1 #ifndef __CS_MATRIX_H__
2 #define __CS_MATRIX_H__
888 #if defined(HAVE_ACCEL)
949 #if defined(HAVE_ACCEL)
1091 const char *func_name);
cs_alloc_mode_t
Definition: cs_base_accel.h:142
#define restrict
Definition: cs_defs.h:139
Definition: cs_defs.h:509
Definition: cs_defs.h:319
cs_lnum_t cs_lnum_2_t[2]
Definition: cs_defs.h:325
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:298
Definition: cs_defs.h:313
void cs_matrix_row_finalize(cs_matrix_row_info_t *r)
Finalize row info for a given matrix.
Definition: cs_matrix.c:5492
struct _cs_matrix_variant_t cs_matrix_variant_t
Definition: cs_matrix.h:114
bool cs_matrix_is_symmetric(const cs_matrix_t *matrix)
Query matrix coefficients symmetry.
Definition: cs_matrix.c:5369
void cs_matrix_copy_coefficients(cs_matrix_t *matrix, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, const cs_lnum_t n_edges, const cs_lnum_2_t edges[], const cs_real_t *da, const cs_real_t *xa)
Set matrix coefficients, copying values to private arrays.
Definition: cs_matrix.c:5137
void cs_matrix_set_coefficients(cs_matrix_t *matrix, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, const cs_lnum_t n_edges, const cs_lnum_2_t edges[], const cs_real_t *da, const cs_real_t *xa)
Set matrix coefficients defined relative to a "native" edge graph, sharing arrays with the caller whe...
Definition: cs_matrix.c:5078
cs_matrix_structure_t * cs_matrix_structure_create(cs_matrix_type_t type, cs_lnum_t n_rows, cs_lnum_t n_cols_ext, cs_lnum_t n_edges, const cs_lnum_2_t *edges, const cs_halo_t *halo, const cs_numbering_t *numbering)
Create a matrix structure.
Definition: cs_matrix.c:4218
void cs_matrix_vector_multiply_nosync(const cs_matrix_t *matrix, cs_real_t *restrict x, cs_real_t *restrict y)
Matrix.vector product y = A.x with no prior halo update of x.
Definition: cs_matrix.c:6007
const char * cs_matrix_spmv_type_name[]
cs_matrix_variant_t * cs_matrix_variant_create(cs_matrix_t *m)
Build matrix variant.
Definition: cs_matrix.c:6158
const char * cs_matrix_get_type_fullname(const cs_matrix_t *matrix)
Definition: cs_matrix.c:4788
void cs_matrix_copy_diagonal(const cs_matrix_t *matrix, cs_real_t *restrict da)
Copy matrix diagonal values.
Definition: cs_matrix.c:5346
struct _cs_matrix_structure_t cs_matrix_structure_t
Definition: cs_matrix.h:106
cs_lnum_t cs_matrix_get_extra_diag_block_size(const cs_matrix_t *matrix)
Return the size of the extra-diagonal block for the given matrix.
Definition: cs_matrix.c:4920
const cs_real_t * cs_matrix_get_diagonal(const cs_matrix_t *matrix)
Get matrix diagonal values.
Definition: cs_matrix.c:5414
cs_matrix_spmv_type_t
Definition: cs_matrix.h:95
@ CS_MATRIX_SPMV_N_TYPES
Definition: cs_matrix.h:100
@ CS_MATRIX_SPMV
Definition: cs_matrix.h:97
@ CS_MATRIX_SPMV_E
Definition: cs_matrix.h:98
void cs_matrix_vector_multiply_partial(const cs_matrix_t *matrix, cs_matrix_spmv_type_t op_type, cs_real_t *restrict x, cs_real_t *restrict y)
Partial matrix.vector product.
Definition: cs_matrix.c:6063
cs_matrix_type_t cs_matrix_variant_type(const cs_matrix_variant_t *mv)
Get the type associated with a matrix variant.
Definition: cs_matrix.c:6559
void cs_matrix_variant_apply_tuned(cs_matrix_t *m, cs_matrix_variant_t *mv)
Apply variants defined by tuning to a given matrix.
Definition: cs_matrix.c:6447
Definition: cs_matrix.h:110
cs_lnum_t cs_matrix_get_n_entries(const cs_matrix_t *matrix)
Return the number of entries in matrix.
Definition: cs_matrix.c:4848
void cs_matrix_destroy(cs_matrix_t **matrix)
Definition: cs_matrix.c:4726
void cs_matrix_variant_apply(cs_matrix_t *m, cs_matrix_variant_t *mv)
Apply a variant to a given matrix.
