8.0
cs_medcoupling_intersector.cxx File Reference
#include <stdarg.h>
#include "cs_file.h"
#include "cs_mesh_connect.h"
#include "cs_post.h"
#include "cs_prototypes.h"
#include "cs_rotation.h"
#include "cs_selector.h"
#include "cs_timer.h"
#include "fvm_writer.h"
#include "fvm_nodal.h"
#include "fvm_nodal_append.h"
#include "cs_medcoupling_mesh.hxx"
#include "cs_medcoupling_intersector.h"
#include <MEDCoupling_version.h>
#include <MEDFileMesh.hxx>
#include <MEDLoader.hxx>
#include <MEDCouplingNormalizedUnstructuredMesh.txx>
#include "Interpolation3D.hxx"
#include "Interpolation3DSurf.hxx"
#include "Interpolation2D3D.hxx"
+ Include dependency graph for cs_medcoupling_intersector.cxx:
static cs_medcoupling_intersector_t * _create_intersector (void)
 create a cs_medcoupling_intersector_t object More...
void _allocate_intersector_external_mesh (cs_medcoupling_intersector_t *mi, const cs_lnum_t n_vtx, const cs_lnum_t dim)
 Allocate and fill arrays needed for fvm writers. More...
void _allocate_intersector (cs_medcoupling_intersector_t *mi, const char *name, const char *medfile_path, const char *interp_method, const char *select_criteria, cs_medcpl_intersect_type_t type)
 Initialize a cs_medcoupling_intersector with given parameters. More...
void _add_intersector (const char *name, const char *medfile_path, const char *interp_method, const char *select_criteria, cs_medcpl_intersect_type_t type)
 Add a MEDCoupling intersector. More...
static void _transform_coord_from_init (cs_real_t matrix[3][4], cs_real_t vector[3], cs_real_t res[3])
 Compute a matrix/vector product to apply a transformation to a vector. More...
static void _transform_coord (cs_real_t matrix[3][4], cs_real_t vector[3])
static void _assign_vertex_coords (MEDCouplingUMesh *med_mesh, cs_coord_3_t *coords)
 assign vertex coordinates to a medcoupling mesh structure More...
static void _destroy_intersector (cs_medcoupling_intersector_t *mi)
 destroy a given intersector More...
static void _compute_intersection_surfaces (cs_medcoupling_intersector_t *mi)
 Compute surface intersection matrix and update the intersection array. More...
static void _compute_intersection_volumes (cs_medcoupling_intersector_t *mi)
 Compute intersection matrix and update the intersection array. More...
static void _compute_intersection_volume_surfaces (cs_medcoupling_intersector_t *mi)
 Compute volume to surface intersection matrix and update the intersection array. More...
static void _dump_medcoupling_mesh (MEDCouplingUMesh *m, const char *prefix, const char *filename)
 dump a medcoupling mesh More...
void cs_medcoupling_intersector_add_vol (const char *name, const char *medfile_path, const char *interp_method, const char *select_criteria)
 Add a volume MEDCoupling intersector. More...
void cs_medcoupling_intersector_add_surf (const char *name, const char *medfile_path, const char *interp_method, const char *select_criteria)
 Add a surface MEDCoupling intersector. More...
void cs_medcoupling_intersector_add_vol_surf (const char *name, const char *medfile_path, const char *interp_method, const char *select_criteria)
 Add a surface in volume MEDCoupling intersector. More...
void cs_medcoupling_intersector_destroy (cs_medcoupling_intersector_t *mi)
 Destroy a given MEDCoupling intersector. More...
void cs_medcoupling_intersector_destroy_all (void)
 Free all allocated intersectors. More...
cs_medcoupling_intersector_t * cs_medcoupling_intersector_by_id (int id)
 Get a MEDCoupling intersector using its id. More...
cs_medcoupling_intersector_t * cs_medcoupling_intersector_by_name (const char *name)
 Get an intersector by name. More...
cs_real_tcs_medcoupling_intersect_volumes (cs_medcoupling_intersector_t *mi)
 Compute the intersection volumes between the source mesh and code mesh. More...
