7.3
cs_sles_pc.h
1 #ifndef __CS_SLES_PC_H__
2 #define __CS_SLES_PC_H__
5  * Sparse Linear Equation Solver Preconditioner driver
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_log.h"
36 #include "cs_halo_perio.h"
37 #include "cs_matrix.h"
38
44  * Macro definitions
46
48  * Type definitions
50
51 /*----------------------------------------------------------------------------
52  * Convergence status
53  *----------------------------------------------------------------------------*/
54
55 typedef enum {
56
61
63
64 /* General linear solver context (opaque) */
65
66 typedef struct _cs_sles_pc_t cs_sles_pc_t;
67
68 /*----------------------------------------------------------------------------
69  * Function pointer returning the type name of a preconditioner context.
70  *
71  * The context structure depends on the type of preconditioner used,
72  * which may in turn be determined by the string returned by
73  * cs_sles_pc_get_type() and cs_sles_pc_get_type_name().
74  * If may be used by appropriate functions specific to that type.
75  *
76  * parameters:
77  * context <-- pointer to preconditioner-specific context
78  * logging <-- if true, a name appropritate to logging
79  * (possibly translated) is returned; if false,
80  * a canonical name is returned.
81  *----------------------------------------------------------------------------*/
82
83 typedef const char *
84 (cs_sles_pc_get_type_t) (const void *context,
85  bool logging);
86
87 /*----------------------------------------------------------------------------
88  * Function pointer for pre-resolution setup of a preconditioner context.
89  *
90  * This setup may include building a multigrid hierarchy, for example.
91  *
92  * parameters:
93  * context <-> pointer to preconditioner context
94  * name <-- pointer to name of associated linear system
95  * a <-- matrix
96  * accel <-- use accelerator version ?
97  * verbosity <-- associated verbosity
98  *----------------------------------------------------------------------------*/
99
100 typedef void
101 (cs_sles_pc_setup_t) (void *context,
102  const char *name,
103  const cs_matrix_t *a,
104  bool accel,
105  int verbosity);
106
107 /*----------------------------------------------------------------------------
108  * Function pointer for setting of the required tolerance for preconditioners
109  * involving an iterative solver.
110  *
111  * This will usually not be relevant to non-iterative preconditioners,
112  * for which this type of function does not need to be defined.
113  *
114  * The preconditioner is considered to have converged when
115  * residue/r_norm <= precision, residue being the L2 norm of a.vx-rhs.
116  *
117  * parameters:
118  * context <-> pointer to preconditioner context
119  * precision <-- preconditioner precision
120  * r_norm <-- residue normalization
121  *----------------------------------------------------------------------------*/
122
123 typedef void
124 (cs_sles_pc_tolerance_t) (void *context,
125  double precision,
126  double r_norm);
127
128 /*----------------------------------------------------------------------------
129  * Function pointer for application of a preconditioner.
130  *
131  * In cases where it is desired that the preconditioner modify a vector
132  * "in place", x_in should be set to NULL, and x_out contain the vector to
133  * be modified (\f$x_{out} \leftarrow M^{-1}x_{out})\f$).
134  *
135  * parameters:
136  * context <-> pointer to preconditioner context
137  * x_in <-- input vector
138  * x_out <-> input/output vector
139  *
140  * returns:
141  * preconditioner application status
142  *----------------------------------------------------------------------------*/
143
144 typedef cs_sles_pc_state_t
145 (cs_sles_pc_apply_t) (void *context,
146  const cs_real_t *x_in,
147  cs_real_t *x_out);
148
149 /*----------------------------------------------------------------------------
150  * Function pointer for freeing of a preconditioner's context data.
151  *
152  * Note that this function should free resolution-related data, such as
153  * multigrid hierarchy and any other temporary arrays or
154  * objects required for application, but should not free the whole context,
155  * as info used for logging (especially performance data) should be
156  * maintained.
157  *
158  * parameters:
159  * context <-> pointer to preconditioner context
160  *----------------------------------------------------------------------------*/
161
162 typedef void
163 (cs_sles_pc_free_t) (void *context);
164
165 /*----------------------------------------------------------------------------
166  * Function pointer for logging of linear preconditioner setup,
167  * history and performance data.
168  *
169  * This function will indirectly be called for each preconditioner when
170  * cs_sles_finalize() is called.
171  *
172  * parameters:
173  * context <-- pointer to preconditioner context
174  * log_type <-- log type
175  *----------------------------------------------------------------------------*/
176
177 typedef void
178 (cs_sles_pc_log_t) (const void *context,
179  cs_log_t log_type);
180
181 /*----------------------------------------------------------------------------
182  * Function pointer for creation of a preconditioner context based on the
183  * copy of another.
