8.0
cs_cdo_system.h
1 #ifndef __CS_CDO_SYSTEM_H__
2 #define __CS_CDO_SYSTEM_H__
5  * Structure and functions used to manipulate elementary structures related to
6  * the definition/usage of linear systems (objects manipulated with this
7  * structure are matrices, matrix strcutures and assemblers, range set and
8  * interface set for parallel synchronization/operations)
9  *============================================================================*/
11 /*
12  This file is part of code_saturne, a general-purpose CFD tool.
13
14  Copyright (C) 1998-2023 EDF S.A.
15
16  This program is free software; you can redistribute it and/or modify it under
17  the terms of the GNU General Public License as published by the Free Software
18  Foundation; either version 2 of the License, or (at your option) any later
19  version.
20
21  This program is distributed in the hope that it will be useful, but WITHOUT
22  ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
23  FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
24  details.
25
26  You should have received a copy of the GNU General Public License along with
27  this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
28  Street, Fifth Floor, Boston, MA 02110-1301, USA.
29 */
30
31 /*----------------------------------------------------------------------------*/
32
33 #include "cs_defs.h"
34
36  * Standard C library headers
38
39 /*----------------------------------------------------------------------------
40  * Local headers
41  *----------------------------------------------------------------------------*/
43 #include "cs_cdo_assembly.h"
44 #include "cs_cdo_connect.h"
45 #include "cs_param_types.h"
46 #include "cs_matrix.h"
47 #include "cs_matrix_assembler.h"
48 #include "cs_range_set.h"
49
50 /*----------------------------------------------------------------------------*/
51
53
55  * Macro definitions
57
59  * Type definitions
61
62 typedef enum {
63
69
91 typedef enum {
92
97
99
101
119 typedef enum {
120
125
127
129
130
131 typedef struct {
132
133  /* If the block is associated to one or several matrices, one keeps
134  * the information about the class of the matrix
135  */
136
138
139  /* An element is for instance a vertex, edge, face or cell */
140
143  int stride;
145  /* Description how is stored the matrix values for this block.
146  *
147  * When stride > 1, there are several options to store the matrix
148  * (all possibilities are not available up to now)
149  *
150  * unrolled: True means that a vector-valued DoF for instance is treated as
151  * a scalar-valued DoF which is three times larger.
152  *
153  * interlaced: True means that a vector-valued DoF is stored as follows:
154  * U0x U0y U0z U1x U1y U1z ... UNx UNy UNz
155  * false means that its representation is as follows:
156  * U0x U1x ... UNx U0y U1y ... UNy U0z U1z ... UNz
157  */
158
159  bool unrolled;
161
163
164
174 typedef struct {
175
176  /*
177  * \var matrix
178  * matrix of the system to solve
179  *
180  * \var matrix_class
181  * class of the matrix
182  *
183  * \var mav
184  * structure to manage the assembly of matrix values
185  *
186  * \var assembly_func
187  * function pointer to operate the assembly stage
188  *
189  * \var slave_assembly_func
190  * function pointer to operate the assembly stage when the system helper
191  * is declared as slave (this is the same for all matrices). Useful for
192  * coupled systems.
193  */
194
199
200  /* The following structures can be shared if the same block configuration
201  is requested */
202
207
209
210
218 typedef struct {
219
220  /*
221  * \var n_matrices
222  * number of matrices to consider
223  *
224  * \var matrices
225  * matrix of the system to solve (the matrix id in the list of matrices
226  * corresponding to the matrix at row i and column j is i*n_matrices+j)
227  *
228  * \var mav_array
229  * array of structures to manage the assembly of matrix values
230  *
231  * \var assembly_func
232  * function pointer to operate the assembly stage (this is the same for
233  * all matrices)
234  *
235  * \var slave_assembly_func
236  * function pointer to operate the assembly stage when the system helper
237  * is declared as slave (this is the same for all matrices)
238  */
239
245
246  /* The two following structures are always shared. They correspond to the
247  scalar-valued version. */
248
251
255
257
266 typedef struct {
267
286
288
289  /* The following structures can be shared if the same block configuration is
290  requested. In this case, shared_structures is set to true. By default,
291  there is no sharing. */
292
296
298
299
307 typedef struct {
308
309  /*
310  * \var matrix
311  * matrix of the system to solve
312  *
313  * \var mav
314  * structure to manage the assembly of matrix values
315  */
316
319
320  /* Private structures */
321
326
328
329
335 typedef struct {
336
337  /* \var info
338  * Set of metadata to describe the block
339  */
340
342
354
355  bool owner;
356
357  int id;
358
366
368
377 typedef struct {
378
415
419
421  cs_real_t *rhs; /* shared */
422  cs_real_t *_rhs; /* private */
424
425  int n_blocks;
427
429
430 /*============================================================================
431  * Inline public function prototypes