cs_real_tcs_medcoupling_intersect_surfaces (cs_medcoupling_intersector_t *mi)
 Compute the intersection surfaces between the source mesh and code mesh. More...
cs_real_tcs_medcoupling_intersect_volume_and_surfaces (cs_medcoupling_intersector_t *mi)
void cs_medcoupling_intersector_translate (cs_medcoupling_intersector_t *mi, cs_real_t translation[3])
 translate the mesh using a given vector More...
void cs_medcoupling_intersector_rotate (cs_medcoupling_intersector_t *mi, cs_real_t invariant[3], cs_real_t axis[3], cs_real_t angle)
 rotate the mesh More...
void cs_medcoupling_intersector_scale_auto (cs_medcoupling_intersector_t *mi, cs_real_t factor)
 Scale a mesh using a factor based on the current mesh center position. More...
void cs_medcoupling_intersector_transform_from_init (cs_medcoupling_intersector_t *mi, cs_real_t matrix[3][4])
 Transform a mesh, but takes as input the initial position of the mesh. More...
void cs_medcoupling_intersector_dump_mesh (cs_medcoupling_intersector_t *mi, const char *prefix)
 dump the mesh of a cs_medcoupling_intersector_t structure More...
int cs_mi_post_get_writer_id (void)
 Return writer id used for medcoupling meshes, 0 means unused. More...
void cs_mi_post_init_writer (const char *case_name, const char *dir_name, const char *fmt_name, const char *fmt_opts, fvm_writer_time_dep_t time_dep, bool output_at_start, bool output_at_end, int frequency_n, double frequency_t)
 Create a new writer that will contains the boundary MED mesh added. More...
void cs_mi_post_add_mesh (cs_medcoupling_intersector_t *mi)
 Associate a Medcoupling mesh to the default writer. More...
static int _n_intersects = 0
static int _writer_id = 0
static cs_medcoupling_intersector_t ** _intersects = NULL
◆ _add_intersector()
void _add_intersector ( const char *  name,
const char *  medfile_path,
const char *  interp_method,
const char *  select_criteria,
[in]namename of the intersector
[in]medfile_pathpath to the MED file
[in]interp_methodinterpolation method (P0P0, P1P0, ..)
[in]select_criteriaselection criteria
[in]typeintersection type (volume or surface)
◆ _allocate_intersector()
void _allocate_intersector ( cs_medcoupling_intersector_t *  mi,
const char *  name,
[in]mipointer to the cs_medcoupling_intersector_t struct
◆ _allocate_intersector_external_mesh()
void _allocate_intersector_external_mesh ( cs_medcoupling_intersector_t *  mi,
const cs_lnum_t  dim
[in]n_vtxnumber of vertices in the mesh
[in]dimmesh dimension
◆ _assign_vertex_coords()
static void _assign_vertex_coords ( MEDCouplingUMesh *  med_mesh,
cs_coord_3_t coords
static
[in]med_meshpointer to MEDCouplingUMesh to which we copy the coordinates
[in]coordspointer to the coordinates to assign to the MEDCouplingUMesh
◆ _compute_intersection_surfaces()
static void _compute_intersection_surfaces ( cs_medcoupling_intersector_t *  mi)
static
◆ _compute_intersection_volume_surfaces()
static void _compute_intersection_volume_surfaces ( cs_medcoupling_intersector_t *  mi)
static
◆ _compute_intersection_volumes()
static void _compute_intersection_volumes ( cs_medcoupling_intersector_t *  mi)
static
◆ _create_intersector()
static cs_medcoupling_intersector_t* _create_intersector ( void  )
static
pointer to the newly created object
◆ _destroy_intersector()
static void _destroy_intersector ( cs_medcoupling_intersector_t *  mi)
static
◆ _dump_medcoupling_mesh()
static void _dump_medcoupling_mesh ( MEDCouplingUMesh *  m,
const char *  prefix,
const char *  filename
static
[in]mMEDCouplingUMesh to dump
[in]prefixfolder where the file is to be written
[in]filenamename of the file to write
◆ _transform_coord()
static void _transform_coord ( cs_real_t  matrix[3][4],
cs_real_t  vector[3]
inlinestatic
[in]matrixmatrix
[in]vectorvector
◆ _transform_coord_from_init()
static void _transform_coord_from_init ( cs_real_t  matrix[3][4],
cs_real_t  res[3]
inlinestatic
Results is stored in an output array.
