1 #ifndef __CS_CDOFB_VECTEQ_H__
2 #define __CS_CDOFB_VECTEQ_H__
119 const short int _off = 3*cm->
n_fc;
120 csys->
rhs[_off ] += coef * csys->
source[_off ];
121 csys->
rhs[_off + 1] += coef * csys->
source[_off + 1];
122 csys->
rhs[_off + 2] += coef * csys->
source[_off + 2];
305 const cs_cdofb_vecteq_t *eqc,
332 const cs_cdofb_vecteq_t *eqc,
356 cs_cdofb_vecteq_t *eqc,
357 cs_cdo_assembly_t *asb);
374 cs_cdofb_vecteq_t *eqc,
527 void *scheme_context);
543 void *scheme_context);
cs_real_t * cs_cdofb_vecteq_get_cell_values(void *context, bool previous)
Get the computed values at mesh cells from the inverse operation w.r.t. the static condensation (DoF ...
Definition: cs_cdofb_vecteq.c:2158
void cs_cdofb_vecteq_init_sharing(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Allocate work buffer and general structures related to CDO vector-valued face-based schemes....
Definition: cs_cdofb_vecteq.c:1486
void cs_cdofb_vecteq_assembly(const cs_cell_sys_t *csys, cs_cdo_system_block_t *block, cs_real_t *rhs, cs_cdofb_vecteq_t *eqc, cs_cdo_assembly_t *asb)
Perform the assembly stage for a vector-valued system obtained with CDO-Fb scheme.
Definition: cs_cdofb_vecteq.c:666
void cs_cdofb_vecteq_update_cell_fields(cs_timer_counter_t *tce, cs_field_t *fld, cs_cdofb_vecteq_t *eqc, bool cur2prev)
Update the variables associated to cells in case of a CDO-Fb scheme. This has to be done after a reso...
Definition: cs_cdofb_vecteq.c:715
static void cs_cdofb_vecteq_sourceterm(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_real_t t_eval, const cs_real_t coef, cs_hodge_t *mass_hodge, cs_cell_builder_t *cb, cs_equation_builder_t *eqb, cs_cell_sys_t *csys)
Compute the source term for a vector-valued CDO-Fb scheme and add it to the local rhs Mass matrix is ...
Definition: cs_cdofb_vecteq.h:94
void cs_cdofb_vecteq_init_cell_system(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_real_t val_f_n[], const cs_real_t val_c_n[], const cs_real_t val_f_nm1[], const cs_real_t val_c_nm1[], cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Initialize the local structure for the current cell The algebraic system for time t^{n+1} is going to...
Definition: cs_cdofb_vecteq.c:337
void cs_cdofb_vecteq_conv_diff_reac(const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_cdofb_vecteq_t *eqc, const cs_cell_mesh_t *cm, cs_hodge_t *mass_hodge, cs_hodge_t *diff_hodge, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Build the local matrices arising from the convection, diffusion, reaction terms in vector-valued CDO-...
Definition: cs_cdofb_vecteq.c:507
void cs_cdofb_vecteq_finalize_sharing(void)
Free work buffer and general structure related to CDO face-based schemes.
Definition: cs_cdofb_vecteq.c:1564
void cs_cdofb_vecteq_read_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Definition: cs_cdofb_vecteq.c:2216
bool cs_cdofb_vecteq_is_initialized(void)
Check if the generic structures for building a CDO-Fb scheme are allocated.
Definition: cs_cdofb_vecteq.c:1465
void cs_cdofb_vecteq_solve_steady_state(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build and solve the linear system arising from a vector steady-state diffusion equation with a CDO-Fb...
Definition: cs_cdofb_vecteq.c:754
void cs_cdofb_vecteq_write_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Definition: cs_cdofb_vecteq.c:2304
void cs_cdofb_vecteq_solve_implicit(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build and solve the linear system arising from a vector diffusion equation with a CDO-Fb scheme and a...
Definition: cs_cdofb_vecteq.c:954
void * cs_cdofb_vecteq_free_context(void *data)
Destroy a cs_cdofb_vecteq_t structure.
Definition: cs_cdofb_vecteq.c:1896
void cs_cdofb_vecteq_extra_post(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_cdofb_vecteq.c:2097
void cs_cdofb_vecteq_init_values(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the initial values of the variable field taking into account the boundary conditions....
Definition: cs_cdofb_vecteq.c:1935
void cs_cdofb_vecteq_diffusion(const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_cdofb_vecteq_t *eqc, const cs_cell_mesh_t *cm, cs_hodge_t *diff_hodge, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Build the local matrices arising from the diffusion term in the vector-valued CDO-Fb schemes.
Definition: cs_cdofb_vecteq.c:439
void cs_cdofb_vecteq_setup(cs_real_t t_eval, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb)
Set the boundary conditions known from the settings Define an indirection array for the enforcement o...
Definition: cs_cdofb_vecteq.c:289
void cs_cdofb_vecteq_current_to_previous(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Operate a current to previous operation for the field associated to this equation and potentially for...
Definition: cs_cdofb_vecteq.c:2066
void cs_cdofb_vecteq_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb)
Definition: cs_cdofb_vecteq.c:1547
cs_real_t * cs_cdofb_vecteq_get_face_values(void *context, bool previous)
Retrieve an array of values at mesh faces for the current context. The lifecycle of this array is man...
Definition: cs_cdofb_vecteq.c:2188
void * cs_cdofb_vecteq_init_context(const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a cs_cdofb_vecteq_t structure storing data useful for building and managing such a scheme.
Definition: cs_cdofb_vecteq.c:1600
void cs_cdofb_vecteq_solve_theta(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_cdofb_vecteq.c:1190
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
Definition: cs_restart.h:95
void cs_source_term_compute_cellwise(const int n_source_terms, cs_xdef_t *const *source_terms, const cs_cell_mesh_t *cm, const cs_mask_t *source_mask, cs_source_term_cellwise_t *compute_source[], cs_real_t time_eval, void *input, cs_cell_builder_t *cb, cs_real_t *result)
Compute the local contributions of source terms in a cell.
Definition: cs_source_term.c:1000
Definition: cs_cdofb_priv.h:51
cs_hodge_t ** mass_hodge
Definition: cs_cdofb_priv.h:104
Definition: cs_cdo_quantities.h:137
Definition: cs_cdo_system.h:335
Definition: cs_cdo_local.h:60
short int n_fc
Definition: cs_cdo_local.h:238
double * source
Definition: cs_cdo_local.h:157
double * rhs
Definition: cs_cdo_local.h:156
int n_dofs
Definition: cs_cdo_local.h:151
cs_xdef_t ** source_terms
Definition: cs_equation_param.h:709
int n_source_terms
Definition: cs_equation_param.h:708
Definition: cs_field.h:131
Definition: cs_hodge.h:183
time step descriptor
Definition: cs_time_step.h:64
Definition: cs_timer.h:55
Definition: cs_xdef.h:160
