7.3
cs_gwf_tracer.h
1 #ifndef __CS_GWF_TRACER_H__
2 #define __CS_GWF_TRACER_H__
5  * Set of main functions to handle soils in the groundwater flow module
6  * when using CDO schemes
8
9 /*
10  This file is part of code_saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2022 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 /*----------------------------------------------------------------------------
32  * Local headers
33  *----------------------------------------------------------------------------*/
34
35 #include "cs_advection_field.h"
36 #include "cs_base.h"
37 #include "cs_equation.h"
38 #include "cs_gwf_param.h"
45  * Typedef definition
53 typedef struct _gwf_tracer_t cs_gwf_tracer_t;
54
55 /* \struct cs_gwf_tracer_default_context_t
56  *
57  * \brief Set of parameters related to a tracer equation attached to a standard
58  * modelling
59  */
60
61 typedef struct _gwf_tracer_default_context_t cs_gwf_tracer_default_context_t;
62
63 /*============================================================================
64  * Public function pointer prototypes
65  *============================================================================*/
66
67 /*----------------------------------------------------------------------------*/
75
76 typedef void
78
79 /*----------------------------------------------------------------------------*/
91
92 typedef void
94  const cs_cdo_quantities_t *quant,
95  const cs_adv_field_t *adv,
96  cs_gwf_tracer_t *tracer);
97
98 /*----------------------------------------------------------------------------*/
110 /*----------------------------------------------------------------------------*/
111
112 typedef void
114  void *context,
115  const cs_time_step_t *ts,
116  const cs_mesh_t *mesh,
117  const cs_cdo_connect_t *connect,
118  const cs_cdo_quantities_t *quant);
119
120 /*----------------------------------------------------------------------------*/
126 /*----------------------------------------------------------------------------*/
127
128 typedef void
130
131 /*----------------------------------------------------------------------------*/
147
148 typedef void
150  const cs_cdo_quantities_t *cdoq,
151  const cs_equation_t *eq,
152  const cs_zone_t *zone,
153  void *context,
154  double results[]);
155
156 /*============================================================================
157  * Structure definitions
158  *============================================================================*/
159
160 /* Structure to handle of radioactive decay chain */
161
162 typedef struct {
163
164  char *name; /* Name of the decay chain */
165  int id; /* Position in the array of chain decays */
166
167  int n_tracers; /* Number of tracers in the decay chain */
168  cs_gwf_tracer_unit_t unit; /* Type of unit measure:
169  * - mole (classical tracer)
170  * - Becquerel (activity)
171  */
172
173  cs_gwf_tracer_t **tracers; /* Array of tracers associated to the
174  decay chain. tracers[0] is the parent
175  without any ancestor. */
176
177  cs_xdef_t **st_defs; /* List of source term definitions */
178
180
181 /* Set of parameters related to a tracer equation attached to a standard
182  modelling */
183
185
186  /* Common settings shared by all physical modelling */
187  /* ------------------------------------------------ */
188
189  double decay_coef; /* First order decay coefficient (related to the
190  reaction term). This value is intrinsic to the
191  component (a radioactive element for instance)
192  and not to the soil. */
193
194  /* The following parameters are defined for each soil (arrays of size equal
195  * to n_soils) */
196
197  double *rho_bulk; /* bulk density (kg.m^-3) */
198  double *kd0; /* reference value of the distribution coefficient
199  (m^".kg^-1) */
200  double *rho_kd; /* Derived quantity: rho_bulk*kd0 */
201
202  double *alpha_l; /* Longitudinal dispersivity */
203  double *alpha_t; /* Transversal dispersivity */
204
205  double *wmd; /* Water molecular diffusivity (m^2.s^-1) */
206
207  /* Precipitation members (set to NULL if not used) */
208  /* ----------------------------------------------- */
209
210  double *conc_l_star; /* maximal value of the concentraction of
211  * tracer in the liquid phase in mol/m^3. There
212  * is one user-defined value for each soil. The
213  * exceeded quantities are stored in the solid
214  * phase (-> precip_mass). These values
215  * corresponds to the user settings
216  */
217
218  cs_real_t *precip_mass; /* array storing the mass of precipitate
219  * (solid) in the dedicated auxiliary
220  * storage. The size of this array may vary
221  * w.r.t. to the discretization scheme.
222  */
223
224  cs_field_t *precip_field; /* Field structure storing the (interpolated)
225  * values of the concentration of precipitate
226  * in mol/kg in each cell.
