8.1
cs_function.h
1 #ifndef __CS_FUNCTION_H__
2 #define __CS_FUNCTION_H__
5  * Function objects management.
35  * Local headers
38 #include "cs_defs.h"
39 #include "cs_mesh_location.h"
40 #include "cs_param_types.h"
41 #include "cs_restart_default.h"
46
48  * Macro definitions
50
57 /*
58  * Function property type
59  */
60
62 #define CS_FUNCTION_INTENSIVE (1 << 0)
63
65 #define CS_FUNCTION_EXTENSIVE (1 << 1)
66
68 #define CS_FUNCTION_TIME_INDEPENDENT (1 << 2)
69
71 #define CS_FUNCTION_USER (1 << 3)
72
74 #define CS_FUNCTION_NO_MPI_CALL (1 << 4)
75
77 #define CS_FUNCTION_NO_SUB_TASK (1 << 5)
78
81 /*============================================================================
82  * Type definitions
83  *============================================================================*/
84
109 /*----------------------------------------------------------------------------*/
110
111 typedef void
112 (cs_eval_at_location_t) (int location_id,
113  cs_lnum_t n_elts,
114  const cs_lnum_t *elt_ids,
115  void *input,
116  void *vals);
117
118 /* Function descriptor */
119 /*---------------------*/
120
121 typedef struct {
122
123  const char *name;
124  char *label;
127  const int id;
128  int type;
130  const int dim;
133  const int location_id;
137  int post_vis;
141  int log;
160  void *func_input; /* Pointer to optional (untyped)
161  value or structure, for use by
162  evaluation function */
163
164 } cs_function_t;
165
166 /*=============================================================================
167  * Global variables
168  *============================================================================*/
169
170 /*============================================================================
171  * Public function prototypes
172  *============================================================================*/
173
174 /*----------------------------------------------------------------------------*/
193 /*----------------------------------------------------------------------------*/
194
196 cs_function_define_by_func(const char *name,
197  int location_id,
198  int dim,
199  bool is_intensive,
200  cs_datatype_t datatype,
201  cs_eval_at_location_t *data_func,
202  void *data_input);
203
204 /*----------------------------------------------------------------------------*/
224 /*----------------------------------------------------------------------------*/
225
227 cs_function_define_by_analytic_func(const char *name,
228  int location_id,
229  int dim,
230  bool is_intensive,
231  cs_analytic_func_t *data_func,
232  void *data_input);
233
234 /*----------------------------------------------------------------------------*/
254 /*----------------------------------------------------------------------------*/
255
257 cs_function_define_by_dof_func(const char *name,
258  int location_id,
259  int dim,
260  bool is_intensive,
261  cs_dof_func_t *data_func,
262  void *data_input);
263
264 /*----------------------------------------------------------------------------
265  * Destroy all function management metadata.
266  *----------------------------------------------------------------------------*/
267
268 void
270
271 /*----------------------------------------------------------------------------*/
277 /*----------------------------------------------------------------------------*/
278
279 int
281
282 /*----------------------------------------------------------------------------*/
292 /*----------------------------------------------------------------------------*/
293
295 cs_function_by_id(int id);
296
297 /*----------------------------------------------------------------------------*/
307 /*----------------------------------------------------------------------------*/
308
310 cs_function_by_name(const char *name);
311
312 /*----------------------------------------------------------------------------*/
322 /*----------------------------------------------------------------------------*/
323
325 cs_function_by_name_try(const char *name);
326
327 /*----------------------------------------------------------------------------*/
334 /*----------------------------------------------------------------------------*/
335
336 void
338  const char *label);
339
340 /*----------------------------------------------------------------------------*/
344 /*----------------------------------------------------------------------------*/
345
346 void
348
349 /*----------------------------------------------------------------------------*/
354 /*----------------------------------------------------------------------------*/
355
356 void
358
359 /*----------------------------------------------------------------------------*/
376 /*----------------------------------------------------------------------------*/
377
378 void
380  const cs_time_step_t *ts,
381  int location_id,
382  cs_lnum_t n_elts,
383  const cs_lnum_t *elt_ids,
384  void *vals);
385
386 /*----------------------------------------------------------------------------*/
387
389
390 #endif /* __CS_FUNCTION_H__ */
cs_datatype_t
Definition: cs_defs.h:272
Definition: cs_defs.h:514
Definition: cs_defs.h:515
Definition: cs_defs.h:313
cs_function_t * cs_function_define_by_func(const char *name, int location_id, int dim, bool is_intensive, cs_datatype_t datatype, cs_eval_at_location_t *data_func, void *data_input)
Define a function whose data values will be computed using the provided evaluation function.
Definition: cs_function.c:303
void() cs_eval_at_location_t(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Function pointer for evaluation of local function values.
Definition: cs_function.h:112
cs_function_t * cs_function_define_by_analytic_func(const char *name, int location_id, int dim, bool is_intensive, cs_analytic_func_t *data_func, void *data_input)
Define a function whose data values will be computed using the provided "degree of freedom" type eval...
Definition: cs_function.c:346
cs_function_t * cs_function_by_name_try(const char *name)
Return a pointer to a function object based on its name if present.
Definition: cs_function.c:511
void cs_function_set_label(cs_function_t *f, const char *label)
Assig a label to a function object.
Definition: cs_function.c:531
cs_function_t * cs_function_by_name(const char *name)
Return a pointer to a function object based on its name.
Definition: cs_function.c:485
void cs_function_log_defs(void)
Log function definition setup information.
Definition: cs_function.c:545
void cs_function_evaluate(const cs_function_t *f, const cs_time_step_t *ts, int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *vals)
Evaluate function values.
Definition: cs_function.c:787
void cs_function_log_all_settings(void)
Print info relative to all given function object settings to log file.
Definition: cs_function.c:693
cs_function_t * cs_function_define_by_dof_func(const char *name, int location_id, int dim, bool is_intensive, cs_dof_func_t *data_func, void *data_input)
Definition: cs_function.c:388
cs_function_t * cs_function_by_id(int id)
Return a pointer to a function object based on its id.
Definition: cs_function.c:461
int cs_function_n_functions(void)
Return the number of defined functions.
Definition: cs_function.c:443
void cs_function_destroy_all(void)
Destroy all functions management metadata.
Definition: cs_function.c:414
void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
Definition: cs_param_types.h:154
cs_restart_file_t
Definition: cs_restart_default.h:54
char * label
Definition: keywords.h:58
Definition: cs_function.h:121
cs_dof_func_t * dof_func
Definition: cs_function.h:157
const cs_datatype_t datatype
Definition: cs_function.h:135
int log
Definition: cs_function.h:141
cs_eval_at_location_t * eval_func
Definition: cs_function.h:153
const int id
Definition: cs_function.h:127
int post_vis
Definition: cs_function.h:137
const char * name
Definition: cs_function.h:123
cs_restart_file_t restart_file
Definition: cs_function.h:148
int type
Definition: cs_function.h:128
char * label
Definition: cs_function.h:124
Definition: cs_function.h:133
int time_stamp
Definition: cs_function.h:145
cs_analytic_func_t * analytic_func
Definition: cs_function.h:155
void * func_input
Definition: cs_function.h:160
const int dim
Definition: cs_function.h:130
time step descriptor
Definition: cs_time_step.h:64
