#include "cs_halo_perio.h"
#include "cs_matrix.h"
#include "cs_sles.h"
| void | cs_sles_default_log_setup (void) |
| void | cs_sles_default (int f_id, const char *name, const cs_matrix_t *a) |
| | Default definition of a sparse linear equation solver. More...
| void | cs_sles_default_setup (void) |
| | Default setup for sparse linear equation solver API. More...
| int | cs_sles_default_get_verbosity (int f_id, const char *name) |
| | Return default verbosity associated to a field id, name couple. More...
| void | cs_sles_default_finalize (void) |
| | Default finalization for sparse linear equation solver API. More...
| void | cs_sles_setup_native_conv_diff (int f_id, const char *name, const cs_lnum_t diag_block_size, const cs_lnum_t extra_diag_block_size, const cs_real_t *da, const cs_real_t *xa, bool conv_diff) |
| | Call sparse linear equation solver setup for convection-diffusion systems. More...
| cs_sles_convergence_state_t | cs_sles_solve_native (int f_id, const char *name, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, const cs_real_t *da, const cs_real_t *xa, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx) |
| | Call sparse linear equation solver using native matrix arrays. More...
| void | cs_sles_free_native (int f_id, const char *name) |
| | Free sparse linear equation solver setup using native matrix arrays. More...
| bool | cs_sles_default_error (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t rhs[], cs_real_t vx[]) |
| | Error handler attempting fallback to alternative solution procedure for sparse linear equation solver. More...
◆ cs_sles_default()
| void cs_sles_default |
int |
f_id, |
const char * |
name, |
const cs_matrix_t * |
a |
- Parameters
| [in] | a | matrix |
◆ cs_sles_default_error()
In case of divergence with an iterative solver, this error handler switches to a default preconditioner, then resets the solution vector.
The default error for the solver type handler is then set, in case the solution fails again.
Note that this error handler may rebuild solver contexts, so should not be used in conjunction with shared contexts (such as multigrid ascent/descent contexts), but only for "outer" solvers.
- Parameters
| [in] | state | convergence status |
| [in] | a | matrix |
- Returns
- true if fallback solution is possible, false otherwise
◆ cs_sles_default_finalize()
| void cs_sles_default_finalize |
void |
This includes performance data logging output.
◆ cs_sles_default_get_verbosity()
| int cs_sles_default_get_verbosity |
int |
f_id, |
const char * |
name |
- Parameters
- Returns
- verbosity associated with field or name
◆ cs_sles_default_log_setup()
| void cs_sles_default_log_setup |
void |
◆ cs_sles_default_setup()
| void cs_sles_default_setup |
void |
This includes setup logging.
◆ cs_sles_free_native()
| void cs_sles_free_native |
int |
f_id, |
const char * |
name |
- Parameters
◆ cs_sles_setup_native_conv_diff()
| void cs_sles_setup_native_conv_diff |
int |
f_id, |
const char * |
name, |
const cs_lnum_t |
diag_block_size, |
const cs_lnum_t |
extra_diag_block_size, |
const cs_real_t * |
da, |
const cs_real_t * |
xa, |
bool |
conv_diff |
- Parameters
| [in] | diag_block_size | block sizes for diagonal, or NULL |
| [in] | extra_diag_block_size | block sizes for extra diagonal, or NULL |
| [in] | da | diagonal values (NULL if zero) |
| [in] | xa | extradiagonal values (NULL if zero) |
| [in] | conv_diff | convection-diffusion mode |
◆ cs_sles_solve_native()
| cs_sles_convergence_state_t cs_sles_solve_native |
int |
f_id, |
const char * |
name, |
bool |
symmetric, |
cs_lnum_t |
diag_block_size, |
cs_lnum_t |
const cs_real_t * |
da, |
const cs_real_t * |
xa, |
double |
precision, |
double |
r_norm, |
int * |
n_iter, |
double * |
residue, |
const cs_real_t * |
rhs, |
cs_real_t * |
vx |
- Parameters
| [in] | symmetric | indicates if matrix coefficients are symmetric |
| [in] | diag_block_size | block sizes for diagonal |
| [in] | extra_diag_block_size | block sizes for extra diagonal |
| [out] | residue | residue |
- Returns
- convergence state
