#include "cs_defs.h"#include <assert.h>#include "bft_error.h"#include "bft_mem.h"#include "cs_array.h"#include "cs_flag.h"#include "cs_matrix_priv.h"#include "cs_cdo_system.h"
Include dependency graph for cs_cdo_system.c:Functions | |
| void | cs_cdo_system_init_sharing (cs_mesh_t *mesh, cs_cdo_connect_t *connect) |
| Allocate and initialize matrix-related structures according to the type of discretization used for this simulation. More... | |
| cs_cdo_system_helper_t * | cs_cdo_system_helper_create (cs_cdo_system_type_t type, int n_col_blocks, const cs_lnum_t *col_block_sizes, int n_blocks) |
| Create a system_helper structure from its set of metadata. n_col_blocks and n_blocks may differ according to the settings. For instance, for a saddle-point system, n_col_blocks >= n_blocks. More... | |
| void | cs_cdo_system_helper_free (cs_cdo_system_helper_t **p_helper) |
| Free a cs_cdo_system_helper_t structure. More... | |
| cs_cdo_system_block_t * | cs_cdo_system_add_dblock (cs_cdo_system_helper_t *sh, int block_id, cs_cdo_system_matrix_class_t matclass, cs_flag_t location, cs_lnum_t n_elements, int stride, bool interlaced, bool unrolled) |
| Add an unassembled block definition at position "block_id" in the helper structure Only metadata are set at this stage. More... | |
| cs_cdo_system_block_t * | cs_cdo_system_add_sblock (cs_cdo_system_helper_t *sh, int block_id, cs_cdo_system_matrix_class_t matclass, cs_flag_t location, cs_lnum_t n_elements, int stride) |
| Add a split block definition at position "block_id" in the helper structure. Only metadata are set at this stage. More... | |
| cs_cdo_system_block_t * | cs_cdo_system_add_ublock (cs_cdo_system_helper_t *sh, int block_id, const cs_adjacency_t *adjacency, cs_flag_t location, cs_lnum_t n_elements, int stride, bool interlaced) |
| cs_cdo_system_block_t * | cs_cdo_system_add_xblock (cs_cdo_system_helper_t *sh, int block_id, cs_lnum_t n_dofs) |
| Add an external block definition at position "block_id" in the helper structure. Only metadata are set at this stage. More... | |
| cs_range_set_t * | cs_cdo_system_get_range_set (const cs_cdo_system_helper_t *sh, int block_id) |
| Retrieve the range set structure associated to the given block_id. More... | |
| cs_matrix_t * | cs_cdo_system_get_matrix (const cs_cdo_system_helper_t *sh, int block_id) |
| Retrieve the matrix associated to the given block_id. If the type of block is either CS_CDO_SYSTEM_BLOCK_DEFAULT or CS_CDO_SYSTEM_BLOCK_EXT. In other cases, a NULL pointer is returned. The unassembled block has no matrix and to get a matrix of a split block, one should use cs_cdo_system_get_sub_matrix(sh, block_id, sub_id) More... | |
| cs_matrix_t * | cs_cdo_system_get_sub_matrix (cs_cdo_system_helper_t *sh, int block_id, int sub_id) |
| Retrieve the (sub-)matrix associated to a split block with id equal to block_id. sub_id is the id in the list of matrices of size equal to stride*stride. If the type of the block is not CS_CDO_SYSTEM_BLOCK_SPLIT, then a NULL pointer is returned. More... | |
| void | cs_cdo_system_build_block (cs_cdo_system_helper_t *sh, int block_id) |
| Build the associated structures for the given system_helper structure If a member is already allocated, one keeps the member as it is. More... | |
| void | cs_cdo_system_helper_init_system (cs_cdo_system_helper_t *sh, cs_real_t **p_rhs) |
| Allocate and initialize the matrix, rhs and the matrix assembler values. If p_rhs is NULL then one allocates the rhs inside this function. The ownership is transfered to this structure in that case. More... | |
| void | cs_cdo_system_helper_finalize_assembly (cs_cdo_system_helper_t *sh) |