Definition: cs_matrix.c:6412
cs_matrix_t * cs_matrix_create_by_copy(cs_matrix_t *src)
Create a matrix container by copying another.
Definition: cs_matrix.c:4606
cs_matrix_fill_type_t cs_matrix_get_fill_type(bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
Get matrix fill type, depending on block sizes.
Definition: cs_matrix.c:5017
const cs_real_t * cs_matrix_get_extra_diagonal(const cs_matrix_t *matrix)
Get pointer to matrix extra-diagonal values in "native" format.
Definition: cs_matrix.c:5449
void cs_matrix_variant_set_func(cs_matrix_variant_t *mv, cs_matrix_fill_type_t fill_type, cs_matrix_spmv_type_t spmv_type, const cs_numbering_t *numbering, const char *func_name)
Select the sparse matrix-vector product function to be used by a matrix variant for a given fill type...
Definition: cs_matrix.c:6513
void cs_matrix_vector_multiply(const cs_matrix_t *matrix, cs_real_t *restrict x, cs_real_t *restrict y)
Matrix.vector product y = A.x.
Definition: cs_matrix.c:5917
void cs_matrix_transfer_coefficients_msr(cs_matrix_t *matrix, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, const cs_lnum_t row_index[], const cs_lnum_t col_id[], cs_real_t **d_val, cs_real_t **x_val)
Set matrix coefficients in an MSR format, transfering the property of those arrays to the matrix.
Definition: cs_matrix.c:5191
cs_matrix_t * cs_matrix_create(const cs_matrix_structure_t *ms)
Create a matrix container using a given structure.
Definition: cs_matrix.c:4525
void cs_matrix_apply_variant(cs_matrix_t *m, const cs_matrix_variant_t *mv)
void cs_matrix_set_alloc_mode(cs_matrix_t *matrix, cs_alloc_mode_t alloc_mode)
Set matrix allocation mode.
Definition: cs_matrix.c:4997
void cs_matrix_get_csr_arrays(const cs_matrix_t *matrix, const cs_lnum_t **row_index, const cs_lnum_t **col_id, const cs_real_t **val)
Get arrays describing a matrix in CSR format.
Definition: cs_matrix.c:5823
cs_alloc_mode_t cs_matrix_get_alloc_mode(const cs_matrix_t *matrix)
Query matrix allocation mode.
Definition: cs_matrix.c:4982
void cs_matrix_row_init(cs_matrix_row_info_t *r)
Initialize row info for a given matrix.
Definition: cs_matrix.c:5473
void cs_matrix_get_msr_arrays(const cs_matrix_t *matrix, const cs_lnum_t **row_index, const cs_lnum_t **col_id, const cs_real_t **d_val, const cs_real_t **x_val)
Get arrays describing a matrix in MSR format.
Definition: cs_matrix.c:5867
cs_matrix_structure_t * cs_matrix_structure_create_msr(cs_matrix_type_t type, bool transfer, bool have_diag, cs_lnum_t n_rows, cs_lnum_t n_cols_ext, cs_lnum_t **row_index, cs_lnum_t **col_id, const cs_halo_t *halo, const cs_numbering_t *numbering)
Create a matrix structure based on a MSR connectivity definition.
Definition: cs_matrix.c:4316
Definition: cs_matrix.h:72
@ CS_MATRIX_BLOCK_D_66
Definition: cs_matrix.h:78
@ CS_MATRIX_N_FILL_TYPES
Definition: cs_matrix.h:85
@ CS_MATRIX_SCALAR
Definition: cs_matrix.h:74
@ CS_MATRIX_BLOCK_D
Definition: cs_matrix.h:76
@ CS_MATRIX_BLOCK
Definition: cs_matrix.h:84
@ CS_MATRIX_SCALAR_SYM
Definition: cs_matrix.h:75
@ CS_MATRIX_BLOCK_D_SYM
Definition: cs_matrix.h:82
const char * cs_matrix_fill_type_name[]
cs_matrix_structure_t * cs_matrix_structure_create_msr_shared(bool direct_assmbly, cs_lnum_t n_rows, cs_lnum_t n_cols_ext, const cs_lnum_t *row_index, const cs_lnum_t *col_id, const cs_halo_t *halo, const cs_numbering_t *numbering)
Create an MSR matrix structure sharing an existing connectivity definition.
