Boundary conditions
Lagrangian boundary conditions are based on boundary zone (cs_boundary_zone_t) definitions. Additional information may be provided for Lagrangian boundary types and injections.
As usual, definitions may be created using the GUI and extended with user functions.
Access to the Lagrangian boundary conditions structure, which is necessary to most of the following examples, may be done as follows:
cs_lagr_zone_data_t * cs_lagr_get_boundary_conditions(void)
Return pointer to the main boundary conditions structure.
Definition: cs_lagr.c:1665
Definition: cs_lagr.h:726
Boundary zones
In this example, we assign rebound conditions to all boundary zones, except for an inlet and outlet type to specified zones. The type assigned is an integer based on the cs_lagr_bc_type_t enumerator type.
for (int z_id = 0; z_id < n_zones; z_id++) {
int cs_boundary_zone_n_zones(void)
Return number of boundary zones defined.
Definition: cs_boundary_zone.c:426
@ CS_LAGR_OUTLET
Definition: cs_lagr.h:88
@ CS_LAGR_INLET
Definition: cs_lagr.h:87
@ CS_LAGR_REBOUND
Definition: cs_lagr.h:89
int * zone_type
Definition: cs_lagr.h:731
int id
Definition: cs_zone.h:59
Injection sets
In the following example, a first injection set for an inlet zone is defined. Note that newly injected particles may also be modified using the cs_user_lagr_in function.
int set_id = 0;
cs_lagr_injection_set_t * cs_lagr_get_injection_set(cs_lagr_zone_data_t *zone_data, int zone_id, int set_id)
Provide access to injection set structure.
Definition: cs_lagr.c:1306
cs_lagr_model_t * cs_glob_lagr_model
cs_lagr_specific_physics_t * cs_glob_lagr_specific_physics
Definition: cs_lagr.h:560
cs_real_t diameter_variance
Definition: cs_lagr.h:604
cs_real_t density
Definition: cs_lagr.h:620
int injection_frequency
Definition: cs_lagr.h:569
int temperature_profile
Definition: cs_lagr.h:587
cs_real_t velocity_magnitude
Definition: cs_lagr.h:598
int velocity_profile
Definition: cs_lagr.h:582
cs_real_t cp
Definition: cs_lagr.h:624
cs_real_t diameter
Definition: cs_lagr.h:603
cs_gnum_t n_inject
Definition: cs_lagr.h:566
int cluster
Definition: cs_lagr.h:593
cs_real_t fouling_index
Definition: cs_lagr.h:622
cs_real_t flow_rate
Definition: cs_lagr.h:628
cs_real_t emissivity
Definition: cs_lagr.h:630
cs_real_t stat_weight
Definition: cs_lagr.h:626
cs_real_t temperature
Definition: cs_lagr.h:601
int n_stat_classes
Definition: cs_lagr.h:335
int itpvar
Definition: cs_lagr.h:411
In the next example, a profile is assigned to the second injection set of an inlet zone (it is assumed this et was previously defined either through the GUI or user function).
This requires first defining a profile definition function, matching the profile of cs_lagr_injection_profile_compute_t. An example based on experimental profiles is given here:
static void
_injection_profile(int zone_id,
int location_id,
const void *input,
const int itmx = 8;
cs_real_t zi[] = {0.e-3, 1.e-3, 1.5e-3, 2.0e-3, 2.5e-3, 3.0e-3, 3.5e-3,
4.0e-3, 4.5e-3, 5.0e-3};
cs_real_t lvf[] = {0.377e-4, 2.236e-4, 3.014e-4, 4.306e-4, 5.689e-4,
8.567e-4, 7.099e-4, 4.520e-4, 2.184e-4, 0.377e-4};
cs_real_t ui[] = {5.544, 8.827, 9.068, 9.169, 8.923, 8.295, 7.151, 6.048,
4.785, 5.544};
const cs_real_t z = b_face_coords[face_id][2];
int i = 0;
if (z > zi[0]) {
for (i = 0; i < itmx; i++) {
if (z >= zi[i] && z < zi[i+1])
break;
cs_real_t up = ui[i] +(z-zi[i])*(ui[i+1]-ui[i])/(zi[i+1]-zi[i]);
cs_real_t lvfp = lvf[i] + (z-zi[i])*(lvf[i+1]-lvf[i])/(zi[i+1]-zi[i]);
profile[ei] = lvfp * up;
Definition: cs_defs.h:319
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:332
Definition: cs_defs.h:313
cs_real_t * b_face_cog
Definition: cs_mesh_quantities.h:111
Assigning the profile to the injection set simply requires assigning the function to the pointer in the injection set structure:
int set_id = 1;
cs_lagr_injection_profile_compute_t * injection_profile_func
Definition: cs_lagr.h:573
void * injection_profile_input
Definition: cs_lagr.h:576
An optional user-defined input function may also be associated.