227  */
228
229  /* Sorption members (set to NULL if not used) */
230  /* ------------------------------------------ */
231
232  double *k0_plus; /* kinetic coefficient towards site 2 locations
233  (m^3.kg^-1.s^-1) */
234  double *k0_minus; /* kinetic coefficient from site 2 locations
235  (s^-1) */
236
237  cs_real_t *conc_site2; /* array allocated to n_cells */
238
239  /* Variables used for the update of physical properties (shared pointers) */
240
242
243 };
244
245 /* Set of parameters describing a tracer structure */
246 /* ----------------------------------------------- */
247
249
261
268
275
283
295
301  void *context;
302
310
316  int chain_id;
317
362
364
368
372 };
373
374 /*============================================================================
375  * Public function prototypes
376  *============================================================================*/
377
378 /*----------------------------------------------------------------------------*/
387 /*----------------------------------------------------------------------------*/
388
390 cs_gwf_tracer_by_name(const char *eq_name);
391
392 /*----------------------------------------------------------------------------*/
418 /*----------------------------------------------------------------------------*/
419
422  cs_gwf_model_type_t gwf_model,
423  const char *eq_name,
424  const char *var_name,
425  cs_adv_field_t *adv_field,
426  double lambda,
427  int chain_position,
428  int chain_id,
429  cs_gwf_tracer_init_setup_t *init_setup,
430  cs_gwf_tracer_finalize_setup_t *finalize_setup);
431
432 /*----------------------------------------------------------------------------*/
436 /*----------------------------------------------------------------------------*/
437
438 void
440
441 /*----------------------------------------------------------------------------*/
448 /*----------------------------------------------------------------------------*/
449
450 cs_real_t
452
453 /*----------------------------------------------------------------------------*/
466 /*----------------------------------------------------------------------------*/
467
468 void
470  const char *soil_name,
471  double wmd,
472  double alpha_l,
473  double alpha_t,
474  double distrib_coef);
475
476 /*----------------------------------------------------------------------------*/
487 /*----------------------------------------------------------------------------*/
488
489 void
491  const char *soil_name,
492  double conc_l_star);
493
494 /*----------------------------------------------------------------------------*/
500 /*----------------------------------------------------------------------------*/
501
502 void
504
505 /*----------------------------------------------------------------------------*/
512 /*----------------------------------------------------------------------------*/
513
514 void
516  const cs_cdo_quantities_t *quant);
517
518 /*----------------------------------------------------------------------------*/
529 /*----------------------------------------------------------------------------*/
530
531 void
533  const cs_mesh_t *mesh,
534  const cs_cdo_connect_t *connect,
535  const cs_cdo_quantities_t *quant);
536
537 /*----------------------------------------------------------------------------*/
541 /*----------------------------------------------------------------------------*/
542
543 void
545
546 /*----------------------------------------------------------------------------*/
556 /*----------------------------------------------------------------------------*/
557
558 void
560  const cs_time_step_t *time_step,
561  const cs_cdo_connect_t *connect,
562  const cs_cdo_quantities_t *cdoq);
563
564 /*----------------------------------------------------------------------------*/
574 /*----------------------------------------------------------------------------*/
575
576 void
578  const cs_time_step_t *time_step,
579  const cs_cdo_connect_t *connect,
580  const cs_cdo_quantities_t *cdoq);
581
582 /*----------------------------------------------------------------------------*/
591 /*----------------------------------------------------------------------------*/
592
593 void
595
596 /*----------------------------------------------------------------------------*/
606 /*----------------------------------------------------------------------------*/
607
608 void
610  const cs_cdo_quantities_t *quant,
611  const cs_adv_field_t *adv,
612  cs_gwf_tracer_t *tracer);
613
614 /*----------------------------------------------------------------------------*/
624 /*----------------------------------------------------------------------------*/
625
626 void
628  const cs_cdo_quantities_t *quant,
629  const cs_adv_field_t *adv,
630  cs_gwf_tracer_t *tracer);
631
632 /*----------------------------------------------------------------------------*/
648 /*----------------------------------------------------------------------------*/
649
650 double
652  const cs_cdo_quantities_t *cdoq,
653  const cs_gwf_tracer_t *tracer,
654  const char *z_name);
655
656 /*----------------------------------------------------------------------------*/
674 /*----------------------------------------------------------------------------*/
675
676 void
678  const cs_cdo_quantities_t *cdoq,
679  const cs_gwf_tracer_t *tracer,
680  const char *z_name,
681  double results[]);
682
683 /*----------------------------------------------------------------------------*/
693 /*----------------------------------------------------------------------------*/
694
697  const char *chain_name,
698  cs_gwf_tracer_unit_t unit);
699
700 /*----------------------------------------------------------------------------*/
709 /*----------------------------------------------------------------------------*/
710
713
714 /*----------------------------------------------------------------------------*/
723 /*----------------------------------------------------------------------------*/
724
726 cs_gwf_tracer_decay_chain_by_name(const char *chain_name);
727
728 /*----------------------------------------------------------------------------*/
729
731
732 #endif /* __CS_GWF_TRACER_H__ */
int reaction_id
Definition: cs_gwf_tracer.h:282
cs_gwf_model_type_t hydraulic_model
Definition: cs_gwf_tracer.h:260
double * conc_l_star
Definition: cs_gwf_tracer.h:210
time step descriptor
Definition: cs_time_step.h:64
void cs_gwf_tracer_default_init_setup(cs_gwf_tracer_t *tracer)
Add terms to the algebraic system related to a tracer equation according to the settings. Case of the default tracer modelling Rely on the generic function: cs_gwf_tracer_add_terms_t.
