7.3
cs_vof.h
1 #ifndef __CS_VOF_H__
2 #define __CS_VOF_H__
5  * Functions associated to VOF model
35  * Local headers
38 #include "cs_base.h"
39 #include "cs_mesh.h"
40 #include "cs_mesh_quantities.h"
45
46 /*=============================================================================
47  * Macro definitions
49
59 #define CS_VOF_ENABLED (1 << 0)
60
62 #define CS_VOF_FREE_SURFACE (1 << 1)
63
65 #define CS_VOF_MERKLE_MASS_TRANSFER (1 << 2)
66
72 /*============================================================================
73  * Type definitions
74  *============================================================================*/
75
76 /* VOF model parameters */
77 /*----------------------*/
78
79 typedef struct {
80
81  unsigned vof_model; /* VoF model (sum of masks defining Volume of
82  Fluid model and submodels */
83
84  double rho1; /* density */
85
86  double rho2;
87
88  double mu1; /* viscosity */
89
90  double mu2;
91
92  double sigmaS; /* surface tension */
93
94  int idrift; /* drift velocity model */
95
96  double cdrift; /* C_gamma constante (drift flux factor)*/
97
98  double kdrift;
99
101
102 /* Cavitation parameters */
103 /*-----------------------*/
104
105 typedef struct {
106
107  cs_real_t presat; /* reference saturation pressure */
108  cs_real_t uinf; /* reference velocity */
109  cs_real_t linf; /* reference length scale */
110  cs_real_t cdest; /* constant of condensation model (Merkle) */
111  cs_real_t cprod; /* constant of vaporization model (Merkle) */
112  int icvevm; /* eddy-viscosity correction indicator */
113  cs_real_t mcav; /* eddy-viscosity correction cstt (Reboud) */
114  int itscvi; /* eddy-viscosity correction indicator */
115
117
118 /*=============================================================================
119  * Global variables
120  *============================================================================*/
121
122 /* pointer to VOF model parameters structure */
123
125
126 /*============================================================================
127  * Public function prototypes
128  *============================================================================*/
129
130 /*----------------------------------------------------------------------------
131  *!
132  * \brief Provide access to VOF structure.
133  */
135
138
139 /*----------------------------------------------------------------------------*/
158 /*----------------------------------------------------------------------------*/
159
160 void
162
163 /*----------------------------------------------------------------------------*/
195 /*----------------------------------------------------------------------------*/
196
197 void
199
200 /*----------------------------------------------------------------------------*/
209 /*----------------------------------------------------------------------------*/
210
211 void
213  const cs_mesh_quantities_t *mq,
214  cs_real_3_t stf[]);
215
216 /*----------------------------------------------------------------------------*/
229 /*----------------------------------------------------------------------------*/
230
231 void
233  const cs_mesh_quantities_t *mq);
234
235 /*----------------------------------------------------------------------------*/
273 /*----------------------------------------------------------------------------*/
274
275 void
277  const cs_mesh_quantities_t *mq);
278
279 /*----------------------------------------------------------------------------*/
311 /*----------------------------------------------------------------------------*/
312
313 void
315  int nswrgp,
316  int imligp,
317  int iwarnp,
318  cs_real_t epsrgp,
319  cs_real_t climgp,
320  cs_real_t *restrict pvar,
321  const cs_real_t *restrict pvara,
322  cs_real_t *restrict rhs);
323
324 /*----------------------------------------------------------------------------
325  *!
326  * \brief Provide access to cavitation parameters structure.
327  */
328 /*----------------------------------------------------------------------------*/
329
332
333 /*----------------------------------------------------------------------------*/
334
336
337 #endif /* __CS_VOF_H__ */
cs_real_t mcav
Definition: cs_vof.h:113
#define restrict
Definition: cs_defs.h:142
void cs_vof_surface_tension(const cs_mesh_t *m, const cs_mesh_quantities_t *mq, cs_real_3_t stf[])
Compute the surface tension momentum source term following the CSF model of Brackbill et al...
Definition: cs_vof.c:938
void cs_vof_log_mass_budget(const cs_mesh_t *m, const cs_mesh_quantities_t *mq)
Write in main log the global mixture mass budget: .
Definition: cs_vof.c:788
void cs_vof_drift_term(int imrgra, int nswrgp, int imligp, int iwarnp, cs_real_t epsrgp, cs_real_t climgp, cs_real_t *restrict pvar, const cs_real_t *restrict pvara, cs_real_t *restrict rhs)
Add the explicit part of the convection/diffusion terms of a standard transport equation of a scalar ...
Definition: cs_vof.c:1247
Definition: cs_defs.h:512
VOF model parameters. Void fraction variable tracks fluid 2.
Definition: cs_vof.h:79
cs_real_t uinf
Definition: cs_vof.h:108
cs_vof_parameters_t * cs_get_glob_vof_parameters(void)
Definition: cs_vof.c:424
Definition: cs_defs.h:322
Definition: cs_mesh.h:85
int idrift
Definition: cs_vof.h:94
unsigned vof_model
Definition: cs_vof.h:81
void cs_vof_compute_linear_rho_mu(const cs_mesh_t *m)
Compute the mixture density, mixture dynamic viscosity given fluid volume fractions and the reference...
Definition: cs_vof.c:651
double rho1
Definition: cs_vof.h:84
double kdrift
Definition: cs_vof.h:98
void cs_vof_update_phys_prop(const cs_mesh_t *m)
Compute the mixture density, mixture dynamic viscosity and mixture mass flux given the volumetric flu...
Definition: cs_vof.c:730
cs_real_t cprod
Definition: cs_vof.h:111
cs_real_t cdest
Definition: cs_vof.h:110
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
cs_real_t linf
Definition: cs_vof.h:109
double rho2
Definition: cs_vof.h:86
Definition: cs_defs.h:513
double mu1
Definition: cs_vof.h:88
const cs_vof_parameters_t * cs_glob_vof_parameters
cs_real_t presat
Definition: cs_vof.h:107
double cdrift
Definition: cs_vof.h:96
cs_cavitation_parameters_t * cs_get_glob_cavitation_parameters(void)
Definition: cs_vof.c:1428
double sigmaS
Definition: cs_vof.h:92
Cavitation model parameters.
Definition: cs_vof.h:105
integer(c_int), pointer, save imrgra
type of gradient reconstruction
Definition: optcal.f90:208
int itscvi
Definition: cs_vof.h:114
double mu2
Definition: cs_vof.h:90
int icvevm
Definition: cs_vof.h:112
void cs_vof_deshpande_drift_flux(const cs_mesh_t *m, const cs_mesh_quantities_t *mq)
Compute the flux of the drift velocity , by using the flux of the standard velocity following the ap...
Definition: cs_vof.c:1140