Boundary-particle interactions
It is also possible to decide of the behavior of particle when they encounter a boundary (this boundary has to be of type CS_LAGR_BC_USER).
In the following example, the particle is simply deposited and marked for elimination:
# pragma omp atomic
particles->n_part_dep += 1;
# pragma omp atomic
p_id,
for (
int k = 0;
k < 3;
k++)
particle_coord[
k] = c_intersect[
k];
@ k
#define CS_EVENT_OUTFLOW
Definition: cs_lagr_event.h:56
#define CS_EVENT_DEPOSITION
Definition: cs_lagr_event.h:62
@ CS_LAGR_STAT_WEIGHT
Definition: cs_lagr_particle.h:90
@ CS_LAGR_COORDS
Definition: cs_lagr_particle.h:95
static void cs_lagr_particles_set_flag(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int mask)
Set flag value with a selected mask for a given particle in a set.
Definition: cs_lagr_particle.h:538
static void * cs_lagr_particles_attr(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get pointer to a current attribute of a given particle in a set.
Definition: cs_lagr_particle.h:412
#define CS_LAGR_PART_DEPOSITED
Definition: cs_lagr_particle.h:57
static cs_real_t cs_lagr_particles_get_real(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_real_t of a given particle in a set.
Definition: cs_lagr_particle.h:798
@ CS_LAGR_PART_OUT
Definition: cs_lagr_tracking.h:60
Volume conditions
Lagrangian volume conditions are based on volume zone (cs_volume_zone_t) definitions. Additional information may be provided for Lagrangian injections.
Access to the Lagrangian volume conditions structure, which is necessary to most of the following examples, may be done as follows:
cs_lagr_zone_data_t * cs_lagr_get_volume_conditions(void)
Return pointer to the main volume conditions structure.
Definition: cs_lagr.c:1689
Injection sets
In the following example, we inject 1 particle set at each time step:
int set_id = 0;
cs_lagr_agglomeration_model_t * cs_glob_lagr_agglomeration_model
const cs_zone_t * cs_volume_zone_by_name(const char *name)
Return a pointer to a volume zone based on its name if present.
Definition: cs_volume_zone.c:680
cs_real_t base_diameter
Definition: cs_lagr.h:514
int aggregat_class_id
Definition: cs_lagr.h:595
cs_real_t aggregat_fractal_dim
Definition: cs_lagr.h:596
int fragmentation
Definition: cs_lagr.h:333
int agglomeration
Definition: cs_lagr.h:329
for (int set_id = 0; set_id < 2; set_id++) {
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:298
const cs_zone_t * cs_volume_zone_by_id(int id)
Return a pointer to a volume zone based on its id.
Definition: cs_volume_zone.c:656
double precision, dimension(:,:,:), allocatable density
Definition: atimbr.f90:124
In the following example, we inject 2 particle sets at computation initialization (i.e. at the first time step of a computation sequence in which the Lagrangian module is activated). Note that newly injected particles may also be modified using the cs_user_lagr_in function.
External force
User definition of an external force field acting on the particles.
It must be prescribed in every cell and be homogeneous to gravity (m/s^2) By default gravity and drag force are the only forces acting on the particles (the gravity components gx gy gz are assigned in the GUI or in cs_user_parameters)
void
fextla[ip][0] = 0;
fextla[ip][1] = 0;
fextla[ip][2] = 0;
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:341
cs_lagr_particle_set_t * cs_lagr_get_particle_set(void)
Return pointer to the main cs_lagr_particle_set_t structure.
Definition: cs_lagr_particle.c:1153
void cs_user_lagr_ef(cs_real_t dt_p, const cs_real_t taup[], const cs_real_3_t tlag[], const cs_real_3_t piil[], const cs_real_33_t bx[], const cs_real_t tsfext[], const cs_real_33_t vagaus[], const cs_real_3_t gradpr[], const cs_real_33_t gradvf[], cs_real_t rho_p[], cs_real_3_t fextla[])
Definition: cs_user_lagr_particle.c:87
Definition: cs_lagr_particle.h:222
cs_lnum_t n_particles
Definition: cs_lagr_particle.h:224
Impose motion on a particle
Impose the motion of a particle flagged CS_LAGR_PART_IMPOSED_MOTION by modifying the particle position and its velocity.
void
disp[0] = 0.;
@ dt
void cs_user_lagr_imposed_motion(const cs_real_t coords[3], const cs_real_t dt, cs_real_t disp[3])
Impose the motion of a particle flagged CS_LAGR_PART_IMPOSED_MOTION.
Definition: cs_user_lagr_particle.c:146
double precision, dimension(ncharm), save omega
Definition: cpincl.f90:99
Modification of newly injected particles
User modification of newly injected particles.
This function is called after the initialization of the new particles in order to modify them according to new particle profiles (injection profiles, position of the injection point, statistical weights, correction of the diameter if the standard-deviation option is activated).