Definition: cs_gwf_tracer.c:2544
cs_gwf_tracer_update_t * update_diff_pty
Definition: cs_gwf_tracer.h:359
Definition: cs_advection_field.h:150
void cs_gwf_tracer_sat_finalize_setup(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, cs_gwf_tracer_t *tracer)
Set the parameters related to a standard tracer equation case of a fully saturated flow model...
Definition: cs_gwf_tracer.c:2706
Definition: cs_field.h:130
void cs_gwf_tracer_update_diff_pty(const cs_time_step_t *ts, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Update the diffusion property related to each tracer equation The update strategy depends on the soil...
Definition: cs_gwf_tracer.c:2329
Definition: cs_field_pointer.h:106
cs_gwf_tracer_decay_chain_t * cs_gwf_tracer_decay_chain_by_id(int id)
Retrieve the decay chain structure associated to the given id If not found, it returns the NULL point...
Definition: cs_gwf_tracer.c:3108
double * k0_plus
Definition: cs_gwf_tracer.h:232
double cs_gwf_tracer_integrate(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_gwf_tracer_t *tracer, const char *z_name)
Compute the integral of the tracer concentration over a given set of cells. This integral gives the n...
Definition: cs_gwf_tracer.c:2975
cs_gwf_tracer_t * cs_gwf_tracer_add(cs_gwf_tracer_model_t tr_model, cs_gwf_model_type_t gwf_model, const char *eq_name, const char *var_name, cs_adv_field_t *adv_field, double lambda, int chain_position, int chain_id, cs_gwf_tracer_init_setup_t *init_setup, cs_gwf_tracer_finalize_setup_t *finalize_setup)
Create a new cs_gwf_tracer_t structure and initialize its members. This creation of a new tracer is f...
Definition: cs_gwf_tracer.c:1953
double decay_coef
Definition: cs_gwf_tracer.h:189
cs_field_t * precip_field
Definition: cs_gwf_tracer.h:224
Definition: cs_defs.h:512
void cs_gwf_tracer_log_all(void)
Display the main features related to each tracer.
Definition: cs_gwf_tracer.c:2361
void() cs_gwf_tracer_integrate_t(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_equation_t *eq, const cs_zone_t *zone, void *context, double results[])
Compute the quantity of tracer using an integral of the tracer concentration over a given set of cell...
Definition: cs_gwf_tracer.h:149
void cs_gwf_tracer_set_precip_param(cs_gwf_tracer_t *tracer, const char *soil_name, double conc_l_star)
For a specified soil set the parameters corresponding to a precipitation modelling of a tracer transp...
Definition: cs_gwf_tracer.c:2162
int chain_position_id
Definition: cs_gwf_tracer.h:309
void cs_gwf_tracer_unsat_finalize_setup(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, cs_gwf_tracer_t *tracer)
Set the parameters related to a standard tracer equation in case of an unsaturated flow model...
Definition: cs_gwf_tracer.c:2846
double * kd0
Definition: cs_gwf_tracer.h:198
cs_gwf_tracer_finalize_setup_t * finalize_setup
Definition: cs_gwf_tracer.h:366
int chain_id
Definition: cs_gwf_tracer.h:316
cs_gwf_tracer_update_t * update_decay_chain_st
Definition: cs_gwf_tracer.h:361
cs_real_t * conc_site2
Definition: cs_gwf_tracer.h:237
void() cs_gwf_tracer_finalize_setup_t(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, cs_gwf_tracer_t *tracer)
Generic function to finalize the setup of parameters related to a tracer equation. At this stage, mesh and its related quantities have been built.
Definition: cs_gwf_tracer.h:93
cs_gwf_model_type_t
Definition: cs_gwf_param.h:118
cs_gwf_tracer_integrate_t * integrate
Definition: cs_gwf_tracer.h:363
void cs_gwf_tracer_integrate_by_terms(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_gwf_tracer_t *tracer, const char *z_name, double results[])
Compute the quantity of tracer using the integral of the tracer concentration over a given set of cel...
Definition: cs_gwf_tracer.c:3019
Definition: cs_defs.h:322
Definition: cs_cdo_quantities.h:132
Type of unit for the expression of the radioactive inventory.
