◆ cs_time_step_type_t
| Enumerator |
| CS_TIME_STEP_STEADY | Steady (SIMPLE) algorithm
| CS_TIME_STEP_CONSTANT | Unsteady (SIMPLEC) algorithm with constant time step
| CS_TIME_STEP_ADAPTIVE | Unsteady (SIMPLEC) algorithm with time-adaptive (varying) time step
| CS_TIME_STEP_LOCAL | Pseudo-steady with time-and-space varying time step (SIMPLEC)
◆ cs_get_glob_time_step()
Provide read/write access to cs_glob_time_step.
- Returns
- pointer to global time step structure
◆ cs_get_glob_time_step_options()
Provide read/write access to cs_glob_time_step_options.
- Returns
- pointer to global time step options structure
◆ cs_time_step_define_local()
| void cs_time_step_define_local |
int |
is_local | ) |
Define whether time step is local in space or not.
- Parameters
| [in] | is_local | 0 if time step is uniform in space, 1 if it is local |
◆ cs_time_step_define_nt_max()
| void cs_time_step_define_nt_max |
int |
nt_max | ) |
Define maximum time step number.
- Parameters
| [in] | nt_max | maximum time step number (unlimited if negative) |
◆ cs_time_step_define_prev()
| void cs_time_step_define_prev |
int |
nt_prev, |
double |
t_prev |
Set time values from previous (usually restarted) calculations.
- Parameters
| [in] | nt_prev | previous time step number |
| [in] | t_prev | previous physical time |
◆ cs_time_step_define_t_max()
| void cs_time_step_define_t_max |
double |
t_max | ) |
Define maximum time value.
- Parameters
| [in] | t_max | maximum time value (unlimited if negative) |
◆ cs_time_step_define_variable()
| void cs_time_step_define_variable |
int |
is_variable | ) |
Define whether time step is variable or not.
- Parameters
| [in] | is_variable | 0 if time step is variable in time, 1 if it is fixed |
◆ cs_time_step_increment()
| void cs_time_step_increment |
double |
dt | ) |
Increment the global time step.
- Parameters
| [in] | dt | time step value to increment |
◆ cs_time_step_log_setup()
| void cs_time_step_log_setup |
void |
Print the time stepping options to setup.log.
◆ cs_time_step_redefine_cur()
| void cs_time_step_redefine_cur |
int |
nt_cur, |
double |
t_cur |
Redefine the current time values.
- Parameters
| [in] | nt_cur | current time step number |
| [in] | t_cur | current physical time |
◆ cs_glob_time_step
◆ cs_glob_time_step_options
