#include "cs_timer.h"
#include "fvm_defs.h"
#include "fvm_nodal.h"
#include "fvm_writer.h"
typedef int() | fvm_writer_n_version_strings_t(void) |
typedef const char *() | fvm_writer_version_string_t(int string_index, int compile_time_version) |
typedef void *() | fvm_writer_init_t(const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency) |
typedef void *() | fvm_writer_finalize_t(void *this_writer) |
typedef void() | fvm_writer_set_mesh_time_t(void *this_writer, int time_step, double time_value) |
typedef int() | fvm_writer_needs_tesselation_t(void *this_writer, const fvm_nodal_t *mesh, fvm_element_t element_type) |
typedef void() | fvm_writer_export_nodal_t(void *this_writer, const fvm_nodal_t *mesh) |
typedef void() | fvm_writer_export_field_t(void *this_writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[]) |
typedef void() | fvm_writer_flush_t(void *this_writer) |
◆ FVM_WRITER_FORMAT_HAS_POLYGON
#define FVM_WRITER_FORMAT_HAS_POLYGON (1 << 1) |
◆ FVM_WRITER_FORMAT_HAS_POLYHEDRON
#define FVM_WRITER_FORMAT_HAS_POLYHEDRON (1 << 2) |
◆ FVM_WRITER_FORMAT_NAME_IS_OPTIONAL
#define FVM_WRITER_FORMAT_NAME_IS_OPTIONAL (1 << 5) |
◆ FVM_WRITER_FORMAT_NO_SEPARATE_MESHES
#define FVM_WRITER_FORMAT_NO_SEPARATE_MESHES (1 << 4) |
◆ FVM_WRITER_FORMAT_SEPARATE_MESHES
#define FVM_WRITER_FORMAT_SEPARATE_MESHES (1 << 3) |
◆ FVM_WRITER_FORMAT_USE_EXTERNAL
#define FVM_WRITER_FORMAT_USE_EXTERNAL (1 << 0) |
◆ fvm_writer_export_field_t
typedef void() fvm_writer_export_field_t(void *this_writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[]) |
◆ fvm_writer_export_nodal_t
typedef void() fvm_writer_export_nodal_t(void *this_writer, const fvm_nodal_t *mesh) |
◆ fvm_writer_finalize_t
typedef void*() fvm_writer_finalize_t(void *this_writer) |
◆ fvm_writer_flush_t
typedef void() fvm_writer_flush_t(void *this_writer) |
◆ fvm_writer_init_t
typedef void*() fvm_writer_init_t(const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency) |
◆ fvm_writer_n_version_strings_t
typedef int() fvm_writer_n_version_strings_t(void) |
◆ fvm_writer_needs_tesselation_t
typedef int() fvm_writer_needs_tesselation_t(void *this_writer, const fvm_nodal_t *mesh, fvm_element_t element_type) |
◆ fvm_writer_set_mesh_time_t
typedef void() fvm_writer_set_mesh_time_t(void *this_writer, int time_step, double time_value) |
◆ fvm_writer_version_string_t
typedef const char*() fvm_writer_version_string_t(int string_index, int compile_time_version) |