432  *============================================================================*/
433
434 /*----------------------------------------------------------------------------*/
442 /*----------------------------------------------------------------------------*/
443
444 static inline cs_cdo_system_matrix_class_t
446 {
447  switch (solver_class) {
448
451  break;
452
454 #if defined(HAVE_HYPRE)
456 #else
458 #endif
459  break;
460
461  default:
463  break;
464
465  }
466 }
467
468 /*============================================================================
469  * Public function prototypes
470  *============================================================================*/
471
472 /*----------------------------------------------------------------------------*/
480 /*----------------------------------------------------------------------------*/
481
482 void
484  cs_cdo_connect_t *connect);
485
486 /*----------------------------------------------------------------------------*/
499 /*----------------------------------------------------------------------------*/
500
503  int n_col_blocks,
504  const cs_lnum_t *col_block_sizes,
505  int n_blocks);
506
507 /*----------------------------------------------------------------------------*/
523 /*----------------------------------------------------------------------------*/
524
527  int block_id,
529  cs_flag_t location,
530  cs_lnum_t n_elements,
531  int stride,
532  bool interlaced,
533  bool unrolled);
534
535 /*----------------------------------------------------------------------------*/
549 /*----------------------------------------------------------------------------*/
550
553  int block_id,
555  cs_flag_t location,
556  cs_lnum_t n_elements,
557  int stride);
558
559 /*----------------------------------------------------------------------------*/
574 /*----------------------------------------------------------------------------*/
575
578  int block_id,
579  const cs_adjacency_t *adjacency,
580  cs_flag_t location,
581  cs_lnum_t n_elements,
582  int stride,
583  bool interlaced);
584
585 /*----------------------------------------------------------------------------*/
596 /*----------------------------------------------------------------------------*/
597
600  int block_id,
601  cs_lnum_t n_dofs);
602
603 /*----------------------------------------------------------------------------*/
612 /*----------------------------------------------------------------------------*/
613
616  int block_id);
617
618 /*----------------------------------------------------------------------------*/
632 /*----------------------------------------------------------------------------*/
633
634 cs_matrix_t *
636  int block_id);
637
638 /*----------------------------------------------------------------------------*/
652 /*----------------------------------------------------------------------------*/
653
654 cs_matrix_t *
656  int block_id,
657  int sub_id);
658
659 /*----------------------------------------------------------------------------*/
667 /*----------------------------------------------------------------------------*/
668
669 void
671  int block_id);
672
673 /*----------------------------------------------------------------------------*/
681 /*----------------------------------------------------------------------------*/
682
683 void
685  cs_real_t **p_rhs);
686
687 /*----------------------------------------------------------------------------*/
693 /*----------------------------------------------------------------------------*/
694
695 void
697
698 /*----------------------------------------------------------------------------*/
704 /*----------------------------------------------------------------------------*/
705
706 void
708
709 /*----------------------------------------------------------------------------*/
715 /*----------------------------------------------------------------------------*/
716
717 void
719
720 /*----------------------------------------------------------------------------*/
725 /*----------------------------------------------------------------------------*/
726
727 void
729
730 /*----------------------------------------------------------------------------*/
734 /*----------------------------------------------------------------------------*/
735
736 void
738
739 /*----------------------------------------------------------------------------*/
740
742
743 #endif /* __CS_CDO_SYSTEM_H__ */
void() cs_cdo_assembly_func_t(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise matrix into the global matrix Block or no block versions are handled.
Definition: cs_cdo_assembly.h:72
cs_cdo_system_block_t * cs_cdo_system_add_xblock(cs_cdo_system_helper_t *sh, int block_id, cs_lnum_t n_dofs)
Add an external block definition at position "block_id" in the helper structure. Only metadata are se...
Definition: cs_cdo_system.c:1494
void cs_cdo_system_helper_free(cs_cdo_system_helper_t **p_helper)
Free a cs_cdo_system_helper_t structure.
Definition: cs_cdo_system.c:1131
void cs_cdo_system_helper_finalize_assembly(cs_cdo_system_helper_t *sh)
Finalize the assembly after the cellwise building and assembly.
Definition: cs_cdo_system.c:1975
void cs_cdo_system_init_sharing(cs_mesh_t *mesh, cs_cdo_connect_t *connect)
Allocate and initialize matrix-related structures according to the type of discretization used for th...
