1 #ifndef __CS_CDO_BC_H__
2 #define __CS_CDO_BC_H__
46 #define CS_CDO_BC_DEFAULT_DEF -1
61 #define CS_CDO_BC_NEUMANN (1 << 0)
65 #define CS_CDO_BC_FULL_NEUMANN (1 << 1)
69 #define CS_CDO_BC_HMG_NEUMANN (1 << 2)
73 #define CS_CDO_BC_DIRICHLET (1 << 3)
77 #define CS_CDO_BC_HMG_DIRICHLET (1 << 4)
81 #define CS_CDO_BC_ROBIN (1 << 5)
85 #define CS_CDO_BC_SLIDING (1 << 6)
89 #define CS_CDO_BC_TANGENTIAL_DIRICHLET (1 << 7)
93 #define CS_CDO_BC_WALL_PRESCRIBED (1 << 8)
183 " %s: Empty desciption buffer.", __func__);
188 sprintf(desc,
"%s",
"Homogenous Dirichlet");
191 sprintf(desc,
"%s",
"Dirichlet");
194 sprintf(desc,
"%s",
"Homogeneous Neumann");
197 sprintf(desc,
"%s",
"Neumann");
200 sprintf(desc,
"%s",
"Full Neumann");
203 sprintf(desc,
"%s",
"Robin");
206 sprintf(desc,
"%s",
"Sliding");
209 sprintf(desc,
"%s",
"Dirichlet on the tangential component");
214 "%s: Invalid case. Please contact the support.\n", __func__);
Definition: bft_error.c:193
static void cs_cdo_bc_get_desc(cs_flag_t bc_flag, char *desc)
Convert a flag into a description.
Definition: cs_cdo_bc.h:178
static bool cs_cdo_bc_is_circulation(cs_flag_t flag)
Check if a flag is associated to a Dirichlet BC (homogeneous or not)
Definition: cs_cdo_bc.h:347
static cs_flag_t cs_cdo_bc_get_flag(cs_param_bc_type_t bc_type)
Convert a cs_param_bc_type_t into a flag (enable multiple type for a same entity as required for vert...
Definition: cs_cdo_bc.h:231
static bool cs_cdo_bc_is_neumann(cs_flag_t flag)
Check if a flag is associated to a Neumann BC (homogeneous or not)
Definition: cs_cdo_bc.h:306
static bool cs_cdo_bc_is_dirichlet(cs_flag_t flag)
Definition: cs_cdo_bc.h:285
static bool cs_cdo_bc_is_sliding(cs_flag_t flag)
Check if a flag is associated to a sliding boundary.
Definition: cs_cdo_bc.h:327
cs_cdo_bc_face_t * cs_cdo_bc_free(cs_cdo_bc_face_t *face_bc)
Free a cs_cdo_bc_face_t structure.
Definition: cs_cdo_bc.c:349
cs_cdo_bc_face_t * cs_cdo_bc_face_define(cs_param_bc_type_t default_bc, bool is_steady, int dim, int n_defs, cs_xdef_t **defs, cs_lnum_t n_b_faces)
Define the structure which translates the BC definitions from the user viewpoint into a ready-to-use ...
Definition: cs_cdo_bc.c:150
Definition: cs_defs.h:509
Definition: cs_defs.h:313
unsigned short int cs_flag_t
Definition: cs_defs.h:321
cs_param_bc_type_t
Definition: cs_param_types.h:475
@ CS_PARAM_BC_SLIDING
Definition: cs_param_types.h:483
@ CS_PARAM_BC_ROBIN
Definition: cs_param_types.h:482
@ CS_PARAM_BC_NEUMANN
Definition: cs_param_types.h:480
@ CS_PARAM_BC_DIRICHLET
Definition: cs_param_types.h:478
@ CS_PARAM_BC_HMG_DIRICHLET
Definition: cs_param_types.h:477
@ CS_PARAM_BC_NEUMANN_FULL
Definition: cs_param_types.h:481
@ CS_PARAM_BC_CIRCULATION
Definition: cs_param_types.h:484
@ CS_PARAM_BC_WALL_PRESCRIBED
Definition: cs_param_types.h:485
@ CS_PARAM_BC_HMG_NEUMANN
Definition: cs_param_types.h:479
Definition: cs_cdo_bc.h:93
Definition: cs_cdo_bc.h:77
Definition: cs_cdo_bc.h:81
Definition: cs_cdo_bc.h:65
Definition: cs_cdo_bc.h:89
Definition: cs_cdo_bc.h:61
Definition: cs_cdo_bc.h:85
Definition: cs_cdo_bc.h:73
Definition: cs_cdo_bc.h:69
Definition: cs_cdo_bc.h:109
cs_lnum_t * hmg_dir_ids
Definition: cs_cdo_bc.h:132
cs_lnum_t n_robin_faces
Definition: cs_cdo_bc.h:145
cs_lnum_t n_sliding_faces
Definition: cs_cdo_bc.h:150
cs_flag_t * flag
Definition: cs_cdo_bc.h:117
cs_lnum_t n_nhmg_neu_faces
Definition: cs_cdo_bc.h:140
cs_lnum_t n_b_faces
Definition: cs_cdo_bc.h:113
cs_lnum_t * nhmg_neu_ids
Definition: cs_cdo_bc.h:141
cs_lnum_t n_hmg_neu_faces
Definition: cs_cdo_bc.h:138
cs_lnum_t * sliding_ids
Definition: cs_cdo_bc.h:151
cs_lnum_t n_circulation_faces
Definition: cs_cdo_bc.h:155
cs_lnum_t n_nhmg_dir_faces
Definition: cs_cdo_bc.h:133
cs_lnum_t * robin_ids
Definition: cs_cdo_bc.h:146
bool is_steady
Definition: cs_cdo_bc.h:111
cs_lnum_t * nhmg_dir_ids
Definition: cs_cdo_bc.h:134
cs_lnum_t * circulation_ids
Definition: cs_cdo_bc.h:156
cs_lnum_t * hmg_neu_ids
Definition: cs_cdo_bc.h:139
short int * def_ids
Definition: cs_cdo_bc.h:122
cs_lnum_t n_hmg_dir_faces
Definition: cs_cdo_bc.h:131
Definition: cs_xdef.h:160
