62 #define CS_FLAG_BOUNDARY_CELL_BY_FACE (1 << 0)
63 #define CS_FLAG_BOUNDARY_CELL_BY_VERTEX (1 << 1)
64 #define CS_FLAG_BOUNDARY_CELL_BY_EDGE (1 << 2)
65 #define CS_FLAG_SOLID_CELL (1 << 3)
80 #define CS_FLAG_CURRENT_TO_PREVIOUS (1 << 0)
81 #define CS_FLAG_INITIALIZATION (1 << 1)
89 #define CS_FLAG_SYS_MASS_MATRIX (1 << 0)
90 #define CS_FLAG_SYS_SYM (1 << 1)
91 #define CS_FLAG_SYS_TIME_DIAG (1 << 2)
92 #define CS_FLAG_SYS_REAC_DIAG (1 << 3)
93 #define CS_FLAG_SYS_SOURCES_HLOC (1 << 4)
94 #define CS_FLAG_SYS_VECTOR (1 << 5)
103 #define CS_FLAG_STATE_UNIFORM (1 << 0)
104 #define CS_FLAG_STATE_CELLWISE (1 << 1)
105 #define CS_FLAG_STATE_FACEWISE (1 << 2)
106 #define CS_FLAG_STATE_STEADY (1 << 3)
107 #define CS_FLAG_STATE_POTENTIAL (1 << 4)
108 #define CS_FLAG_STATE_CIRCULATION (1 << 5)
109 #define CS_FLAG_STATE_FLUX (1 << 6)
110 #define CS_FLAG_STATE_DENSITY (1 << 7)
119 #define CS_FLAG_FULL_LOC (1 << 0)
120 #define CS_FLAG_SCALAR (1 << 1)
121 #define CS_FLAG_VECTOR (1 << 2)
122 #define CS_FLAG_TENSOR (1 << 3)
123 #define CS_FLAG_VERTEX (1 << 4)
124 #define CS_FLAG_EDGE (1 << 5)
125 #define CS_FLAG_FACE (1 << 6)
126 #define CS_FLAG_CELL (1 << 7)
127 #define CS_FLAG_PRIMAL (1 << 8)
128 #define CS_FLAG_DUAL (1 << 9)
129 #define CS_FLAG_BORDER (1 << 10)
130 #define CS_FLAG_BY_CELL (1 << 11)
131 #define CS_FLAG_BY_FACE (1 << 12)
143 #define CS_FLAG_SCHEME_SCALAR (1 << 0)
144 #define CS_FLAG_SCHEME_VECTOR (1 << 1)
145 #define CS_FLAG_SCHEME_NAVSTO (1 << 2)
146 #define CS_FLAG_SCHEME_POLY0 (1 << 3)
147 #define CS_FLAG_SCHEME_POLY1 (1 << 4)
148 #define CS_FLAG_SCHEME_POLY2 (1 << 5)
321 if ((flag_to_check & reference) == reference)
345 for (
int i = 0; i < n_masks; i++)
346 if ((flag_to_check & masks[i]) == masks[i])
369 if ((flag_to_check & reference) == reference)
Definition: cs_defs.h:509
unsigned short int cs_flag_t
Definition: cs_defs.h:321
const cs_flag_t cs_flag_primal_cell
Definition: cs_flag.c:58
Definition: cs_flag.h:126
Definition: cs_flag.h:123
const cs_eflag_t cs_flag_need_pfq
Definition: cs_flag.c:105
const cs_flag_t cs_flag_dual_face
Definition: cs_flag.c:62
Definition: cs_flag.h:124
const cs_flag_t cs_flag_cell
Definition: cs_flag.c:75
const cs_eflag_t cs_flag_need_e
Definition: cs_flag.c:90
const cs_eflag_t cs_flag_need_v
Definition: cs_flag.c:88
const cs_flag_t cs_flag_dual_closure_byf
Definition: cs_flag.c:68
cs_flag_location_t
Definition: cs_flag.h:285
@ CS_FLAG_LOCATION_DUAL_EDGE
Definition: cs_flag.h:292
@ CS_FLAG_LOCATION_DUAL_FACE
Definition: cs_flag.h:293
@ CS_FLAG_LOCATION_PRIMAL_FACE
Definition: cs_flag.h:289
@ CS_FLAG_N_LOCATIONS
Definition: cs_flag.h:296
@ CS_FLAG_LOCATION_PRIMAL_CELL
Definition: cs_flag.h:290
@ CS_FLAG_LOCATION_DUAL_CELL
Definition: cs_flag.h:294
@ CS_FLAG_LOCATION_PRIMAL_VTX
Definition: cs_flag.h:287
@ CS_FLAG_LOCATION_PRIMAL_EDGE
Definition: cs_flag.h:288
@ CS_FLAG_LOCATION_DUAL_VTX
Definition: cs_flag.h:291
static bool cs_flag_test(cs_flag_t flag_to_check, cs_flag_t reference)
Check if a two flag share the same pattern Return true if the flag to check has at least the pattern ...