[in]matrixmatrix
[in]vectorvector
[out]resresulting vector
◆ cs_medcoupling_intersect_surfaces()
cs_real_t* cs_medcoupling_intersect_surfaces ( cs_medcoupling_intersector_t *  mi)
a pointer to the array containing the intersected volume of each cell
◆ cs_medcoupling_intersect_volume_and_surfaces()
cs_real_t* cs_medcoupling_intersect_volume_and_surfaces ( cs_medcoupling_intersector_t *  mi)
◆ cs_medcoupling_intersect_volumes()
cs_real_t* cs_medcoupling_intersect_volumes ( cs_medcoupling_intersector_t *  mi)
◆ cs_medcoupling_intersector_add_surf()
void cs_medcoupling_intersector_add_surf ( const char *  name,
◆ cs_medcoupling_intersector_add_vol()
void cs_medcoupling_intersector_add_vol ( const char *  name,
◆ cs_medcoupling_intersector_add_vol_surf()
void cs_medcoupling_intersector_add_vol_surf ( const char *  name,
◆ cs_medcoupling_intersector_by_id()
cs_medcoupling_intersector_t* cs_medcoupling_intersector_by_id ( int  id)
[in]idid of the intersector
pointer to the cs_medcoupling_intersector_t or NULL if not found
◆ cs_medcoupling_intersector_by_name()
cs_medcoupling_intersector_t* cs_medcoupling_intersector_by_name ( const char *  name)
Get a MEDCoupling intersector by name.
◆ cs_medcoupling_intersector_destroy()
void cs_medcoupling_intersector_destroy ( cs_medcoupling_intersector_t *  mi)
◆ cs_medcoupling_intersector_destroy_all()
void cs_medcoupling_intersector_destroy_all ( void  )
◆ cs_medcoupling_intersector_dump_mesh()
void cs_medcoupling_intersector_dump_mesh ( cs_medcoupling_intersector_t *  mi,
const char *  prefix
[in]prefixsubdir prefix
◆ cs_medcoupling_intersector_rotate()
void cs_medcoupling_intersector_rotate ( cs_medcoupling_intersector_t *  mi,
cs_real_t  axis[3],
cs_real_t  angle
rotate the mesh
[in]invariantInvariant point
[in]axisRotation axis
[in]angleangle (in radians)
◆ cs_medcoupling_intersector_scale_auto()
void cs_medcoupling_intersector_scale_auto ( cs_medcoupling_intersector_t *  mi,
cs_real_t  factor
[in]factorscaling factor (cs_real_t)
◆ cs_medcoupling_intersector_transform_from_init()
void cs_medcoupling_intersector_transform_from_init ( cs_medcoupling_intersector_t *  mi,
Transformation is thus applied on the initial coordiantes and the
mesh is modified accordingly.
[in]matrixtransformation matrix
◆ cs_medcoupling_intersector_translate()
void cs_medcoupling_intersector_translate ( cs_medcoupling_intersector_t *  mi,
[in]translationtranslation vector
◆ cs_mi_post_add_mesh()
void cs_mi_post_add_mesh ( cs_medcoupling_intersector_t *  mi)
[in]mipointer to the associated MedCoupling intersector structure
◆ cs_mi_post_get_writer_id()
int cs_mi_post_get_writer_id ( void  )
◆ cs_mi_post_init_writer()
void cs_mi_post_init_writer ( const char *  case_name,
const char *  dir_name,
const char *  fmt_name,
const char *  fmt_opts,
bool  output_at_end,
int  frequency_n,
double  frequency_t
by the user. The writer_id is stored locally..
[in]time_dep> 1 if the writer is transient, else writer is fixed
◆ _intersects
cs_medcoupling_intersector_t** _intersects = NULL
static
◆ _n_intersects
static
◆ _writer_id
int _writer_id = 0
static
