#include <float.h>
#include <stdarg.h>
#include <mpi.h>
#include <ple_locator.h>
#include "cs_flag_check.h"
#include "cs_map.h"
#include "cs_mesh_location.h"
#include "cs_parameters.h"
#include "cs_boundary_zone.h"
void | cs_boundary_zone_initialize (void) |
Initialize boundary zone structures. More... | |
void | cs_boundary_zone_finalize (void) |
Free all boundary zone structures. More... | |
int | cs_boundary_zone_n_zones (void) |
Return number of boundary zones defined. More... | |
int | cs_boundary_zone_n_zones_time_varying (void) |
Return number of boundary zones which may vary in time. More... | |
void | cs_boundary_zone_build_private (int id) |
Update association of a given private boundary zone with a mesh. More... | |
void | cs_boundary_zone_build_all (bool mesh_modified) |
Update association of boundary zones with a mesh. More... | |
int | cs_boundary_zone_define (const char *name, const char *criteria, int type_flag) |
Define a new boundary zone using a selection criteria string. More... | |
int | cs_boundary_zone_define_by_func (const char *name, cs_mesh_location_select_t *func, void *input, int type_flag) |
Define a new mesh location with an associated selection function. More... | |
const cs_zone_t * | cs_boundary_zone_by_id (int id) |
Return a pointer to a boundary zone based on its id. More... | |
const cs_zone_t * | cs_boundary_zone_by_name (const char *name) |
Return a pointer to a boundary zone based on its name if present. More... | |
const cs_zone_t * | cs_boundary_zone_by_name_try (const char *name) |
int | cs_boundary_zone_id_by_name (const char *z_name) |
Retrieve the boundary zone id from its zone name. If the zone name is equal to NULL or has an empty length, then the default zone id (=0) corresponding to all entities is returned. More... | |
void | cs_boundary_zone_set_type (int id, int type_flag) |
Set type flag for a given boundary zone. More... | |
void | cs_boundary_zone_set_time_varying (int id, bool time_varying) |
Set time varying behavior for a given boundary zone. More... | |
void | cs_boundary_zone_set_overlay (int id, bool allow_overlay) |
Set overlay behavior for a given boundary zone. More... | |
const int * | cs_boundary_zone_face_zone_id (void) |
Return pointer to zone id associated with each boundary face. More... | |
void | cs_boundary_zone_log_info (const cs_zone_t *z) |
Print info relative to a given boundary zone to log file. More... | |
void | cs_boundary_zone_log_setup (void) |
Log setup information relative to defined boundary zones. More... | |
int | cs_boundary_zone_n_type_zones (int type_flag) |
Return number of boundary zones associated with a given zone flag. More... | |
int * | cs_boundary_zone_face_class_id (void) |
Get pointer to optional boundary face class ids. More... | |
void | cs_boundary_zone_update_face_class_id (void) |
Update boundary face output class ids if present. More... | |
const int * | cs_boundary_zone_face_class_or_zone_id (void) |
Get read pointer to optional boundary face class or zone ids. More... | |
int | cs_boundary_zone_max_class_or_zone_id (void) |
Return the maximum defined face class or zone id. More... | |
void | cs_boundary_zone_print_info (void) |
Print boundary zones information to listing file. More... | |
Boundary zone handling.
void cs_boundary_zone_build_all | ( | bool | mesh_modified | ) |
[in] | mesh_modified | indicate if mesh has been modified |
void cs_boundary_zone_build_private | ( | int | id | ) |
[in] | id | zone id |
const cs_zone_t* cs_boundary_zone_by_id | ( | int | id | ) |
This function requires that a boundary zone of the given id is defined.
const cs_zone_t* cs_boundary_zone_by_name | ( | const char * | name | ) |
This function requires that a boundary zone of the given name is defined.
[in] | name | boundary zone name |
const cs_zone_t* cs_boundary_zone_by_name_try | ( | const char * | name | ) |
If no boundary zone of the given name is defined, NULL is returned.
int cs_boundary_zone_define | ( | const char * | name, |
const char * | criteria, | ||
int | type_flag | ||
[in] | name | name of location to define |
[in] | criteria | selection criteria for associated elements |
[in] | type_flag | mask of zone category values |
int cs_boundary_zone_define_by_func | ( | const char * | name, |
cs_mesh_location_select_t * | func, | ||
void * | input, | ||
[in] | func | pointer to selection function for associated elements |
[in,out] | input | pointer to optional (untyped) value or structure. |
int* cs_boundary_zone_face_class_id | ( | void | ) |
For each boundary face, a specific output (logging and postprocessing) class id may be assigned. This allows realizing logging, postprocessing, or otherwise extracting data based on this class.
Using this function at a given point indicates that user-defined class ids will be used. The face class ids are initially equal to the face zone ids, but may be modified by the user.
In the presence of a time-varying mesh or boundary zones, the face class ids will be reset to the zone ids, so it may be necessary to update the user definitions.
The class id values are arbitrarily chosen by the user, but must be positive integers; numbers do not need to be contiguous, but very high numbers may also lead to higher memory consumption.
const int* cs_boundary_zone_face_class_or_zone_id | ( | void | ) |
If no face classes have been defined by cs_boundary_zone_face_class_id the boundary face zone id is returned instead.
const int* cs_boundary_zone_face_zone_id | ( | void | ) |
In case of overlayed zones, the highest zone id associated with a given face is given. Private (automatically defined) zones are excluded from this definition.
void cs_boundary_zone_finalize | ( | void | ) |
int cs_boundary_zone_id_by_name | ( | const char * | z_name | ) |
[in] | z_name | name of the zone or NULL or "" |
void cs_boundary_zone_initialize | ( | void | ) |
This defines a default boundary zone. This is the first function of the boundary zone handling functions which should be called, and it should only be called after cs_mesh_location_initialize.
void cs_boundary_zone_log_info | ( | const cs_zone_t * | z | ) |
[in] | z | pointer to boundary zone structure |
void cs_boundary_zone_log_setup | ( | void | ) |
int cs_boundary_zone_max_class_or_zone_id | ( | void | ) |
This value is valid only if cs_boundary_zone_update_face_class_id
int cs_boundary_zone_n_type_zones | ( | int | type_flag | ) |
Private (automatic) zones are excluded from this count.
[in] | type_flag | flag to compare to zone type |
int cs_boundary_zone_n_zones | ( | void | ) |
int cs_boundary_zone_n_zones_time_varying | ( | void | ) |
void cs_boundary_zone_print_info | ( | void | ) |
void cs_boundary_zone_set_overlay | ( | int | id, |
bool | allow_overlay | ||
[in] | id | boundary zone id |
[in] | allow_overlay | true if the zone may be overlayed by another |
void cs_boundary_zone_set_time_varying | ( | int | id, |
bool | time_varying | ||
[in] | time_varying | true if the zone's definition varies in time |
void cs_boundary_zone_set_type | ( | int | id, |
[in] | type_flag | volume zone type flag |
void cs_boundary_zone_update_face_class_id | ( | void | ) |
Face class ids lower than 0 are replaced by the matching face zone id.
