Include dependency graph for cs_vof.h:Go to the source code of this file.
| struct | cs_vof_parameters_t |
| VOF model parameters. Void fraction variable tracks fluid 2. More... | |
| struct | cs_cavitation_parameters_t |
| Cavitation model parameters. More... | |
Macros | |
| #define | CS_VOF_ENABLED (1 << 0) |
| #define | CS_VOF_FREE_SURFACE (1 << 1) |
| #define | CS_VOF_MERKLE_MASS_TRANSFER (1 << 2) |
| cs_vof_parameters_t * | cs_get_glob_vof_parameters (void) |
| void | cs_vof_compute_linear_rho_mu (const cs_mesh_t *m) |
Compute the mixture density, mixture dynamic viscosity given fluid volume fractions and the reference density and dynamic viscosity (liquid), (gas). More... | |
| void | cs_vof_update_phys_prop (const cs_mesh_t *m) |
Compute the mixture density, mixture dynamic viscosity and mixture mass flux given the volumetric flux, the volume fraction and the reference density and dynamic viscosity (liquid), (gas). More... | |
| void | cs_vof_surface_tension (const cs_mesh_t *m, const cs_mesh_quantities_t *mq, cs_real_3_t stf[]) |
| Compute the surface tension momentum source term following the CSF model of Brackbill et al. (1992). More... | |
| void | cs_vof_log_mass_budget (const cs_mesh_t *m, const cs_mesh_quantities_t *mq) |
| Write in main log the global mixture mass budget:
. More... | |
| void | cs_vof_deshpande_drift_flux (const cs_mesh_t *m, const cs_mesh_quantities_t *mq) |
Compute the flux of the drift velocity , by using the flux of the standard velocity following the approach described by Suraj S Deshpande et al 2012 Comput. Sci. Disc. 5 014016. It is activated with the option idrift = 1. More... | |
| void | cs_vof_drift_term (int imrgra, int nswrgp, int imligp, int iwarnp, cs_real_t epsrgp, cs_real_t climgp, cs_real_t *restrict pvar, const cs_real_t *restrict pvara, cs_real_t *restrict rhs) |
Add the explicit part of the convection/diffusion terms of a standard transport equation of a scalar field . More... | |
| cs_cavitation_parameters_t * | cs_get_glob_cavitation_parameters (void) |
| const cs_vof_parameters_t * | cs_glob_vof_parameters |
| cs_cavitation_parameters_t* cs_get_glob_cavitation_parameters | ( | void | ) |
| cs_vof_parameters_t* cs_get_glob_vof_parameters | ( | void | ) |
| void cs_vof_compute_linear_rho_mu | ( | const cs_mesh_t * | m | ) |
(liquid),
(gas).
Computation is done as follows on cells:
A similar linear formula is followed on boundary using fluid volume fraction value on the boundary.
| [in] | m | pointer to mesh structure |
| void cs_vof_deshpande_drift_flux | ( | const cs_mesh_t * | m, |
| const cs_mesh_quantities_t * | mq | ||
Using the notation:
The drift flux is computed as:
Where
is the drift flux factor defined with the variable cdrift,
the normal vector to the interface. The gradient is computed using a centered scheme:
| [in] | mq | pointer to mesh quantities structure |
Using the notation:
Where
| void cs_vof_drift_term | ( | int | imrgra, |
| int | nswrgp, | ||
| int | imligp, | ||
| int | iwarnp, | ||
| cs_real_t | epsrgp, | ||
| cs_real_t | climgp, | ||
| cs_real_t *restrict | pvar, | ||
| const cs_real_t *restrict | pvara, | ||
| cs_real_t *restrict | rhs | ||
More precisely, the right hand side
is updated as follows:
| [in] | imrgra | indicator
| [in] | nswrgp | number of reconstruction sweeps for the gradients |
| [in] | imligp | clipping gradient method
| [in] | iwarnp | verbosity |
| [in] | epsrgp | relative precision for the gradient reconstruction |
| [in] | climgp | clipping coefficient for the computation of the gradient |
| [in] | pvar | solved variable (current time step) |
| [in] | pvara | solved variable (previous time step) |
| [in,out] | rhs | right hand side ![]() |
| [in,out] | rhs | right hand side |
| void cs_vof_log_mass_budget | ( | const cs_mesh_t * | m, |
| void cs_vof_surface_tension | ( | const cs_mesh_t * | m, |
| const cs_mesh_quantities_t * | mq, | ||
| cs_real_3_t | stf[] | ||
| [out] | stf | surface tension momentum source term |
| void cs_vof_update_phys_prop | ( | const cs_mesh_t * | m | ) |
(liquid),
(gas).
For the computation of mixture density, mixture dynamic viscosity, see cs_vof_compute_linear_rho_mu.
Computation of mass flux is as follows:
| const cs_vof_parameters_t* cs_glob_vof_parameters |
