling_coef | valued of the scaling coefficient |
| void cs_navsto_param_transfer | ( | const cs_navsto_param_t * | nsp, |
| cs_equation_param_t * | eqp | ||
| [in,out] | eqp | pointer to a cs_equation_param_t structure |
| void cs_navsto_set_fixed_walls | ( | cs_navsto_param_t * | nsp | ) |
| void cs_navsto_set_outlets | ( | cs_navsto_param_t * | nsp | ) |
| cs_xdef_t* cs_navsto_set_pressure_bc_by_value | ( | cs_navsto_param_t * | nsp, |
| cs_real_t * | values | ||
| [in] | z_name | name of the associated zone (if NULL or "" all boundary faces are considered) |
| [in] | values | value to set |
| void cs_navsto_set_reference_pressure | ( | cs_navsto_param_t * | nsp, |
| cs_real_t | pref | ||
| [in] | pref | value of the reference pressure |
| void cs_navsto_set_symmetries | ( | cs_navsto_param_t * | nsp | ) |
| cs_xdef_t* cs_navsto_set_velocity_inlet_by_analytic | ( | cs_navsto_param_t * | nsp, |
| void * | input | ||
| cs_xdef_t* cs_navsto_set_velocity_inlet_by_array | ( | cs_navsto_param_t * | nsp, |
| [in] | full_length | if true, the size of "array" should be allocated to the total numbers of entities related to the given location. If false, a new list is allocated and filled with the related subset indirection. |
| cs_xdef_t* cs_navsto_set_velocity_inlet_by_dof_func | ( | cs_navsto_param_t * | nsp, |
| cs_flag_t | dof_loc, | ||
| void * | func_input | ||
| [in] | dof_loc | where are located DoFs |
| [in] | func | pointer to a cs_dof_function_t |
| [in] | func_input | NULL or pointer to a structure cast on-the-fly |
| cs_xdef_t* cs_navsto_set_velocity_inlet_by_value | ( | cs_navsto_param_t * | nsp, |
| [in] | values | array of three real values |
| cs_xdef_t* cs_navsto_set_velocity_wall_by_value | ( | cs_navsto_param_t * | nsp, |