Definition: cs_gwf_param.h:102
Definition: cs_mesh.h:85
void cs_gwf_tracer_free_all(void)
Free all tracer structures and all decay chains.
Definition: cs_gwf_tracer.c:2009
cs_real_t cs_gwf_tracer_get_time_theta_max(void)
Retrieve the max. value of the theta parameter associated to a time scheme. Loop on all tracer equati...
Definition: cs_gwf_tracer.c:2060
cs_xdef_t ** st_defs
Definition: cs_gwf_tracer.h:177
void cs_gwf_tracer_set_soil_param(cs_gwf_tracer_t *tracer, const char *soil_name, double wmd, double alpha_l, double alpha_t, double distrib_coef)
Set the main parameters corresponding to a default modelling of a tracer transport equation for a spe...
Definition: cs_gwf_tracer.c:2099
cs_gwf_tracer_model_t model
Definition: cs_gwf_tracer.h:267
cs_gwf_tracer_free_context_t * free_context
Definition: cs_gwf_tracer.h:367
double * wmd
Definition: cs_gwf_tracer.h:205
cs_gwf_tracer_init_setup_t * init_setup
Definition: cs_gwf_tracer.h:365
void cs_gwf_tracer_init_setup(void)
Initial setup step for tracer equations. Soils and equation parameters are defined at this stage...
Definition: cs_gwf_tracer.c:2206
void() cs_gwf_tracer_init_setup_t(cs_gwf_tracer_t *tracer)
Generic function to update the first setup stage (the one done before building mesh and its related q...
Definition: cs_gwf_tracer.h:77
Definition: cs_xdef.h:155
void * context
Definition: cs_gwf_tracer.h:301
cs_gwf_tracer_decay_chain_t * cs_gwf_tracer_create_decay_chain(int n_tracers, const char *chain_name, cs_gwf_tracer_unit_t unit)
Create a decay chain structure to manage several linked tracers.
Definition: cs_gwf_tracer.c:3057
cs_gwf_tracer_t ** tracers
Definition: cs_gwf_tracer.h:173
double * k0_minus
Definition: cs_gwf_tracer.h:234
int n_tracers
Definition: cs_gwf_tracer.h:167
void cs_gwf_tracer_compute_all(const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Compute the new (unsteady) state for all tracer equations. Nothing is done if all equations are stead...
Definition: cs_gwf_tracer.c:2489
Definition: cs_gwf_tracer.h:168
double * alpha_t
Definition: cs_gwf_tracer.h:203
cs_gwf_tracer_update_t * update_precipitation
Definition: cs_gwf_tracer.h:360
Definition: cs_defs.h:513
const cs_field_t * darcy_velocity_field
Definition: cs_gwf_tracer.h:241
cs_real_t * precip_mass
Definition: cs_gwf_tracer.h:218
cs_equation_t * equation
Definition: cs_gwf_tracer.h:294
double * rho_bulk
Definition: cs_gwf_tracer.h:197
void cs_gwf_tracer_compute_steady_all(const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Compute the steady-state for all tracer equations. Nothing is done if all equations are unsteady...
Definition: cs_gwf_tracer.c:2440
cs_field_t * diffusivity
Definition: cs_gwf_tracer.h:274
char * name
Definition: cs_gwf_tracer.h:164
Definition: cs_gwf_tracer.h:162
int id
Definition: cs_gwf_tracer.h:165
Definition: cs_gwf_param.h:272
cs_gwf_tracer_decay_chain_t * cs_gwf_tracer_decay_chain_by_name(const char *chain_name)
Retrieve the decay chain structure associated to the name given as parameter. If not found...
Definition: cs_gwf_tracer.c:3132
double * alpha_l
Definition: cs_gwf_tracer.h:202
cs_gwf_tracer_t * cs_gwf_tracer_by_name(const char *eq_name)
Retrieve the pointer to the cs_gwf_tracer_t structure associated to the name given as parameter...
Definition: cs_gwf_tracer.c:1900
Set of parameters describing a tracer structure.
void cs_gwf_tracer_finalize_setup(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Finalize the tracer setup.
Definition: cs_gwf_tracer.c:2243
void() cs_gwf_tracer_free_context_t(cs_gwf_tracer_t *tracer)
Generic function to free the input of a tracer model.
Definition: cs_gwf_tracer.h:129
Definition: mesh.f90:26
Definition: cs_gwf_tracer.h:248
double * rho_kd
Definition: cs_gwf_tracer.h:200
Definition: cs_gwf_tracer.h:184
void() cs_gwf_tracer_update_t(cs_gwf_tracer_t *tracer, void *context, const cs_time_step_t *ts, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Generic function to update the properties related to a tracer. This function depends on a numerical s...
Definition: cs_gwf_tracer.h:113
Definition: cs_zone.h:55
