1 #ifndef __CS_CDOFB_MONOLITHIC_H__
2 #define __CS_CDOFB_MONOLITHIC_H__
167 void *scheme_context);
184 void *scheme_context);
202 void *scheme_context);
222 void *scheme_context);
int cs_boundary_type_t
Definition: cs_boundary.h:69
void cs_cdofb_monolithic_finalize_common(const cs_navsto_param_t *nsp)
Free shared pointers with lifecycle dedicated to this file.
Definition: cs_cdofb_monolithic.c:1897
void cs_cdofb_monolithic_nl(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a monolithic approach....
Definition: cs_cdofb_monolithic.c:2912
void cs_cdofb_monolithic_init_sharing(const cs_navsto_param_t *nsp, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Definition: cs_cdofb_monolithic.c:1842
void cs_cdofb_monolithic(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Definition: cs_cdofb_monolithic.c:2790
static cs_real_t * cs_cdofb_monolithic_get_face_velocity(bool previous)
Retrieve the values of the velocity on the faces.
Definition: cs_cdofb_monolithic.h:77
void cs_cdofb_monolithic_steady(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Solve the steady Navier-Stokes system with a CDO face-based scheme using a monolithic approach.
Definition: cs_cdofb_monolithic.c:2466
void * cs_cdofb_monolithic_free_scheme_context(void *scheme_context)
Destroy a cs_cdofb_monolithic_t structure.
Definition: cs_cdofb_monolithic.c:2424
void * cs_cdofb_monolithic_init_scheme_context(const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *bf_type, void *cc_context)
Initialize a cs_cdofb_monolithic_t structure.
Definition: cs_cdofb_monolithic.c:1941
void cs_cdofb_monolithic_steady_nl(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Solve the steady Navier-Stokes system with a CDO face-based scheme using a monolithic approach and Pi...
Definition: cs_cdofb_monolithic.c:2585
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
cs_equation_t * cs_equation_by_name(const char *eqname)
Find the cs_equation_t structure with name eqname Return NULL if not find.
Definition: cs_equation.c:516
cs_real_t * cs_equation_get_face_values(const cs_equation_t *eq, bool previous)
For a given equation, retrieve an array of values related to each face of the mesh for the unknowns.
Definition: cs_equation.c:3196
Definition: cs_advection_field.h:150
Definition: cs_cdo_quantities.h:137
Definition: cs_navsto_param.h:611
time step descriptor
Definition: cs_time_step.h:64
