8.1
cs_cdofb_monolithic.h File Reference
#include "cs_cdo_connect.h"
#include "cs_equation.h"
#include "cs_navsto_param.h"
#include "cs_time_step.h"
+ Include dependency graph for cs_cdofb_monolithic.h:
static cs_real_tcs_cdofb_monolithic_get_face_velocity (bool previous)
 Retrieve the values of the velocity on the faces. More...
void cs_cdofb_monolithic_init_sharing (const cs_navsto_param_t *nsp, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
void cs_cdofb_monolithic_finalize_common (const cs_navsto_param_t *nsp)
 Free shared pointers with lifecycle dedicated to this file. More...
void * cs_cdofb_monolithic_init_scheme_context (const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *bf_type, void *cc_context)
 Initialize a cs_cdofb_monolithic_t structure. More...
void * cs_cdofb_monolithic_free_scheme_context (void *scheme_context)
 Destroy a cs_cdofb_monolithic_t structure. More...
void cs_cdofb_monolithic_steady (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
 Solve the steady Navier-Stokes system with a CDO face-based scheme using a monolithic approach. More...
void cs_cdofb_monolithic_steady_nl (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
 Solve the steady Navier-Stokes system with a CDO face-based scheme using a monolithic approach and Picard iterations to solve the non-linearities arising from the advection term. More...
void cs_cdofb_monolithic (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
 Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a monolithic approach. According to the settings, this function can handle either an implicit Euler time scheme or more generally a theta time scheme. More...
void cs_cdofb_monolithic_nl (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
 Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a monolithic approach. According to the settings, this function can handle either an implicit Euler time scheme or more generally a theta time scheme. Rely on Picard iterations to solve the non-linearities arising from the advection term. More...
◆ cs_cdofb_monolithic()
void cs_cdofb_monolithic ( const cs_mesh_t mesh,
const cs_navsto_param_t nsp,
void *  scheme_context
[in]scheme_contextpointer to a structure cast on-the-fly
◆ cs_cdofb_monolithic_finalize_common()
void cs_cdofb_monolithic_finalize_common ( const cs_navsto_param_t nsp)
[in]nsppointer to NavSto parameter settings
◆ cs_cdofb_monolithic_free_scheme_context()
void* cs_cdofb_monolithic_free_scheme_context ( void *  scheme_context)
[in]scheme_contextpointer to a scheme context structure to free
a NULL pointer
◆ cs_cdofb_monolithic_get_face_velocity()
static cs_real_t* cs_cdofb_monolithic_get_face_velocity ( bool  previous)
inlinestatic
a pointer to an array of cs_real_t
◆ cs_cdofb_monolithic_init_scheme_context()
void* cs_cdofb_monolithic_init_scheme_context ( const cs_navsto_param_t nsp,
cs_adv_field_t adv_field,
cs_real_t mflux,
cs_real_t mflux_pre,
cs_boundary_type_t bf_type,
void *  cc_context
[in]mfluxcurrent values of the mass flux across primal faces
[in]mflux_precurrent values of the mass flux across primal faces
[in]bf_typetype of boundary for each boundary face
[in]cc_contextpointer to a cs_navsto_monolithic_t structure
a pointer to a new allocated cs_cdofb_monolithic_t structure
◆ cs_cdofb_monolithic_init_sharing()
void cs_cdofb_monolithic_init_sharing ( const cs_navsto_param_t nsp,
const cs_time_step_t time_step
◆ cs_cdofb_monolithic_nl()
void cs_cdofb_monolithic_nl ( const cs_mesh_t mesh,
[in,out]scheme_contextpointer to a structure cast on-the-fly
◆ cs_cdofb_monolithic_steady()
void cs_cdofb_monolithic_steady ( const cs_mesh_t mesh,
◆ cs_cdofb_monolithic_steady_nl()
void cs_cdofb_monolithic_steady_nl ( const cs_mesh_t mesh,