184  *
185  * The new context copies the settings of the copied context, but not
186  * its setup data and logged info, such as performance data.
187  *
188  * This type of function is optional, but enables associating different
189  * preconditioners to related systems (to differentiate logging) while using
190  * the same settings by default.
191  *
192  * parameters:
193  * context <-- context to clone
194  *
195  * returns:
196  * pointer to newly created context
197  *----------------------------------------------------------------------------*/
198
199 typedef void *
200 (cs_sles_pc_clone_t) (const void *context);
201
202 /*----------------------------------------------------------------------------
203  * Function pointer for destruction of a preconditioner context.
204  *
205  * This function should free all context data.
206  *
207  * parameters:
208  * context <-> pointer to preconditioner context
209  *----------------------------------------------------------------------------*/
210
211 typedef void
212 (cs_sles_pc_destroy_t) (void **context);
213
214 /*============================================================================
215  * Global variables
216  *============================================================================*/
217
218 /*=============================================================================
219  * Public function prototypes for Fortran API
220  *============================================================================*/
221
222 /*=============================================================================
223  * Public function prototypes
224  *============================================================================*/
225
226 /*----------------------------------------------------------------------------*/
238 /*----------------------------------------------------------------------------*/
239
240 void
242  cs_log_t log_type);
243
244 /*----------------------------------------------------------------------------*/
269 /*----------------------------------------------------------------------------*/
270
271 cs_sles_pc_t *
272 cs_sles_pc_define(void *context,
273  cs_sles_pc_get_type_t *get_type_func,
274  cs_sles_pc_setup_t *setup_func,
275  cs_sles_pc_tolerance_t *tolerance_func,
276  cs_sles_pc_apply_t *apply_func,
277  cs_sles_pc_free_t *free_func,
278  cs_sles_pc_log_t *log_func,
279  cs_sles_pc_clone_t *clone_func,
280  cs_sles_pc_destroy_t *destroy_func);
281
282 /*----------------------------------------------------------------------------*/
289 /*----------------------------------------------------------------------------*/
290
291 void
293
294 /*----------------------------------------------------------------------------*/
308 /*----------------------------------------------------------------------------*/
309
310 cs_sles_pc_t *
311 cs_sles_pc_clone(const cs_sles_pc_t *src);
312
313 /*----------------------------------------------------------------------------*/
326 /*----------------------------------------------------------------------------*/
327
328 const char *
330
331 /*----------------------------------------------------------------------------*/
339 /*----------------------------------------------------------------------------*/
340
341 const char *
343
344 /*----------------------------------------------------------------------------*/
356 /*----------------------------------------------------------------------------*/
357
358 void *
360
361 /*----------------------------------------------------------------------------*/
371 /*----------------------------------------------------------------------------*/
372
375
376 /*----------------------------------------------------------------------------*/
394 /*----------------------------------------------------------------------------*/
395
396 void
398  double precision,
399  double r_norm);
400
401 /*----------------------------------------------------------------------------*/
418 /*----------------------------------------------------------------------------*/
419
420 void
422  const char *name,
423  const cs_matrix_t *a,
424  bool accel,
425  int verbosity);
426
427 /*----------------------------------------------------------------------------*/
444 /*----------------------------------------------------------------------------*/
445
448  cs_real_t *x_in,
449  cs_real_t *x_out);
450
451 /*----------------------------------------------------------------------------*/
462 /*----------------------------------------------------------------------------*/
463
464 void
466
467 /*----------------------------------------------------------------------------*/
473 /*----------------------------------------------------------------------------*/
474
475 cs_sles_pc_t *
477
478 /*----------------------------------------------------------------------------*/
484 /*----------------------------------------------------------------------------*/
485
486 cs_sles_pc_t *
488
489 /*----------------------------------------------------------------------------*/
495 /*----------------------------------------------------------------------------*/
496
497 cs_sles_pc_t *
499
500 /*----------------------------------------------------------------------------*/
506 /*----------------------------------------------------------------------------*/
507
508 cs_sles_pc_t *
510
511 /*----------------------------------------------------------------------------*/
512
514
515 #endif /* __CS_SLES_PC_H__ */
cs_sles_pc_t * cs_sles_pc_poly_1_create(void)
Create a polynomial preconditioner of degree 1.
Definition: cs_sles_pc.c:1096
void cs_sles_pc_setup(cs_sles_pc_t *pc, const char *name, const cs_matrix_t *a, bool accel, int verbosity)
Setup sparse linear equation preconditioner.
