Log field and other array statistics at relevant time steps. More...
#include <stdarg.h>
#include "cs_array_reduce.h"
#include "cs_ctwr.h"
#include "cs_fan.h"
#include "cs_function.h"
#include "cs_map.h"
#include "cs_mesh_location.h"
#include "cs_parameters.h"
#include "cs_prototypes.h"
#include "cs_range_set.h"
#include "cs_time_moment.h"
#include "cs_time_plot.h"
#include "cs_time_step.h"
#include "cs_lagr_stat.h"
#include "cs_lagr_log.h"
#include "fvm_convert_array.h"
#include "cs_log_iteration.h"
void | cs_log_iteration_destroy_all (void) |
Free arrays possible used by logging of array statistics. More... | |
void | cs_log_iteration (void) |
Log field and other array statistics for the current time step. More... | |
void | cs_log_iteration_add_array (const char *name, const char *category, const cs_mesh_location_type_t loc_id, bool is_intensive, int dim, const cs_real_t val[]) |
Add or update array not saved as permanent field to iteration log. More... | |
void | cs_log_iteration_clipping (const char *name, int dim, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[]) |
Add or update clipping info for a given array. More... | |
void | cs_log_iteration_clipping_field (int f_id, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[], cs_lnum_t n_clip_min_comp[], cs_lnum_t n_clip_max_comp[]) |
Add or update clipping info for a field. More... | |
void | cs_log_iteration_prepare (void) |
Initialize structures used for logging for new iteration. More... | |
void | cs_log_iteration_l2residual (void) |
Log L2 time residual for variable fields. More... | |
void cs_log_iteration | ( | void | ) |
void cs_log_iteration_add_array | ( | const char * | name, |
const char * | category, | ||
const cs_mesh_location_type_t | loc_id, | ||
bool | is_intensive, | ||
int | dim, | ||
const cs_real_t | val[] | ||
[in] | name | array name |
[in] | category | category name |
[in] | loc_id | associated mesh location id |
[in] | is_intensive | are the matching values intensive ? |
[in] | dim | associated dimension (interleaved) |
[in] | val | associated values |
void cs_log_iteration_clipping | ( | const char * | name, |
int | dim, | ||
cs_lnum_t | n_clip_min, | ||
cs_lnum_t | n_clip_max, | ||
const cs_real_t | min_pre_clip[], | ||
const cs_real_t | max_pre_clip[] | ||
[in] | name | field or array name |
[in] | dim | associated dimension |
[in] | n_clip_min | number of local clippings to minimum value |
[in] | n_clip_max | number of local clippings to maximum value |
[in] | min_pre_clip | minimum values prior to clipping |
[in] | max_pre_clip | maximum values prior to clipping |
void cs_log_iteration_clipping_field | ( | int | f_id, |
const cs_real_t | max_pre_clip[], | ||
cs_lnum_t | n_clip_min_comp[], | ||
cs_lnum_t | n_clip_max_comp[] | ||
[in] | f_id | associated field id |
[in] | n_clip_min_comp | number of clip min by component |
[in] | n_clip_max_comp | number of clip max by component |
void cs_log_iteration_destroy_all | ( | void | ) |
void cs_log_iteration_l2residual | ( | void | ) |
void cs_log_iteration_prepare | ( | void | ) |
