Main structure storing the parameter settings. More...
#include <cs_equation_system_param.h>
Collaboration diagram for cs_equation_system_param_t:Data Fields | |
Generic metadata | |
| char *restrict | name |
| int | verbosity |
| cs_param_space_scheme_t | space_scheme |
| int | block_var_dim |
Linear algebra (SLES) | |
| bool | sles_setup_done |
| cs_equation_system_sles_strategy_t | sles_strategy |
| cs_param_sles_cvg_t | linear_solver_cvg |
| block_var_dim |
Dimension of the variable in each block
| cs_param_sles_cvg_t linear_solver_cvg |
| name |
Name of the system of equations
| sles_setup_done |
Indicator to know if the setup stage has be done
| sles_strategy |
Type of strategy used to solve the resulting system
| space_scheme |
Associated space discretization. One assumes that all blocks share the same space discretization.
| verbosity |
Level of verbosity (quantity of output information)
