#include <cs_gwf_tracer.h>
Collaboration diagram for cs_gwf_tracer_t:Data Fields | |
Physical modelling information for a tracer | |
| cs_gwf_model_type_t | hydraulic_model |
| cs_gwf_tracer_model_t | model |
| cs_field_t * | diffusivity |
| int | reaction_id |
Other members | |
| cs_equation_t * | equation |
| void * | context |
| int | chain_position_id |
| int | chain_id |
Function pointers associated to a tracer | |
| cs_gwf_tracer_update_t * | update_diff_pty |
| cs_gwf_tracer_update_t * | update_precipitation |
| cs_gwf_tracer_update_t * | update_decay_chain_st |
| cs_gwf_tracer_integrate_t * | integrate |
| cs_gwf_tracer_init_setup_t * | init_setup |
| cs_gwf_tracer_finalize_setup_t * | finalize_setup |
| cs_gwf_tracer_free_context_t * | free_context |
| chain_id |
id in the array of decay chains. (-1 if not associated to a decay chain; this is the default behavior)
| chain_position_id |
Position of the current tracer inside a decay chain. The default value is -1 meaning that this is not a tracer associated to a decay chain.
| context |
Pointer to a context structure cast on-the-fly according to the model.
| diffusivity |
Field related to the property associated to the diffusion term. NULL if no diffusion term is build in the tracer equation.
| equation |
Pointer to the related equation structure
| finalize_setup |
This is a function pointer to finalize the setup of a tracer equation. There is a function pointer by default but this can be overloaded by a user-defined function in the case of a user-defined tracer.
| free_context |
Function to free quantities or structure associated to the context structure of a tracer.
| hydraulic_model |
Type of hydraulic model to consider. This is an information shared with the main gorundwater flow structure
| init_setup |
This is a function pointer to initialize the setup (adding terms in an equation). At this stage, the mesh has not been loaded. There is a function pointer by default but this can be overloaded by a user-defined function in the case of a user-defined tracer.
| integrate |
Function to compute the quantity of tracer inside a volume. The way to compute this quantity may be optimized according to the hydraulic model or the tracer modelling.
| model |
Type of tracer model to consider. 0 corresponds to the default behavior.
| reaction_id |
Since there can be several reaction terms associated to an equation. One stores the id related to the reaction term wich is automatically added when a radioactive tracer is considered.
Function used to update the source term induced by the parent in a decay chain
| update_diff_pty |
Function used to update the diffusion property which is a tensor in the most generic case (dispersion + diffusion)
Function used to update the quantities related to the precipitation model