| Finalize the assembly after the cellwise building and assembly. More... | |
| void | cs_cdo_system_helper_reset (cs_cdo_system_helper_t *sh) |
| Free matrix and rhs after the solve step. More... | |
| void | cs_cdo_system_allocate_assembly (void) |
| Initialize shared assembly structures from the existing helper structures. More... | |
| void | cs_cdo_system_destroy_all (void) |
| Free all members associated to system helpers. More... | |
| cs_cdo_system_block_t* cs_cdo_system_add_dblock | ( | cs_cdo_system_helper_t * | sh, |
| int | block_id, | ||
| cs_cdo_system_matrix_class_t | matclass, | ||
| cs_flag_t | location, | ||
| cs_lnum_t | n_elements, | ||
| int | stride, | ||
| bool | interlaced, | ||
| bool | unrolled | ||
| [in,out] | sh | pointer to the system helper to update |
| [in] | block_id | id in blocks array in a system helper |
| [in] | matclass | class of the matrix to handle |
| [in] | location | where DoFs are defined |
| [in] | n_elements | number of elements (support entities for DoFs) |
| [in] | stride | number of DoFs by element |
| [in] | interlaced | useful if stride > 1; way to store components |
| [in] | unrolled | useful if stride > 1; true=as scalar-valued |
| cs_cdo_system_block_t* cs_cdo_system_add_sblock | ( | cs_cdo_system_helper_t * | sh, |
| int | stride | ||
| cs_cdo_system_block_t* cs_cdo_system_add_ublock | ( | cs_cdo_system_helper_t * | sh, |
| const cs_adjacency_t * | adjacency, | ||
| int | stride, | ||
| bool | interlaced | ||
| [in] | adjacency | shared adjacency structure |
| cs_cdo_system_block_t* cs_cdo_system_add_xblock | ( | cs_cdo_system_helper_t * | sh, |
| cs_lnum_t | n_dofs | ||
| [in] | n_dofs | number of degrees of freedom |
| void cs_cdo_system_allocate_assembly | ( | void | ) |
| void cs_cdo_system_build_block | ( | cs_cdo_system_helper_t * | sh, |
| int | block_id | ||
| [in,out] | sh | pointer to the system_helper structure to update |
| [in] | block_id | specific block to handle or -1 for all blocks |
| void cs_cdo_system_destroy_all | ( | void | ) |
| cs_matrix_t* cs_cdo_system_get_matrix | ( | const cs_cdo_system_helper_t * | sh, |
| int | block_id | ||
| [in] | sh | pointer to the system_helper structure to update |
| [in] | block_id | id of the block to consider |
| cs_range_set_t* cs_cdo_system_get_range_set | ( | const cs_cdo_system_helper_t * | sh, |
| int | block_id | ||
| cs_matrix_t* cs_cdo_system_get_sub_matrix | ( | cs_cdo_system_helper_t * | sh, |
| int | sub_id | ||
| [in] | sub_id | id in the slip block |
| cs_cdo_system_helper_t* cs_cdo_system_helper_create | ( | cs_cdo_system_type_t | type, |
| int | n_col_blocks, | ||
| const cs_lnum_t * | col_block_sizes, | ||
| int | n_blocks | ||
| [in] | type | type of system to handle |
| [in] | n_col_blocks | number of blocks in a row |
| [in] | col_block_sizes | number of DoFs in each block of the row |
| [in] | n_blocks | number of blocks associated to this system |
| void cs_cdo_system_helper_finalize_assembly | ( | cs_cdo_system_helper_t * | sh | ) |
| [in,out] | sh | pointer to a system helper structure |
| void cs_cdo_system_helper_free | ( | cs_cdo_system_helper_t ** | p_helper | ) |
| [in,out] | p_helper | double pointer to the structure to free |
| void cs_cdo_system_helper_init_system | ( | cs_cdo_system_helper_t * | sh, |
| cs_real_t ** | p_rhs | ||
| [in,out] | p_rhs | double pointer to the RHS array to initialize |
| void cs_cdo_system_helper_reset | ( | cs_cdo_system_helper_t * | sh | ) |
| void cs_cdo_system_init_sharing | ( | cs_mesh_t * | mesh, |
| cs_cdo_connect_t * | connect | ||