Definition: cs_cdo_system.c:1054
cs_cdo_system_block_type_t
type of block composing a (block) matrix
Definition: cs_cdo_system.h:91
@ CS_CDO_SYSTEM_BLOCK_EXT
Definition: cs_cdo_system.h:96
@ CS_CDO_SYSTEM_N_BLOCK_TYPES
Definition: cs_cdo_system.h:98
@ CS_CDO_SYSTEM_BLOCK_DEFAULT
Definition: cs_cdo_system.h:93
@ CS_CDO_SYSTEM_BLOCK_UNASS
Definition: cs_cdo_system.h:95
@ CS_CDO_SYSTEM_BLOCK_SPLIT
Definition: cs_cdo_system.h:94
void cs_cdo_system_helper_reset(cs_cdo_system_helper_t *sh)
Free matrix and rhs after the solve step.
Definition: cs_cdo_system.c:2036
void cs_cdo_system_allocate_assembly(void)
Initialize shared assembly structures from the existing helper structures.
Definition: cs_cdo_system.c:2101
Class of matrices to consider.
Definition: cs_cdo_system.h:119
@ CS_CDO_SYSTEM_MATRIX_HYPRE
Definition: cs_cdo_system.h:124
@ CS_CDO_SYSTEM_N_MATRIX_CLASSES
Definition: cs_cdo_system.h:126
@ CS_CDO_SYSTEM_MATRIX_NONE
Definition: cs_cdo_system.h:121
@ CS_CDO_SYSTEM_MATRIX_CS
Definition: cs_cdo_system.h:122
@ CS_CDO_SYSTEM_MATRIX_PETSC
Definition: cs_cdo_system.h:123
void cs_cdo_system_destroy_all(void)
Free all members associated to system helpers.
Definition: cs_cdo_system.c:2158
cs_cdo_system_type_t
Definition: cs_cdo_system.h:62
@ CS_CDO_SYSTEM_COUPLED
Definition: cs_cdo_system.h:65
@ CS_CDO_SYSTEM_SADDLE_POINT
Definition: cs_cdo_system.h:66
@ CS_CDO_SYSTEM_DEFAULT
Definition: cs_cdo_system.h:64
static cs_cdo_system_matrix_class_t cs_cdo_system_get_matrix_class(cs_param_sles_class_t solver_class)
Get the best available class of matrix w.r.t. the solver class.
Definition: cs_cdo_system.h:445
cs_cdo_system_block_t * cs_cdo_system_add_sblock(cs_cdo_system_helper_t *sh, int block_id, cs_cdo_system_matrix_class_t matclass, cs_flag_t location, cs_lnum_t n_elements, int stride)
Add a split block definition at position "block_id" in the helper structure. Only metadata are set at...
Definition: cs_cdo_system.c:1275
void cs_cdo_system_helper_init_system(cs_cdo_system_helper_t *sh, cs_real_t **p_rhs)
Allocate and initialize the matrix, rhs and the matrix assembler values.
Definition: cs_cdo_system.c:1802
cs_matrix_t * cs_cdo_system_get_matrix(const cs_cdo_system_helper_t *sh, int block_id)
Retrieve the matrix associated to the given block_id. If the type of block is either CS_CDO_SYSTEM_BL...
Definition: cs_cdo_system.c:1630
cs_cdo_system_block_t * cs_cdo_system_add_ublock(cs_cdo_system_helper_t *sh, int block_id, const cs_adjacency_t *adjacency, cs_flag_t location, cs_lnum_t n_elements, int stride, bool interlaced)
Add an unassembled block definition at position "block_id" in the helper structure Only metadata are ...
Definition: cs_cdo_system.c:1406
cs_matrix_t * cs_cdo_system_get_sub_matrix(cs_cdo_system_helper_t *sh, int block_id, int sub_id)
Retrieve the (sub-)matrix associated to a split block with id equal to block_id. sub_id is the id in ...
Definition: cs_cdo_system.c:1682
cs_range_set_t * cs_cdo_system_get_range_set(const cs_cdo_system_helper_t *sh, int block_id)
Retrieve the range set structure associated to the given block_id.
Definition: cs_cdo_system.c:1564
void cs_cdo_system_build_block(cs_cdo_system_helper_t *sh, int block_id)
Build the associated structures for the given system_helper structure If a member is already allocate...
Definition: cs_cdo_system.c:1723
cs_cdo_system_block_t * cs_cdo_system_add_dblock(cs_cdo_system_helper_t *sh, int block_id, cs_cdo_system_matrix_class_t matclass, cs_flag_t location, cs_lnum_t n_elements, int stride, bool interlaced, bool unrolled)
Definition: cs_cdo_system.c:1174
cs_cdo_system_helper_t * cs_cdo_system_helper_create(cs_cdo_system_type_t type, int n_col_blocks, const cs_lnum_t *col_block_sizes, int n_blocks)
Create a system_helper structure from its set of metadata. n_col_blocks and n_blocks may differ accor...
