Include dependency graph for cs_gwf_param.h:Go to the source code of this file.
Macros | |
Flags specifying the kind of post-processing to perform in | |
the groundwater flow module | |
| #define | CS_GWF_POST_SOIL_CAPACITY (1 << 0) |
| Activate the post-processing of the soil capacity (property in front of the unsteady term in Richards equation) More... | |
| #define | CS_GWF_POST_LIQUID_SATURATION (1 << 1) |
| Activate the post-processing of the liquid saturation (also nammed "moisture content" in case of single phase flow) More... | |
| #define | CS_GWF_POST_PERMEABILITY (1 << 2) |
| Activate the post-processing of the permeability field. More... | |
| #define | CS_GWF_POST_DARCY_FLUX_BALANCE (1 << 3) |
| Compute the overall balance at the different boundaries of the Darcy flux. More... | |
| #define | CS_GWF_POST_DARCY_FLUX_DIVERGENCE (1 << 4) |
| Compute in each control volume (vertices or cells w.r.t the space scheme) the divergence of the Darcy flux. More... | |
| #define | CS_GWF_POST_DARCY_FLUX_AT_BOUNDARY (1 << 5) |
| Define a field at boundary faces for the Darcy flux and activate the post-processing. More... | |
| #define | CS_GWF_POST_GAS_MASS_DENSITY (1 << 6) |
| Compute the mass density of the gas component for a miscible or immiscible two-phase flow model. One recalls that one assumes that there is no water in the gas phase and that the mass density is a function of the gas pressure through a perfect gas law. More... | |
Enumerations | |
| enum | cs_gwf_model_bit_t { CS_GWF_GRAVITATION = 1<< 0, CS_GWF_GRAVITATION = 1<< 0, CS_GWF_FORCE_RICHARDS_ITERATIONS = 1<< 6, CS_GWF_FORCE_RICHARDS_ITERATIONS = 1<< 6, CS_GWF_RESCALE_HEAD_TO_ZERO_MEAN_VALUE = 1<< 7, CS_GWF_RESCALE_HEAD_TO_ZERO_MEAN_VALUE = 1<< 7, CS_GWF_ENFORCE_DIVERGENCE_FREE = 1<< 8, CS_GWF_ENFORCE_DIVERGENCE_FREE = 1<< 8 } |
| Additional modelling options either from the physical viewpoint or the numerical viewpoint. More... | |
Type of unit used for the inventory of radioactive tracers | |
| enum | cs_gwf_tracer_unit_t { CS_GWF_TRACER_UNIT_BECQUEREL, CS_GWF_TRACER_UNIT_MOLE } |
| Type of unit for the expression of the radioactive inventory. More... | |
Model definition for the groundwater flow module | |
| enum | cs_gwf_model_type_t { CS_GWF_MODEL_SATURATED_SINGLE_PHASE, CS_GWF_MODEL_UNSATURATED_SINGLE_PHASE, CS_GWF_MODEL_MISCIBLE_TWO_PHASE, CS_GWF_MODEL_IMMISCIBLE_TWO_PHASE, CS_GWF_N_MODEL_TYPES } |
| Type of system of equation(s) to consider for the physical modelling. More... | |
Soil modelling | |
| enum | cs_gwf_soil_model_t { CS_GWF_SOIL_GENUCHTEN, CS_GWF_SOIL_SATURATED, CS_GWF_SOIL_USER, CS_GWF_SOIL_N_HYDRAULIC_MODELS } |
| Predefined hydraulic model of soils used in the groundwater flow module. More... | |
Tracer modelling | |
| enum | cs_gwf_tracer_model_bit_t { CS_GWF_TRACER_USER = 1<< 0, CS_GWF_TRACER_SORPTION_EK_3_PARAMETERS = 1<< 2, CS_GWF_TRACER_SORPTION_EK_5_PARAMETERS = 1<< 3, CS_GWF_TRACER_PRECIPITATION = 1<< 4 } |
| Flags specifying the general behavior of a tracer associated to the groundwater flow module. More... | |
| typedef cs_flag_t | cs_gwf_tracer_model_t |
| #define CS_GWF_POST_DARCY_FLUX_AT_BOUNDARY (1 << 5) |
| #define CS_GWF_POST_DARCY_FLUX_BALANCE (1 << 3) |
| #define CS_GWF_POST_DARCY_FLUX_DIVERGENCE (1 << 4) |
| #define CS_GWF_POST_GAS_MASS_DENSITY (1 << 6) |
| #define CS_GWF_POST_LIQUID_SATURATION (1 << 1) |
| #define CS_GWF_POST_PERMEABILITY (1 << 2) |
| #define CS_GWF_POST_SOIL_CAPACITY (1 << 0) |
| typedef cs_flag_t cs_gwf_tracer_model_t |
| enum cs_gwf_model_bit_t |
| enum cs_gwf_model_type_t |
| Enumerator | |
| CS_GWF_MODEL_SATURATED_SINGLE_PHASE | Single phase (liquid phase) modelling in a porous media. All soils are assumed to be saturated. This yields several simplifications in the Richards equation governing the water conservation. The Richards equation is steady. The saturation is constant and there is no relative permeability. |
| CS_GWF_MODEL_UNSATURATED_SINGLE_PHASE | Single phase (liquid phase) modelling in a porous media. Some soils are not saturated and are described by a more complex model such as the Van Genuchten-Mualen model. Simplifications made in the case of CS_GWF_MODEL_SATURATED_SINGLE_PHASE do not hold anymore. Richards equation is unsteady and there may be a non-linearity to handle according to the type of soil model. Soil properties such as permeability, soil capacity and liquid saturation (also called moisture content) are neither uniform nor steady. |
| CS_GWF_MODEL_MISCIBLE_TWO_PHASE | Miscible two phase flow modelling (gaseous and liquid phases) in porous media. A Richards-like equation is considered in each phase to take into account the mass conservation of water and one other component. The component can be disolved in the liquid phase. No water vapour is taken into account. Please refer to cs_gwf_two_phase_t for more details. |
| CS_GWF_MODEL_IMMISCIBLE_TWO_PHASE | Immiscible two phase flow modelling (gaseous and liquid phases) in porous media. A Richards-like equation is considered in each phase to take into account the mass conservation of water in the liquid phase and the conservation of the other component in the gaseous phase. The model context is shared with the miscible two-phase flow model. Please refer to cs_gwf_two_phase_t for more details. |
| CS_GWF_N_MODEL_TYPES | Number of predefined models (not a model) |
| enum cs_gwf_soil_model_t |
Elemental modelling choice either from the physical viewpoint or the numerical viewpoint for the transport of a tracer
| enum cs_gwf_tracer_unit_t |
