7.3
cs_turbulence_rij.h
1 #ifndef __CS_TURBULENCE_RIJ_H__
2 #define __CS_TURBULENCE_RIJ_H__
5  * Rij-epsilon turbulence model.
31  * Local headers
34 #include "cs_defs.h"
41  * Public function prototypes
44 /*----------------------------------------------------------------------------*/
60 /*-----------------------------------------------------------------------------*/
61
62 void
64  cs_lnum_t icetsm[],
65  int itypsm[],
66  cs_real_t smacel[]);
67
68 /*----------------------------------------------------------------------------*/
76 /*----------------------------------------------------------------------------*/
77
78 void
80  cs_real_t c_durbin_l);
81
82 /*----------------------------------------------------------------------------*/
92 /*----------------------------------------------------------------------------*/
93
94 void
97
98 /*----------------------------------------------------------------------------*/
105 /*----------------------------------------------------------------------------*/
106
107 void
109
110 /*----------------------------------------------------------------------------*/
118 /*----------------------------------------------------------------------------*/
119
120 void
122  int iclip);
123
124 /*----------------------------------------------------------------------------*/
125
127
128 #endif /* __CS_TURBULENCE_RIJ_H__ */
double precision, dimension(:,:), allocatable, target smacel
Definition: pointe.f90:199
real(c_double), pointer, save uref
the characteristic flow velocity, used for the initialization of the turbulence. Negative value: not ...
Definition: cstphy.f90:606
Definition: cs_defs.h:512
integer, dimension(:,:), allocatable, target itypsm
Definition: pointe.f90:193
Definition: cs_defs.h:322
void cs_turbulence_rij_solve_alpha(int f_id, cs_real_t c_durbin_l)
Solve the equation on alpha in the framework of the Rij-EBRSM model.
Definition: cs_turbulence_rij.c:3176
void cs_turbulence_rij_clip_sg(cs_lnum_t n_cells, int iclip)
Clip the turbulent Reynods stress tensor and the turbulent dissipation (segregated version) ...
Definition: cs_turbulence_rij.c:3692
void cs_turbulence_rij_clip(cs_lnum_t n_cells)
Clip the turbulent Reynods stress tensor and the turbulent dissipation (coupled components version)...
Definition: cs_turbulence_rij.c:3479
integer, dimension(:), allocatable, target icetsm
Definition: pointe.f90:184
Definition: cs_defs.h:316
Definition: cs_defs.h:513
void cs_turbulence_rij(cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], cs_real_t smacel[])
Solve the for incompressible flows or slightly compressible flows for one time step.
Definition: cs_turbulence_rij.c:2492
real(c_double), pointer, save almax
is a characteristic macroscopic length of the domain, used for the initialization of the turbulence a...
Definition: cstphy.f90:597
void cs_turbulence_rij_init_by_ref_quantities(cs_real_t uref, cs_real_t almax)
Initialize Rij-epsilon variables based on reference quantities.
Definition: cs_turbulence_rij.c:3418
