7.3
cs_sles_mumps.h File Reference
#include "cs_halo_perio.h"
#include "cs_matrix.h"
#include "cs_param_sles.h"
#include "cs_time_plot.h"
#include "cs_sles.h"
#include "cs_sles_pc.h"
+ Include dependency graph for cs_sles_mumps.h:
Macros
#define CS_SLES_MUMPS_JOB_INIT   -1
#define ICNTL(I)   icntl[(I)-1]
#define CNTL(I)   cntl[(I)-1]
#define INFOG(I)   infog[(I)-1]
#define INFO(I)   info[(I)-1]
#define RINFOG(I)   rinfog[(I)-1]
#define RINFO(I)   rinfo[(I)-1]
#define KEEP(I)   keep[(I)-1]
Typedefs
typedef void() cs_sles_mumps_setup_hook_t(const cs_param_sles_t *slesp, void *context, void *mumps)
 Function pointer for user settings of a MUMPS solver. This function is called at the end of the setup stage. More...
typedef struct _cs_sles_mumps_t cs_sles_mumps_t
void cs_user_sles_mumps_hook (const cs_param_sles_t *slesp, void *context, void *pmumps)
 Function pointer for advanced user settings of a MUMPS solver. This function is called two times during the setup stage. More...
cs_sles_mumps_tcs_sles_mumps_define (int f_id, const char *name, const cs_param_sles_t *slesp, cs_sles_mumps_setup_hook_t *setup_hook, void *context)
 Define and associate a MUMPS linear system solver for a given field or equation name. More...
cs_sles_pc_tcs_sles_mumps_pc_create (const cs_param_sles_t *slesp)
 Create a preconditioner structure relying on MUMPS solver. More...
cs_sles_mumps_tcs_sles_mumps_create (const cs_param_sles_t *slesp, cs_sles_mumps_setup_hook_t *setup_hook, void *context)
 Create MUMPS linear system solver info and context. More...
void * cs_sles_mumps_copy (const void *context)
 Create MUMPS linear system solver info and context based on existing info and context. More...
void cs_sles_mumps_free (void *context)
 Free MUMPS linear equation solver setup context. More...
void cs_sles_mumps_destroy (void **context)
 Destroy MUMPS linear system solver info and context. More...
void cs_sles_mumps_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity)
 Setup MUMPS linear equation solver. More...
cs_sles_convergence_state_t cs_sles_mumps_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors)
 Call MUMPS linear equation solver. More...
void cs_sles_mumps_log (const void *context, cs_log_t log_type)
 Log sparse linear equation solver info. More...
void cs_sles_mumps_library_info (cs_log_t log_type)
 Print information on MUMPS library. More...
◆ CNTL
#define CNTL (   I)    cntl[(I)-1]
◆ CS_SLES_MUMPS_JOB_INIT
◆ ICNTL
#define ICNTL (   I)    icntl[(I)-1]
◆ INFO
#define INFO (   I)    info[(I)-1]
◆ INFOG
#define INFOG (   I)    infog[(I)-1]
◆ KEEP
#define KEEP (   I)    keep[(I)-1]
◆ RINFO
#define RINFO (   I)    rinfo[(I)-1]
◆ RINFOG
#define RINFOG (   I)    rinfog[(I)-1]
Typedef Documentation
◆ cs_sles_mumps_setup_hook_t
Function pointer for user settings of a MUMPS DMUMPS_STRUC_C solver setup.
Note: if the context pointer is non-NULL, it must point to valid data when the selection function is called so that value or structure should not be temporary (i.e. local);
[in]slesppointer to the related cs_param_sles_t structure
[in,out]contextpointer to optional (untyped) value or structure
[in,out]mumpspointer to DMUMPS_STRUC_C or SMUMPS_STRUC_C
This function is called the end of the setup stage.
[in,out]dmumpspointer to DMUMPS_STRUC_C structure
◆ cs_sles_mumps_t
◆ cs_sles_mumps_copy()
void* cs_sles_mumps_copy ( const void *  context)
[in]contextpointer to reference info and context (actual type: cs_sles_mumps_t *)
pointer to newly created solver info object. (actual type: cs_sles_mumps_t *)
◆ cs_sles_mumps_create()
cs_sles_mumps_t* cs_sles_mumps_create ( const cs_param_sles_t slesp,
cs_sles_mumps_setup_hook_t setup_hook,
void *  context
[in]slesppointer to a cs_param_sles_t structure
[in]setup_hookpointer to optional setup epilogue function
[in,out]contextpointer to optional (untyped) value or structure for setup_hook, or NULL
pointer to associated linear system object.
◆ cs_sles_mumps_define()
cs_sles_mumps_t* cs_sles_mumps_define ( int  f_id,
const char *  name,
void *  context
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_mumps_create.
Note that this function returns a pointer directly to the sparse direct solver management structure. This may be used to set further options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
[in]nameassociated name if f_id < 0, or NULL
pointer to newly created sparse direct solver info object.
◆ cs_sles_mumps_destroy()
void cs_sles_mumps_destroy ( void **  context)
[in,out]contextpointer to sparse direct solver info and context (actual type: cs_sles_mumps_t **)
◆ cs_sles_mumps_free()
void cs_sles_mumps_free ( void *  context)
[in,out]contextpointer to sparse direct solver info and context (actual type: cs_sles_mumps_t *)
◆ cs_sles_mumps_library_info()
void cs_sles_mumps_library_info ( cs_log_t  log_type)
[in]log_typelog type
◆ cs_sles_mumps_log()
void cs_sles_mumps_log ( const void *  context,
cs_log_t  log_type
[in]contextpointer to sparse direct solver info and context (actual type: cs_sles_mumps_t *)
◆ cs_sles_mumps_pc_create()
cs_sles_pc_t* cs_sles_mumps_pc_create ( const cs_param_sles_t slesp)
pointer to newly created preconditioner object.
◆ cs_sles_mumps_setup()
void cs_sles_mumps_setup ( void *  context,
const char *  name,
const cs_matrix_t a,
int  verbosity
[in]namepointer to system name
[in]aassociated matrix
[in]verbosityassociated verbosity
◆ cs_sles_mumps_solve()
cs_sles_convergence_state_t cs_sles_mumps_solve ( void *  context,
const char *  name,
int  verbosity,
double  precision,
double  r_norm,
int *  n_iter,
double *  residue,
const cs_real_t rhs,
cs_real_t vx,
size_t  aux_size,
void *  aux_vectors
[in]amatrix
[in]precisionsolver precision
[in]r_normresidue normalization
[out]residueresidue
[in]rhsright hand side
[in,out]vxsystem solution
[in]aux_sizenumber of elements in aux_vectors (in bytes)
aux_vectorsoptional working area (internal allocation if NULL)
convergence state
◆ cs_user_sles_mumps_hook()
void cs_user_sles_mumps_hook ( const cs_param_sles_t slesp,
void *  context,
void *  pmumps
  1. Before the analysis step
  2. Before the factorization step
One can recover the MUMPS step through the "job" member. MUMPS_JOB_ANALYSIS or MUMPS_JOB_FACTORIZATION
Note: if the context pointer is non-NULL, it must point to valid data when the selection function is called so that structure should not be temporary (i.e. local);
[in,out]pmumpspointer to DMUMPS_STRUC_C or SMUMPS_STRUC_C struct.
