7.3
cs_time_moment.c File Reference
Temporal moments management. More...
#include <stdarg.h>
#include "cs_array_reduce.h"
#include "cs_field_pointer.h"
#include "cs_halo.h"
#include "cs_halo_perio.h"
#include "cs_mesh_location.h"
#include "cs_restart.h"
#include "cs_restart_default.h"
#include "cs_prototypes.h"
#include "cs_time_step.h"
#include "cs_time_moment.h"
+ Include dependency graph for cs_time_moment.c:
void cs_time_moment_destroy_all (void)
 Destroy all moments management metadata. More...
int cs_time_moment_define_by_field_ids (const char *name, int n_fields, const int field_id[], const int component_id[], cs_time_moment_type_t type, int nt_start, double t_start, cs_time_moment_restart_t restart_mode, const char *restart_name)
 Define a moment of a product of existing fields components. More...
int cs_time_moment_define_by_func (const char *name, int location_id, int dim, bool is_intensive, cs_time_moment_data_t *data_func, const void *data_input, cs_time_moment_data_t *w_data_func, void *w_data_input, cs_time_moment_type_t type, int nt_start, double t_start, cs_time_moment_restart_t restart_mode, const char *restart_name)
 Define a moment whose data values will be computed using a specified function. More...
int cs_time_moment_n_moments (void)
 Return the number of defined time moments. More...
int cs_time_moment_n_moments_restart (void)
 Return the number of time moments in the restart file, if any. More...
void cs_time_moment_restart_options_by_id (int restart_id, cs_time_moment_restart_t *restart_mode, const char **restart_name)
 Define a moment restart mode and name by an id. More...
const char * cs_time_moment_restart_name (int restart_id)
 Return name of a given time moments in the restart file, if any (check also cs_time_moment_n_moments_restart). More...
cs_field_tcs_time_moment_get_field (int moment_id)
 Return pointer to field associated with a given moment. More...
int cs_time_moment_is_active (int moment_id)
 Return 1 if moment is active, 0 if it is not active yet. More...
void cs_time_moment_reset (int moment_id)
 Reset a time moment. Current iteration is set as starting time step for current moment. More...
void cs_time_moment_map_cell_dt (const cs_real_t *dt)
 Map time step values array for temporal moments. More...
void cs_time_moment_update_all (void)
 Update all moment accumulators. More...
void cs_time_moment_log_setup (void)
 Log moment definition setup information. More...
void cs_time_moment_log_iteration (void)
 Log moment definition information for a given iteration. More...
void cs_time_moment_restart_use_main (int use_main)
 Indicate if restart API should use "main" instead of "auxiliary" file. More...
void cs_time_moment_restart_read (cs_restart_t *restart)
 Read restart moment data. More...
void cs_time_moment_restart_write (cs_restart_t *restart)
 Checkpoint moment data. More...
const char * cs_time_moment_type_name []
◆ cs_time_moment_define_by_field_ids()
int cs_time_moment_define_by_field_ids ( const char *  name,
int  n_fields,
int  nt_start,
double  t_start,
const char *  restart_name
Moments will involve the tensor products of their component fields, and only scalar, vector, or rank-2 tensors are handled (for post-processing output reasons), so a moment may not involve more than 2 vectors or 1 tensor, unless single components are specified.
[in]namename of associated moment
[in]n_fieldsnumber of associated fields
[in]field_idids of associated fields
[in]component_idids of matching field components (-1 for all)
[in]typemoment type
[in]nt_startstarting time step (or -1 to use t_start)
[in]t_startstarting time
[in]restart_modebehavior in case of restart (reset, automatic, or strict)
[in]restart_nameif not NULL, previous name in case of restart
id of new moment in case of success, -1 in case of error.
◆ cs_time_moment_define_by_func()
int cs_time_moment_define_by_func ( const char *  name,
int  location_id,
int  dim,
bool  is_intensive,
cs_time_moment_data_t data_func,
const void *  data_input,
cs_time_moment_data_t w_data_func,
void *  w_data_input,
int  nt_start,
double  t_start,
[in]location_idid of associated mesh location
[in]dimdimension associated with element data
[in]is_intensiveis the time moment intensive?
[in]data_funcfunction used to define data values
[in]data_inputpointer to optional (untyped) value or structure to be used by data_func
[in]w_data_funcfunction used to define weight values
[in]w_data_inputpointer to optional (untyped) value or structure to be used by w_data_func
[in]typemoment type
◆ cs_time_moment_destroy_all()
void cs_time_moment_destroy_all ( void  )
◆ cs_time_moment_get_field()
cs_field_t* cs_time_moment_get_field ( int  moment_id)
For moments defined automatically to assist computation of higher order moments, which do not have an associated field, NULL is returned.
[in]moment_idid of associated moment
pointer to field associated with given moment, or NULL
◆ cs_time_moment_is_active()
int cs_time_moment_is_active ( int  moment_id)
◆ cs_time_moment_log_iteration()
void cs_time_moment_log_iteration ( void  )
◆ cs_time_moment_log_setup()
void cs_time_moment_log_setup ( void  )
◆ cs_time_moment_map_cell_dt()
void cs_time_moment_map_cell_dt ( const cs_real_t dt)
If this function is not called, the field referenced by field pointer CS_F_(dt) will be used instead.
[in]dtpointer to time step values array
◆ cs_time_moment_n_moments()
int cs_time_moment_n_moments ( void  )
◆ cs_time_moment_n_moments_restart()
int cs_time_moment_n_moments_restart ( void  )
number of defined moments in restart file, or 0
◆ cs_time_moment_reset()
void cs_time_moment_reset ( int  moment_id)
All other time moments sharing the same start time should also be reset.
◆ cs_time_moment_restart_name()
const char* cs_time_moment_restart_name ( int  restart_id)
[in]restart_idid of time moment in restart data
name of defined moment in restart file, or NULL
◆ cs_time_moment_restart_options_by_id()
void cs_time_moment_restart_options_by_id ( int  restart_id,
const char **  restart_name
This is a utility function, to allow simplification of automatic setups. It must be called just before defining a moment to work properly if restart_id < -1 (automatic mode).
[in]restart_id-2: automatic, -1: reset, >= 0: id of matching moment in restart data
[out]restart_modematching restart mode
[out]restart_namematching restart name
◆ cs_time_moment_restart_read()
void cs_time_moment_restart_read ( cs_restart_t restart)
[in]restartassociated restart file pointer
◆ cs_time_moment_restart_use_main()
void cs_time_moment_restart_use_main ( int  use_main)
[in]use_mainuse "main" restart if nonzero, "auxiliary" otherwise
◆ cs_time_moment_restart_write()
void cs_time_moment_restart_write ( cs_restart_t restart)
◆ cs_time_moment_update_all()
void cs_time_moment_update_all ( void  )
◆ cs_time_moment_type_name
const char* cs_time_moment_type_name[]
Initial value:
= {N_("mean"),
N_("variance")}
#define N_(String)
Definition: cs_defs.h:67
