Include dependency graph for cs_turbulence_rij.h:Go to the source code of this file.
| void | cs_turbulence_rij (cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], cs_real_t smacel[]) |
Solve the for incompressible flows or slightly compressible flows for one time step. More... | |
| void | cs_turbulence_rij_solve_alpha (int f_id, cs_real_t c_durbin_l) |
| Solve the equation on alpha in the framework of the Rij-EBRSM model. More... | |
| void | cs_turbulence_rij_init_by_ref_quantities (cs_real_t uref, cs_real_t almax) |
| Initialize Rij-epsilon variables based on reference quantities. More... | |
| void | cs_turbulence_rij_clip (cs_lnum_t n_cells) |
| Clip the turbulent Reynods stress tensor and the turbulent dissipation (coupled components version). More... | |
| void | cs_turbulence_rij_clip_sg (cs_lnum_t n_cells, int iclip) |
| Clip the turbulent Reynods stress tensor and the turbulent dissipation (segregated version) More... | |
Solve the
Please refer to the
model section of the theory guide for more informations, as well as the turrij section.
| [in] | itypsm | mass source type for the variables |
| [in] | smacel | values of the variables associated to the mass source (for ivar=ipr, smacel is the mass flux) ! |
| void cs_turbulence_rij_clip | ( | cs_lnum_t | n_cells | ) |
| void cs_turbulence_rij_clip_sg | ( | cs_lnum_t | n_cells, |
| int | iclip | ||
| [in] | iclip | if 0, viscl0 is used; otherwise viscl is used. |
If uref is not provided (0 or negative), values are set at a large negative value (-cs_math_big_r) to allow for later checks.
| [in] | uref | characteristic flow velocity |
| [in] | almax | characteristic macroscopic length of the domain |
| void cs_turbulence_rij_solve_alpha | ( | int | f_id, |
| cs_real_t | c_durbin_l | ||
Also called for alpha of scalars for EB-DFM.
| [in] | f_id | field id of alpha variable |
| [in] | c_durbin_l | constant for the Durbin length ! |