This function is called for each injection zone and set. Particles with ids between pset->n_particles and n_elts are initialized but may be modidied by this function.
void
for (
cs_lnum_t p_id = particle_range[0]; p_id < particle_range[1]; p_id++) {
part_vel[0] = 1.0;
part_vel[1] = 0.0;
part_vel[2] = 0.0;
attr_id++) {
*user_var = 0.;
if (particle_range[1] <= particle_range[0])
return;
for (
cs_lnum_t ip = particle_range[0]; ip < particle_range[1]; ip++) {
_inlet2(particles, ip);
int time_id = 1;
time_id = 0;
time_id,
visc_length);
cs_lagr_source_terms_t * cs_glob_lagr_source_terms
cs_lagr_time_scheme_t * cs_glob_lagr_time_scheme
void cs_lagr_new_particle_init(const cs_lnum_t particle_range[2], int time_id, const cs_real_t visc_length[])
Initialization for new particles.
Definition: cs_lagr_new.c:658
@ CS_LAGR_USER
Definition: cs_lagr_particle.h:177
@ CS_LAGR_VELOCITY
Definition: cs_lagr_particle.h:96
@ CS_LAGR_TEMPERATURE
Definition: cs_lagr_particle.h:147
@ CS_LAGR_DIAMETER
Definition: cs_lagr_particle.h:93
static void cs_lagr_particles_set_real(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr, cs_real_t value)
Set attribute value of type cs_real_t of a given particle in a set.
Definition: cs_lagr_particle.h:848
void cs_user_lagr_in(cs_lagr_particle_set_t *particles, const cs_lagr_injection_set_t *zis, const cs_lnum_t particle_range[2], const cs_lnum_t particle_face_id[], const cs_real_t visc_length[])
Definition: cs_user_lagr_particle.c:181
cs_lagr_stat_options_t * cs_glob_lagr_stat_options
int n_user_variables
Definition: cs_lagr.h:337
int nstits
Definition: cs_lagr.h:703
int nstist
Definition: cs_lagr_stat.h:213
int isttio
Definition: cs_lagr.h:210
int nt_cur
Definition: cs_time_step.h:74
Here is another example of the modification of newly injected particles:
int coal_id = 0;
cs_real_t initial_diameter = 0, shrinking_diameter = 0;
for (int l_id = 0; l_id < n_layers; l_id++) {
temperature[l_id] = 0;
coal_mass_fraction[l_id] = 0;
coke_density[l_id] = 0;
coke_mass_fraction[l_id] = 0;
coal_id = 0;
+ (1.0 - lagr_cc->
xwatch[coal_id] - lagr_cc->
xashch[coal_id])
* (1.0 - (lagr_cc->
y1ch[coal_id] + lagr_cc->
y2ch[coal_id]) / 2.0);
water_mass_f = 0.0;
temperature[l_id] = 800 - 273.15;
coal_mass_fraction[l_id] = 0.;
coke_density[l_id]
= (1.0 - lagr_cc->
xashch[coal_id])
* (1.0 - (lagr_cc->
coke_mass_fraction[l_id] = coke_density[l_id] /
density;
for (
water_mass_f * mass);
particle_temperature[l_id] = temperature[l_id];
particle_coal_mass[l_id] = coal_mass_fraction[l_id] * mass / n_layers;
particle_coke_mass[l_id] = coke_mass_fraction[l_id] * mass / n_layers;
particle_coal_density[l_id] = coke_density[l_id];
shrinking_diameter);
initial_diameter);
@ cp
Definition: cs_field_pointer.h:100
cs_lagr_coal_comb_t * cs_glob_lagr_coal_comb
@ CS_LAGR_COAL_DENSITY
Definition: cs_lagr_particle.h:161
@ CS_LAGR_MASS
Definition: cs_lagr_particle.h:92
@ CS_LAGR_COAL_MASS
Definition: cs_lagr_particle.h:154
@ CS_LAGR_COKE_MASS
Definition: cs_lagr_particle.h:155
@ CS_LAGR_CP
Definition: cs_lagr_particle.h:149
@ CS_LAGR_INITIAL_DIAMETER
Definition: cs_lagr_particle.h:158
@ CS_LAGR_SHRINKING_DIAMETER
Definition: cs_lagr_particle.h:157
@ CS_LAGR_WATER_MASS
Definition: cs_lagr_particle.h:153
const cs_real_t cs_math_pi
Definition: cs_lagr.h:1004
cs_real_t * xwatch
Definition: cs_lagr.h:1033
cs_real_t * y2ch
Definition: cs_lagr.h:1028
cs_real_t * xashch
Definition: cs_lagr.h:1034
cs_real_t * rho0ch
Definition: cs_lagr.h:1032
cs_real_t * cp2ch
Definition: cs_lagr.h:1029
cs_real_t * y1ch
Definition: cs_lagr.h:1027
int zone_id
Definition: cs_lagr.h:562
int set_id
Definition: cs_lagr.h:563
int n_temperature_layers
Definition: cs_lagr.h:275