Definition: cs_cdo_system.c:1079
Definition: cs_defs.h:509
Definition: cs_defs.h:319
Definition: cs_defs.h:313
unsigned short int cs_flag_t
Definition: cs_defs.h:321
Definition: cs_interface.h:61
struct _cs_matrix_structure_t cs_matrix_structure_t
Definition: cs_matrix.h:106
Definition: cs_matrix.h:110
Definition: cs_param_types.h:585
@ CS_PARAM_SLES_CLASS_HYPRE
Definition: cs_param_types.h:588
@ CS_PARAM_SLES_CLASS_CS
Definition: cs_param_types.h:587
Definition: mesh.f90:26
Definition: cs_cdo_system.h:131
int stride
Definition: cs_cdo_system.h:143
cs_cdo_system_matrix_class_t matrix_class
Definition: cs_cdo_system.h:137
cs_flag_t location
Definition: cs_cdo_system.h:141
bool interlaced
Definition: cs_cdo_system.h:160
Definition: cs_cdo_system.h:142
bool unrolled
Definition: cs_cdo_system.h:159
Definition: cs_cdo_system.h:335
void * block_pointer
Definition: cs_cdo_system.h:365
cs_cdo_system_block_info_t info
Definition: cs_cdo_system.h:341
cs_cdo_system_block_type_t type
Definition: cs_cdo_system.h:353
int id
Definition: cs_cdo_system.h:357
bool owner
Definition: cs_cdo_system.h:355
Structure associated to the default type of block.
Definition: cs_cdo_system.h:174
cs_matrix_t * matrix
Definition: cs_cdo_system.h:195
cs_cdo_assembly_func_t * slave_assembly_func
Definition: cs_cdo_system.h:198
cs_interface_set_t * interface_set
Definition: cs_cdo_system.h:204
cs_matrix_assembler_values_t * mav
Definition: cs_cdo_system.h:196
cs_range_set_t * range_set
Definition: cs_cdo_system.h:203
cs_matrix_assembler_t * matrix_assembler
Definition: cs_cdo_system.h:205
cs_cdo_assembly_func_t * assembly_func
Definition: cs_cdo_system.h:197
cs_matrix_structure_t * matrix_structure
Definition: cs_cdo_system.h:206
Definition: cs_cdo_system.h:377
cs_real_t ** rhs_array
Definition: cs_cdo_system.h:423
cs_lnum_t * col_block_sizes
Definition: cs_cdo_system.h:417
Definition: cs_cdo_system.h:414
cs_cdo_system_block_t ** blocks
Definition: cs_cdo_system.h:426
cs_lnum_t full_rhs_size
Definition: cs_cdo_system.h:420
cs_lnum_t * max_col_block_sizes
Definition: cs_cdo_system.h:418
cs_real_t * _rhs
Definition: cs_cdo_system.h:422
int n_col_blocks
Definition: cs_cdo_system.h:416
cs_real_t * rhs
Definition: cs_cdo_system.h:421
int n_blocks
Definition: cs_cdo_system.h:425
Structure associated to the split type of block.
Definition: cs_cdo_system.h:218
bool matrix_struct_ownership
Definition: cs_cdo_system.h:252
Definition: cs_cdo_system.h:244
Definition: cs_cdo_system.h:250
int n_matrices
Definition: cs_cdo_system.h:240
cs_matrix_assembler_values_t ** mav_array
Definition: cs_cdo_system.h:242
cs_matrix_t ** matrices
Definition: cs_cdo_system.h:241
Definition: cs_cdo_system.h:249
Definition: cs_cdo_system.h:253
Definition: cs_cdo_system.h:243
Definition: cs_cdo_system.h:254
Structure associated to the unassembled type of block.
Definition: cs_cdo_system.h:266
bool shared_structures
Definition: cs_cdo_system.h:293
const cs_adjacency_t * adjacency
Definition: cs_cdo_system.h:287
cs_real_t * values
Definition: cs_cdo_system.h:284
cs_real_t * _values
Definition: cs_cdo_system.h:285
Definition: cs_cdo_system.h:295
Definition: cs_cdo_system.h:294
Structure associated to the extended type of block.
Definition: cs_cdo_system.h:307
Definition: cs_cdo_system.h:317
Definition: cs_cdo_system.h:323
Definition: cs_cdo_system.h:318
Definition: cs_cdo_system.h:322
Definition: cs_cdo_system.h:324
Definition: cs_cdo_system.h:325
Definition: cs_mesh.h:85
Definition: cs_range_set.h:57
