462 const char *type_name,
cs_sles_define_t * cs_sles_get_default_define(void)
Return pointer to default sparse linear solver definition function.
Definition: cs_sles.c:1942
cs_sles_t * cs_sles_find_or_add(int f_id, const char *name)
Return pointer to linear system object, based on matching field id or system name.
Definition: cs_sles.c:1238
void cs_sles_log(cs_log_t log_type)
Log sparse linear equation solver info.
Definition: cs_sles.c:997
const char * cs_sles_get_type(cs_sles_t *sles)
Return type name of solver context.
Definition: cs_sles.c:1515
cs_sles_convergence_state_t cs_sles_solve(cs_sles_t *sles, const cs_matrix_t *a, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors)
General sparse linear system resolution.
Definition: cs_sles.c:1698
void cs_sles_setup(cs_sles_t *sles, const cs_matrix_t *a)
Setup sparse linear equation solver.
Definition: cs_sles.c:1630
void cs_sles_initialize(void)
Initialize sparse linear equation solver API.
Definition: cs_sles.c:937
void cs_sles_set_allow_no_op(cs_sles_t *sles, bool allow_no_op)
Indicate if immediate_return ("no-op") is allowed when initial guess is zero (solve by increments) an...
Definition: cs_sles.c:1607
void() cs_sles_define_t(int f_id, const char *name, const cs_matrix_t *a)
Function pointer for the default definition of a sparse linear equation solver.
Definition: cs_sles.h:262
Definition: cs_defs.h:512
double cs_sles_get_epzero(void)
Get the current threshold value used in the detection of immediate exit.
Definition: cs_sles.c:925
const char * cs_sles_get_name(const cs_sles_t *sles)
Return name associated with a given sparse linear equation solver.
Definition: cs_sles.c:1570
const char * cs_sles_name(int f_id, const char *name)
Return name associated to a field id, name couple.
Definition: cs_sles.c:2246
void() cs_sles_free_t(void *context)
Function pointer for freeing of a linear system's context data.
Definition: cs_sles.h:157
cs_sles_t * cs_sles_find(int f_id, const char *name)
Definition: cs_sles.c:1173
bool() cs_sles_error_handler_t(cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx)
Function pointer for handling of non-convergence when solving a linear system.
Definition: cs_sles.h:233
void cs_sles_set_default_verbosity(cs_sles_verbosity_t *verbosity_func)
Set default verbosity definition function.
Definition: cs_sles.c:1977
void cs_sles_push(int f_id, const char *name)
Temporarily replace field id with name for matching calls to cs_sles_setup, cs_sles_solve, cs_sles_free, and other operations involving access through a field id.
Definition: cs_sles.c:1275
bool cs_sles_get_allow_no_op(const cs_sles_t *sles)
Query if immediate_return ("no-op") is allowed when initial guess is zero (solve by increments) and t...
Definition: cs_sles.c:1589
Definition: cs_defs.h:322
void cs_sles_free(cs_sles_t *sles)
Free sparse linear equation solver setup.
Definition: cs_sles.c:1834
Definition: cs_matrix.h:110
void * cs_sles_get_context(cs_sles_t *sles)
Return pointer to solver context structure pointer.
Definition: cs_sles.c:1535
void cs_sles_set_error_handler(cs_sles_t *sles, cs_sles_error_handler_t *error_handler_func)
Associate a convergence error handler to a given sparse linear equation solver.
Definition: cs_sles.c:1922
int cs_sles_get_post_output(cs_sles_t *sles)
Return the id of the associated writer if postprocessing output is active for a given linear equation...
Definition: cs_sles.c:1483
void() cs_sles_setup_t(void *context, const char *name, const cs_matrix_t *a, int verbosity)
Function pointer for pre-resolution setup of a linear system's context.
Definition: cs_sles.h:88
Convergence status indicator.
Definition: cs_sles.h:56
struct _cs_sles_t cs_sles_t
Definition: cs_sles.h:68
void cs_sles_finalize(void)
Finalize sparse linear equation solver API.
Definition: cs_sles.c:957
void cs_sles_set_epzero(double new_value)
Set the threshold value used in the detection of immediate exit.
Definition: cs_sles.c:910
int cs_sles_get_f_id(const cs_sles_t *sles)
Return field id associated with a given sparse linear equation solver.
Definition: cs_sles.c:1551
double precision, save a
Definition: cs_fuel_incl.f90:148
int cs_sles_get_verbosity(cs_sles_t *sles)
Get the verbosity for a given linear equation solver.
Definition: cs_sles.c:1436
int cs_sles_copy(cs_sles_t *dest, const cs_sles_t *src)
Copy the definition of a sparse linear equation solver to another.
Definition: cs_sles.c:1865
void() cs_sles_destroy_t(void **context)
Definition: cs_sles.h:207
int() cs_sles_verbosity_t(int f_id, const char *name)
Function pointer for the default definition of a sparse linear equation solver's verbosity.
Definition: cs_sles.h:283
void *() cs_sles_copy_t(const void *context)
Function pointer for creation of a solver context based on the copy of another.
Definition: cs_sles.h:194
cs_log_t
Definition: cs_log.h:48
void cs_sles_set_post_output(cs_sles_t *sles, int writer_id)
Activate postprocessing output for a given linear equation solver.
Definition: cs_sles.c:1455
void() cs_sles_log_t(const void *context, cs_log_t log_type)
Function pointer for logging of linear solver history and performance data.
Definition: cs_sles.h:172
cs_sles_convergence_state_t() cs_sles_solve_t(void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors)
Function pointer for resolution of a linear system.
Definition: cs_sles.h:130
Definition: cs_defs.h:513
void cs_sles_post_error_output_def(const char *name, int mesh_id, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx)
Output default post-processing data for failed system convergence.
Definition: cs_sles.c:1995
const char * cs_sles_base_name(int f_id, const char *name)
Return base name associated to a field id, name couple.
Definition: cs_sles.c:2221
void cs_sles_set_default_define(cs_sles_define_t *define_func)
Set default sparse linear solver definition function.
Definition: cs_sles.c:1960
void cs_sles_set_verbosity(cs_sles_t *sles, int verbosity)
Set the verbosity for a given linear equation solver.
Definition: cs_sles.c:1417
cs_sles_t * cs_sles_define(int f_id, const char *name, void *context, const char *type_name, cs_sles_setup_t *setup_func, cs_sles_solve_t *solve_func, cs_sles_free_t *free_func, cs_sles_log_t *log_func, cs_sles_copy_t *copy_func, cs_sles_destroy_t *destroy_func)
Define sparse linear equation solver for a given field or equation name.
Definition: cs_sles.c:1363
void cs_sles_pop(int f_id)
Restore behavior temporarily modified by cs_sles_push.
Definition: cs_sles.c:1311
void cs_sles_post_output_var(const char *name, int mesh_id, int location_id, int writer_id, int diag_block_size, cs_real_t var[])
Output post-processing variable related to system convergence.
Definition: cs_sles.c:2105