Definition: cs_sles_pc.c:948
void() cs_sles_pc_free_t(void *context)
Function pointer for freeing of a preconditioner&#39;s context data.
Definition: cs_sles_pc.h:163
cs_sles_pc_state_t
Convergence status indicator.
Definition: cs_sles_pc.h:55
cs_sles_pc_t * cs_sles_pc_poly_2_create(void)
Create a polynomial preconditioner of degree 2.
Definition: cs_sles_pc.c:1124
const char * cs_sles_pc_get_type(cs_sles_pc_t *pc)
Return type name of preconditioner context.
Definition: cs_sles_pc.c:822
void cs_sles_pc_destroy(cs_sles_pc_t **pc)
Destroy a sparse linear equation preconditioner.
Definition: cs_sles_pc.c:754
void() cs_sles_pc_setup_t(void *context, const char *name, const cs_matrix_t *a, bool accel, int verbosity)
Definition: cs_sles_pc.h:101
Definition: cs_sles_pc.h:60
cs_sles_pc_t * cs_sles_pc_define(void *context, cs_sles_pc_get_type_t *get_type_func, cs_sles_pc_setup_t *setup_func, cs_sles_pc_tolerance_t *tolerance_func, cs_sles_pc_apply_t *apply_func, cs_sles_pc_free_t *free_func, cs_sles_pc_log_t *log_func, cs_sles_pc_clone_t *clone_func, cs_sles_pc_destroy_t *destroy_func)
Define sparse linear equation preconditioner.
Definition: cs_sles_pc.c:716
Definition: cs_defs.h:512
Definition: cs_sles_pc.h:66
Definition: cs_sles_pc.h:58
cs_sles_pc_t * cs_sles_pc_none_create(void)
Create an "identity" (or null) preconditioner.
Definition: cs_sles_pc.c:1040
Definition: cs_defs.h:322
cs_sles_pc_state_t() cs_sles_pc_apply_t(void *context, const cs_real_t *x_in, cs_real_t *x_out)
Definition: cs_sles_pc.h:145
Definition: cs_matrix.h:110
void * cs_sles_pc_get_context(cs_sles_pc_t *pc)
Return pointer to preconditioner context structure pointer.
Definition: cs_sles_pc.c:868
double precision, save a
Definition: cs_fuel_incl.f90:148
cs_sles_pc_t * cs_sles_pc_jacobi_create(void)
Create a Jacobi preconditioner.
Definition: cs_sles_pc.c:1068
const char *() cs_sles_pc_get_type_t(const void *context, bool logging)
Definition: cs_sles_pc.h:84
void *() cs_sles_pc_clone_t(const void *context)
Function pointer for creation of a preconditioner context based on the copy of another.
Definition: cs_sles_pc.h:200
cs_sles_pc_state_t cs_sles_pc_apply(cs_sles_pc_t *pc, cs_real_t *x_in, cs_real_t *x_out)
Apply a preconditioner.
Definition: cs_sles_pc.c:980
cs_log_t
Definition: cs_log.h:48
void cs_sles_pc_set_tolerance(cs_sles_pc_t *pc, double precision, double r_norm)
Set the required tolerance for preconditioners involving an iterative solver.
Definition: cs_sles_pc.c:917
cs_sles_pc_apply_t * cs_sles_pc_get_apply_func(const cs_sles_pc_t *pc)
Return a pointer to the function used to apply a preconditioner.
Definition: cs_sles_pc.c:891
void cs_sles_pc_free(cs_sles_pc_t *pc)
Free preconditioner setup.
Definition: cs_sles_pc.c:1001
void() cs_sles_pc_destroy_t(void **context)
Definition: cs_sles_pc.h:212
void() cs_sles_pc_log_t(const void *context, cs_log_t log_type)
Function pointer for logging of preconditioner history and performance data.
Definition: cs_sles_pc.h:178
Definition: cs_defs.h:513
Definition: cs_sles_pc.h:59
Definition: cs_sles_pc.h:57
void() cs_sles_pc_tolerance_t(void *context, double precision, double r_norm)
Function pointer for setting of the required tolerance for preconditioners involving an iterative sol...
Definition: cs_sles_pc.h:124
void cs_sles_pc_log(cs_sles_pc_t *pc, cs_log_t log_type)
Log preconditioner setup, history and performance data.
Definition: cs_sles_pc.c:1024
cs_sles_pc_t * cs_sles_pc_clone(const cs_sles_pc_t *src)
Create a new preconditioner context based on the copy of another.
Definition: cs_sles_pc.c:782
const char * cs_sles_pc_get_type_name(cs_sles_pc_t *pc)
Definition: cs_sles_pc.c:843
