8.0
cs_equation_system_param.h
1 #ifndef __CS_EQUATION_SYSTEM_PARAM_H__
2 #define __CS_EQUATION_SYSTEM_PARAM_H__
5  * Functions to handle a set of coupled equations hinging on the cs_equation_t
6  * structure
8
9 /*
10  This file is part of code_saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2023 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
29 /*----------------------------------------------------------------------------
30  * Local headers
31  *----------------------------------------------------------------------------*/
32
33 #include "cs_equation_param.h"
34 #include "cs_iter_algo.h"
35 #include "cs_param_sles.h"
36 #include "cs_param_types.h"
43  * Macro definitions
45
47  * Type definitions
49
60 typedef enum {
61
63
65
67
72 typedef struct {
73
92  char *restrict name;
93
94  int verbosity;
95
97
99
116
118
120
126
127
154 typedef enum {
155
162
164
166
167 /*============================================================================
168  * Public function prototypes
169  *============================================================================*/
170 /*----------------------------------------------------------------------------*/
179 /*----------------------------------------------------------------------------*/
180
182 cs_equation_system_param_create(const char *name,
183  int block_var_dim);
184
185 /*----------------------------------------------------------------------------*/
193 /*----------------------------------------------------------------------------*/
194
197
198 /*----------------------------------------------------------------------------*/
204 /*----------------------------------------------------------------------------*/
205
206 void
208
209 /*----------------------------------------------------------------------------*/
218 /*----------------------------------------------------------------------------*/
219
220 void
223  const char *keyval);
224
225 /*----------------------------------------------------------------------------*/
226
228
229 #endif /* __CS_EQUATION_SYSTEM_PARAM_H__ */
#define restrict
Definition: cs_defs.h:139
Definition: cs_defs.h:509
cs_equation_system_param_t * cs_equation_system_param_create(const char *name, int block_var_dim)
Create and initialize a new cs_equation_system_param_t structure.
Definition: cs_equation_system_param.c:91
cs_equation_system_key_t
List of available keys for setting the parameters of a system of equations.
Definition: cs_equation_system_param.h:154
@ CS_SYSKEY_LINEAR_SOLVER_ATOL
Definition: cs_equation_system_param.h:156
@ CS_SYSKEY_N_KEYS
Definition: cs_equation_system_param.h:163
@ CS_SYSKEY_LINEAR_SOLVER_DTOL
Definition: cs_equation_system_param.h:157
@ CS_SYSKEY_LINEAR_SOLVER_RTOL
Definition: cs_equation_system_param.h:158
@ CS_SYSKEY_SLES_STRATEGY
Definition: cs_equation_system_param.h:160
@ CS_SYSKEY_LINEAR_SOLVER_MAX_ITER
Definition: cs_equation_system_param.h:159
@ CS_SYSKEY_VERBOSITY
Definition: cs_equation_system_param.h:161
cs_equation_system_sles_strategy_t
High-level information about the way of solving the system of equations.
Definition: cs_equation_system_param.h:60
@ CS_EQUATION_SYSTEM_N_SLES_TYPES
Definition: cs_equation_system_param.h:64
@ CS_EQUATION_SYSTEM_SLES_MUMPS
Definition: cs_equation_system_param.h:62
void cs_equation_system_param_set(cs_equation_system_param_t *sysp, cs_equation_system_key_t key, const char *keyval)
Set a parameter related to a keyname in a cs_equation_system_param_t structure.
Definition: cs_equation_system_param.c:207
void cs_equation_system_param_log(const cs_equation_system_param_t *sysp)
Log the setup gathered in the structure cs_equation_system_param_t.
Definition: cs_equation_system_param.c:160
cs_equation_system_param_t * cs_equation_system_param_free(cs_equation_system_param_t *sysp)
Free a cs_equation_system_param_t structure.
Definition: cs_equation_system_param.c:139
Structure and routines handling the SLES settings stored inside a cs_param_sles_t structure.
cs_param_space_scheme_t
Definition: cs_param_types.h:211
Main structure storing the parameter settings.
Definition: cs_equation_system_param.h:72
bool sles_setup_done
Definition: cs_equation_system_param.h:115
int block_var_dim
Definition: cs_equation_system_param.h:98
cs_equation_system_sles_strategy_t sles_strategy
Definition: cs_equation_system_param.h:117
int verbosity
Definition: cs_equation_system_param.h:94
char *restrict name
Definition: cs_equation_system_param.h:92
cs_param_sles_cvg_t linear_solver_cvg
Definition: cs_equation_system_param.h:119
cs_param_space_scheme_t space_scheme
Definition: cs_equation_system_param.h:96
Set of parameters to check the convergence (or the divergence) of an iterative process (tolerances or...
Definition: cs_param_sles.h:61