Definition: cs_matrix.c:4406
const cs_halo_t * cs_matrix_get_halo(const cs_matrix_t *matrix)
Return the pointer to the halo structure for the given matrix.
Definition: cs_matrix.c:4939
cs_matrix_t * cs_matrix_create_from_assembler(cs_matrix_type_t type, cs_matrix_assembler_t *ma)
Create a matrix directly from assembler.
Definition: cs_matrix.c:4559
const char * cs_matrix_get_type_name(const cs_matrix_t *matrix)
Definition: cs_matrix.c:4772
cs_lnum_t cs_matrix_get_diag_block_size(const cs_matrix_t *matrix)
Return the size of the diagonal block for the given matrix structure.
Definition: cs_matrix.c:4901
void cs_matrix_variant_destroy(cs_matrix_variant_t **mv)
Destroy a matrix variant structure.
Definition: cs_matrix.c:6396
void cs_matrix_pre_vector_multiply_sync(const cs_matrix_t *matrix, cs_real_t *x)
cs_matrix_type_t
Definition: cs_matrix.h:54
@ CS_MATRIX_CSR
Definition: cs_matrix.h:57
@ CS_MATRIX_MSR
Definition: cs_matrix.h:58
@ CS_MATRIX_N_TYPES
Definition: cs_matrix.h:66
@ CS_MATRIX_NATIVE
Definition: cs_matrix.h:56
@ CS_MATRIX_DIST
Definition: cs_matrix.h:60
@ CS_MATRIX_N_BUILTIN_TYPES
Definition: cs_matrix.h:64
void cs_matrix_variant_build_list(const cs_matrix_t *m, int *n_variants, cs_matrix_variant_t **m_variant)
Build list of variants for tuning or testing.
Definition: cs_matrix.c:6203
bool cs_matrix_is_mapped_from_native(const cs_matrix_t *matrix)
Indicate whether coefficients were mapped from native face-based arrays.
Definition: cs_matrix.c:5390
cs_matrix_assembler_values_t * cs_matrix_assembler_values_init(cs_matrix_t *matrix, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
Create and initialize a CSR matrix assembler values structure.
Definition: cs_matrix.c:5304
void cs_matrix_release_coefficients(cs_matrix_t *matrix)
Release shared matrix coefficients.
Definition: cs_matrix.c:5261
void cs_matrix_get_row(const cs_matrix_t *matrix, const cs_lnum_t row_id, cs_matrix_row_info_t *r)
Get row values for a given matrix.
Definition: cs_matrix.c:5523
cs_matrix_type_t cs_matrix_get_type(const cs_matrix_t *matrix)
Return matrix type.
Definition: cs_matrix.c:4757
cs_lnum_t cs_matrix_get_n_rows(const cs_matrix_t *matrix)
Return the number of rows in matrix.
Definition: cs_matrix.c:4826
void cs_matrix_structure_destroy(cs_matrix_structure_t **ms)
Destroy a matrix structure.
Definition: cs_matrix.c:4497
cs_matrix_t * cs_matrix_create_by_local_restrict(const cs_matrix_t *src)
Create a matrix based on the local restriction of a base matrix.
Definition: cs_matrix.c:4657
cs_lnum_t cs_matrix_get_n_columns(const cs_matrix_t *matrix)
Return number of columns in a matrix.
Definition: cs_matrix.c:4807
void cs_matrix_get_native_arrays(const cs_matrix_t *matrix, bool *symmetric, cs_lnum_t *n_edges, const cs_lnum_2_t **edges, const cs_real_t **d_val, const cs_real_t **x_val)
Get arrays describing a matrix in native format.
Definition: cs_matrix.c:5769
const cs_gnum_t * cs_matrix_get_l_range(const cs_matrix_t *matrix)
Return a pointer to local global row range associated with a matrix, if available.
Definition: cs_matrix.c:4959
cs_matrix_structure_t * cs_matrix_structure_create_from_assembler(cs_matrix_type_t type, cs_matrix_assembler_t *ma)
Create a matrix structure using a matrix assembler.
Definition: cs_matrix.c:4456
Definition: cs_matrix.h:118
cs_lnum_t buffer_size
Definition: cs_matrix.h:121
cs_real_t * _vals
Definition: cs_matrix.h:125
const cs_lnum_t * col_id
Definition: cs_matrix.h:122
cs_lnum_t * _col_id
Definition: cs_matrix.h:123
cs_lnum_t row_size
Definition: cs_matrix.h:120
const cs_real_t * vals
Definition: cs_matrix.h:124
Definition: cs_numbering.h:87