Definition: cs_flag.h:318
const cs_flag_t cs_flag_dual_cell_byc
Definition: cs_flag.c:64
const cs_flag_t cs_flag_vertex
Definition: cs_flag.c:74
const cs_flag_t cs_flag_boundary_face
Definition: cs_flag.c:77
const cs_flag_t cs_flag_primal_edge
Definition: cs_flag.c:56
unsigned char cs_mask_t
Definition: cs_flag.h:158
Definition: cs_flag.h:128
const cs_eflag_t cs_flag_need_deq
Definition: cs_flag.c:108
const char * cs_flag_str_location(cs_flag_t loc)
Retrieve the label associated to a location flag.
Definition: cs_flag.c:130
const cs_eflag_t cs_flag_need_peq
Definition: cs_flag.c:101
const cs_eflag_t cs_flag_need_dfq
Definition: cs_flag.c:103
const cs_eflag_t cs_flag_need_pfc
Definition: cs_flag.c:110
const cs_eflag_t cs_flag_need_ef
Definition: cs_flag.c:99
Definition: cs_flag.h:125
const cs_eflag_t cs_flag_need_f
Definition: cs_flag.c:93
Definition: cs_flag.h:127
const cs_eflag_t cs_flag_need_fe
Definition: cs_flag.c:97
Definition: cs_flag.c:63
unsigned int cs_eflag_t
Definition: cs_flag.h:187
const cs_flag_t cs_flag_primal_face
Definition: cs_flag.c:57
static bool cs_flag_at_least(cs_flag_t flag_to_check, int n_masks, cs_flag_t masks[])
Check if a flag has in common at least one of the given masks Return true if the test is satisfied.
Definition: cs_flag.h:341
static bool cs_eflag_test(cs_eflag_t flag_to_check, cs_eflag_t reference)
Check if a two compute flag share the same pattern Return true if the computed flag to check has at l...
Definition: cs_flag.h:366
const cs_flag_t cs_flag_dual_vtx
Definition: cs_flag.c:60
cs_flag_comp_bits_t
Definition: cs_flag.h:202
@ CS_FLAG_COMP_DFQ
Definition: cs_flag.h:222
@ CS_FLAG_COMP_FV
Definition: cs_flag.h:250
@ CS_FLAG_COMP_PVQ
Definition: cs_flag.h:210
@ CS_FLAG_COMP_PE
Definition: cs_flag.h:214
@ CS_FLAG_COMP_FEQ
Definition: cs_flag.h:246
@ CS_FLAG_COMP_HFQ
Definition: cs_flag.h:264
@ CS_FLAG_COMP_PEC
Definition: cs_flag.h:277
@ CS_FLAG_COMP_PFQ
Definition: cs_flag.h:230
@ CS_FLAG_COMP_EF
Definition: cs_flag.h:254
@ CS_FLAG_COMP_PF
Definition: cs_flag.h:226
@ CS_FLAG_COMP_FES
Definition: cs_flag.h:268
@ CS_FLAG_COMP_EV
Definition: cs_flag.h:238
@ CS_FLAG_COMP_FE
Definition: cs_flag.h:242
@ CS_FLAG_COMP_PEQ
Definition: cs_flag.h:218
@ CS_FLAG_COMP_PV
Definition: cs_flag.h:206
@ CS_FLAG_COMP_PFC
Definition: cs_flag.h:273
@ CS_FLAG_COMP_DIAM
Definition: cs_flag.h:281
@ CS_FLAG_COMP_DEQ
Definition: cs_flag.h:234
@ CS_FLAG_COMP_SEF
Definition: cs_flag.h:259
const cs_flag_t cs_flag_dual_face_byc
Definition: cs_flag.c:66
const cs_flag_t cs_flag_primal_vtx
Definition: cs_flag.c:55
