8.1
cs_cdo_assembly.h File Reference
#include "cs_matrix.h"
#include "cs_matrix_assembler.h"
#include "cs_param_types.h"
#include "cs_range_set.h"
#include "cs_sdm.h"
+ Include dependency graph for cs_cdo_assembly.h:
Data Structures
struct  cs_cdo_assembly_row_t
struct  cs_cdo_assembly_t
Macros
#define CS_CDO_ASSEMBLY_BUFSIZE   200
Typedefs
typedef void() cs_cdo_assembly_func_t(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *eqa, cs_matrix_assembler_values_t *mav)
 Assemble a cellwise matrix into the global matrix Block or no block versions are handled. More...
void cs_cdo_assembly_setup_log (void)
 Print information for the setup.log file. More...
cs_cdo_assembly_t * cs_cdo_assembly_get (int t_id)
 Get a pointer to a cs_cdo_assembly_t structure related to a given thread. More...
void cs_cdo_assembly_init (int ddim, int edim, int n_cw_dofs)
 Allocate cs_cdo_assembly_t structure (shared among schemes). Each thread has its own copy this structure to enable a multithreaded assembly process. More...
void cs_cdo_assembly_finalize (void)
 Free matrix-related structures used during the simulation. Display overall statistic about the assembly stage for CDO schemes. More...
void cs_cdo_assembly_set_shift (cs_cdo_assembly_t *asb, cs_lnum_t l_row_shift, cs_lnum_t l_col_shift)
 Set the current shift values to consider during the assembly stage. More...
void cs_cdo_assembly_matrix_scal_generic (const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
 Assemble a cellwise matrix into the global matrix. Rely on the generic cs_matrix_assembler_values_add_g() function. Case of scalar-valued matrices. More...
void cs_cdo_assembly_matrix_e33_generic (const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
 Assemble a cellwise matrix into the global matrix. Rely on the generic cs_matrix_assembler_values_add_g() function. Case of vector-valued matrices with an expanded 3x3 block. More...
void cs_cdo_assembly_matrix_seqt (const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
 Assemble a cellwise matrix into the global matrix. Scalar-valued case. Sequential and with openMP threading. More...
void cs_cdo_assembly_matrix_seqs (const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
 Assemble a cellwise matrix into the global matrix Scalar-valued case. Sequential and without openMP (single thread). More...
void cs_cdo_assembly_matrix_sys_seqs (const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
 Assemble a cellwise (no-block) matrix into the global matrix corresponding to a system of coupled equations. Scalar-valued case. Sequential and without openMP. Block matrices assembled from cellwise scalar-valued matrices. More...
void cs_cdo_assembly_matrix_sys_seqt (const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
 Assemble a cellwise (no-block) matrix into the global matrix corresponding to a system of coupled equations. Scalar-valued case. Sequential and with openMP. Block matrices assembled from cellwise scalar-valued matrices. More...
void cs_cdo_assembly_eblock33_matrix_seqs (const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
 Assemble a cellwise matrix into the global matrix Case of a block 3x3 entries. Expand each row. Sequential run without openMP threading. More...
void cs_cdo_assembly_eblock33_matrix_seqt (const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
 Assemble a cellwise matrix into the global matrix. Case of a block 3x3 entries. Expand each row. Sequential run with openMP threading. More...
void cs_cdo_assembly_block33_matrix_seqs (const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
 Assemble a cellwise matrix into the global matrix. Case of a block 3x3 entries. Expand each row. Sequential run without openMP threading. More...
void cs_cdo_assembly_block33_matrix_seqt (const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
void cs_cdo_assembly_eblock_matrix_seqs (const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
 Assemble a cellwise matrix into the global matrix Case of a block NxN entries. Expand each row. Sequential run without openMP threading. More...
void cs_cdo_assembly_eblock_matrix_seqt (const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
 Assemble a cellwise system into the global algebraic system. Case of a block NxN entries. Expand each row. Sequential run with openMP threading. More...
◆ CS_CDO_ASSEMBLY_BUFSIZE
Typedef Documentation
◆ cs_cdo_assembly_func_t
[in]mcellwise view of the algebraic system
[in]dof_idslocal DoF numbering
[in]rsetpointer to a cs_range_set_t structure
[in,out]eqapointer to an equation assembly structure
[in,out]mavpointer to a matrix assembler structure
◆ cs_cdo_assembly_block33_matrix_seqs()
void cs_cdo_assembly_block33_matrix_seqs ( const cs_sdm_t *  m,
const cs_lnum_t dof_ids,
const cs_range_set_t rset,
cs_cdo_assembly_t *  asb,
cs_matrix_assembler_values_t mav
[in,out]asbpointer to an equation assembly structure
◆ cs_cdo_assembly_block33_matrix_seqt()
void cs_cdo_assembly_block33_matrix_seqt ( const cs_sdm_t *  m,
◆ cs_cdo_assembly_eblock33_matrix_seqs()
void cs_cdo_assembly_eblock33_matrix_seqs ( const cs_sdm_t *  m,
◆ cs_cdo_assembly_eblock33_matrix_seqt()
void cs_cdo_assembly_eblock33_matrix_seqt ( const cs_sdm_t *  m,
◆ cs_cdo_assembly_eblock_matrix_seqs()
void cs_cdo_assembly_eblock_matrix_seqs ( const cs_sdm_t *  m,
◆ cs_cdo_assembly_eblock_matrix_seqt()
void cs_cdo_assembly_eblock_matrix_seqt ( const cs_sdm_t *  m,
◆ cs_cdo_assembly_finalize()
void cs_cdo_assembly_finalize ( void  )
◆ cs_cdo_assembly_get()
cs_cdo_assembly_t* cs_cdo_assembly_get ( int  t_id)
[in]t_idid in the array of pointer
◆ cs_cdo_assembly_init()
void cs_cdo_assembly_init ( int  ddim,
int  edim,
int  n_cw_dofs
[in]ddimmax number of dof values on the diagonal part
[in]edimmax number of dof values on the extra-diag. part
[in]n_cw_dofsmax number of DoFs in a cell
◆ cs_cdo_assembly_matrix_e33_generic()
void cs_cdo_assembly_matrix_e33_generic ( const cs_sdm_t *  m,
[in,out]asbpointer to a matrix assembler buffers
◆ cs_cdo_assembly_matrix_scal_generic()
void cs_cdo_assembly_matrix_scal_generic ( const cs_sdm_t *  m,
◆ cs_cdo_assembly_matrix_seqs()
void cs_cdo_assembly_matrix_seqs ( const cs_sdm_t *  m,
◆ cs_cdo_assembly_matrix_seqt()
void cs_cdo_assembly_matrix_seqt ( const cs_sdm_t *  m,
◆ cs_cdo_assembly_matrix_sys_seqs()
void cs_cdo_assembly_matrix_sys_seqs ( const cs_sdm_t *  m,
◆ cs_cdo_assembly_matrix_sys_seqt()
void cs_cdo_assembly_matrix_sys_seqt ( const cs_sdm_t *  m,
◆ cs_cdo_assembly_set_shift()
void cs_cdo_assembly_set_shift ( cs_cdo_assembly_t *  asb,
[in,out]asbpointer to a cs_cdo_assembly_t to update
[in]l_row_shiftshift to apply to local row ids
[in]l_col_shiftshift to apply to local col ids
a function pointer cs_cdo_assembly_func_t
◆ cs_cdo_assembly_setup_log()
void cs_cdo_assembly_setup_log ( void  )
