| integer, save | ncepdc |
| integer, dimension(:), allocatable | icepdc |
| double precision, dimension(:,:), allocatable | ckupdc |
| double precision, dimension(:), allocatable, target | b_head_loss |
| | Head loss factor of the fluid outside the domain, between infinity and the entrance (for ifrent boundary type). The default value is 0, dimensionless factor. The user may give a value in cs_user_boundary_conditions in the array rcodcl(ifac, ipr, 2). More...
| integer, save | ncetsm |
| integer, dimension(:), allocatable, target | icetsm |
| integer, dimension(:), allocatable | izctsm |
| | zone where a mass source term is imposed. More...
| integer, dimension(:,:), allocatable, target | itypsm |
| double precision, dimension(:,:), allocatable, target | smacel |
| double precision, dimension(:), allocatable, target | gamcav |
| | liquid-vapor mass transfer term for cavitating flows and its derivative with respect to pressure More...
| double precision, dimension(:), allocatable, target | dgdpca |
| double precision, dimension(:,:), allocatable | xref_cond |
| | reference point for wall condensation, used in forced and mixed convection regimes More...
| integer, save | ncmast |
| | number of the ncmast cells in which a condensation source terms is imposed. See lstmast list and the subroutine cs_user_metal_structures_source_terms More...
| integer, dimension(:), allocatable | ltmast |
| | list on the ncmast cells in which a condensation source terms is imposed. See the user subroutine cs_user_metal_structures_source_terms. More...
| integer, dimension(:), allocatable | izmast |
| | zone type where a condensation source terms is imposed to model the metal structures condensation on a volumic zone. More...
| integer, dimension(:,:), allocatable | itypst |
| | type of condensation source terms for each variable More...
| double precision, dimension(:,:), allocatable | svcond |
| | value of the condensation source terms for pressure associated to the metal structures modelling. For the other variables, eventual imposed specific value. See the user subroutine cs_user_metal_structures_source_terms. More...
| double precision, dimension(:), allocatable | flxmst |
| | value of the thermal flux for the condensation model associated to the metal structures modelling. See the user subroutine cs_user_metal_structures_source_terms. More...
