Macros | |
#define | CS_MALLOC_HD(_ptr, _ni, _type, _mode) |
#define | CS_REALLOC_HD(_ptr, _ni, _type, _mode) |
#define | CS_FREE_HD(_ptr) cs_free_hd(_ptr, #_ptr, __FILE__, __LINE__), _ptr = NULL |
#define | CS_FREE(_ptr) cs_free(_ptr, #_ptr, __FILE__, __LINE__), _ptr = NULL |
#define | cs_alloc_mode CS_ALLOC_HOST |
#define | cs_associate_device_ptr(_host_ptr, _ni, _size) ; |
Associate device memory with a given host memory pointer. More... | |
#define | cs_disassociate_device_ptr(_host_ptr) ; |
Detach device memory from a given host memory pointer. More... | |
#define | cs_set_alloc_mode(_host_ptr, mode) ; |
Set allocation mode for an already allocated pointer. More... | |
Enumerations | |
enum | cs_alloc_mode_t { CS_ALLOC_HOST , CS_ALLOC_HOST_DEVICE , CS_ALLOC_HOST_DEVICE_PINNED , CS_ALLOC_HOST_DEVICE_SHARED , CS_ALLOC_DEVICE } |
static int | cs_get_device_id (void) |
Return currently associated device id. More... | |
static void * | cs_malloc_hd (cs_alloc_mode_t mode, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num) |
Allocate memory on host and device for ni elements of size bytes. More... | |
static void * | cs_realloc_hd (void *ptr, cs_alloc_mode_t mode, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num) |
Reallocate memory on host and device for ni elements of size bytes. More... | |
static void | cs_free_hd (void *ptr, const char *var_name, const char *file_name, int line_num) |
Free memory on host and device for a given host pointer. More... | |
static void | cs_free (void *ptr, const char *var_name, const char *file_name, int line_num) |
Free memory on host and device for a given pointer. More... | |
static void * | cs_get_device_ptr (void *ptr) |
Return matching device pointer for a given pointer. More... | |
static const void * | cs_get_device_ptr_const (const void *ptr) |
Return matching device pointer for a given constant pointer. More... | |
static const void * | cs_get_device_ptr_const_pf (const void *ptr) |
Return matching device pointer for a given constant pointer, prefetching if applicable. More... | |
static cs_alloc_mode_t | cs_check_device_ptr (const void *ptr) |
Check if a pointer is associated with a device. More... | |
static void | cs_sync_h2d (const void *ptr) |
Synchronize data from host to device. More... | |
static void | cs_sync_h2d_future (const void *ptr) |
Initiate synchronization of data from host to device for future access. More... | |
static void | cs_sync_d2h (void *ptr) |
Synchronize data from device to host. More... | |
static void | cs_prefetch_h2d (void *ptr, size_t size) |
Prefetch data from host to device. More... | |
static void | cs_prefetch_d2h (void *ptr, size_t size) |
Prefetch data from device to host. More... | |
static int | cs_get_n_allocations_hd (void) |
Return number of host-device allocations. More... | |
static size_t | cs_get_allocation_hd_size (void *host_ptr) |
Check if a given host pointer is allocated with associated with cs_alloc_hd or cs_realloc_hd. More... | |
#define cs_alloc_mode CS_ALLOC_HOST |
#define cs_associate_device_ptr | ( | _host_ptr, | |
_ni, | |||
_size | |||
If the host memory is already associated with the device, the existing device pointer is returned. Otherwise, a new device allocation is called and returned.
[in] | host_ptr | host pointer |
[in] | ni | number of elements |
[in] | size | element size |
#define cs_disassociate_device_ptr | ( | _host_ptr | ) | ; |
If the host memory is shared with the device (i.e. using CS_ALLOC_SHARED), device memory stays shared.
#define CS_FREE | ( | _ptr | ) | cs_free(_ptr, #_ptr, __FILE__, __LINE__), _ptr = NULL |
#define CS_FREE_HD | ( | _ptr | ) | cs_free_hd(_ptr, #_ptr, __FILE__, __LINE__), _ptr = NULL |
#define CS_MALLOC_HD | ( | _ptr, | |
_ni, | |||
_type, | |||
_mode | |||
#define CS_REALLOC_HD | ( | _ptr, | |
_ni, | |||
_type, | |||
_mode | |||
#define cs_set_alloc_mode | ( | _host_ptr, | |
mode | |||
If the allocation mode is different from the previous one, the associated memory will be reallocated with the desired mode, and the previous allocation freed.
[in,out] | host_ptr | pointer to host pointer to modify |
[in] | mode | desired allocation mode |
enum cs_alloc_mode_t |
Allocation modes for accelerated code.
inlinestatic |
If separate pointers are used on the host and device, the host pointer should be used with this function.
inlinestatic |
Compared to \cs_free_hd, this function also allows freeing memory allocated through BFT_MEM_MALLOC / bft_mem_malloc.
[in] | ptr | pointer to free |
[in] | var_name | allocated variable name string |
[in] | file_name | name of calling source file |
[in] | line_num | line number in calling source file |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
If memory is not allocated on device yet at the call site, it will be allocated automatically by this function.
[in] | ptr | pointer |
inlinestatic |
inlinestatic |
If separate pointers are used on the host and device, the host pointer should be used with this function. In this case, it is assumed that the host and device values have already been synchronized, unless memory is not allocated on device yet at the call site, in which case it will be allocated automatically by this function.
inlinestatic |
inlinestatic |
This function calls the appropriate allocation function based on the requested mode, and allows introspection of the allocated memory.
If separate pointers are used on the host and device, the host pointer is returned.
[in] | mode | allocation mode |
inlinestatic |
This function should only be used on arrays using shared host and device memory, shuch as those allocated using CS_ALLOC_HOST_DEVICE_SHARED. It should be usable on a subset of such an array.
[in,out] | ptr | pointer to data to prefetch |
[in] | size | number of bytes to prefetch |
inlinestatic |
inlinestatic |
This function calls the appropriate reallocation function based on the requested mode, and allows introspection of the allocated memory.
If the allocation parameters are unchanged, no actual reallocation occurs on the host.
If the device uses a separate allocation, it is freed, and a new allocation is delayed (as per initial allocation) so as to invalidate copies which will not be up to date anymore after the associated values modification.
[in] | ptr | pointer to previously allocated memory |
inlinestatic |
If separate allocations are used on the host and device (mode == CS_ALLOC_HOST_DEVICE), the host pointer should be passed to this function.
Depending on the allocaton type, this can imply a copy, data prefetch, or a no-op.
This function assumes the provided pointer was allocated using CS_MALLOC_HD or CS_REALLOC_HD, as it uses the associated mapping to determine associated metadata.
[in,out] | ptr | pointer to values to copy or prefetch |
inlinestatic |
Depending on the allocation type, this can imply a copy, data prefetch, or a no-op.
[in,out] | ptr | host pointer to values to copy or prefetch |
inlinestatic |
If separate pointers are used on the host and device, the host pointer should be used with this function. In this case, synchronization is started (asynchronously if the allocation mode supports it).
In other cases, synchronization will be delayed until actual use. the host pointer should be used with this function.
