7.3
cs_navsto_system.h File Reference
#include "cs_advection_field.h"
#include "cs_cdo_turbulence.h"
#include "cs_equation.h"
#include "cs_param_types.h"
#include "cs_property.h"
#include "cs_maxwell.h"
#include "cs_navsto_param.h"
#include "cs_time_plot.h"
#include "cs_time_step.h"
#include "cs_thermal_system.h"
#include "cs_xdef.h"
+ Include dependency graph for cs_navsto_system.h:
Data Structures
struct  cs_navsto_system_t
 Structure managing the Navier-Stokes system. More...
Typedefs
typedef void *() cs_navsto_init_scheme_context_t(const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *fb_type, void *nscc)
 Allocate and initialize the context structure related to a given discretization scheme for the resolution of the Navier-Stokes system with a specified coupling algorithm. More...
typedef void *() cs_navsto_free_scheme_context_t(void *scheme_context)
 Free the context structure related to a given discretization scheme for the resolution of the Navier-Stokes system with a specified coupling algorithm. More...
typedef void() cs_navsto_init_values_t(const cs_navsto_param_t *nsp, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, cs_field_t *field)
 According to the model, coupling algorithm and the space discretization, initialize the field values which are not associated to a cs_equation_t structure (which manages the initialization) More...
typedef void() cs_navsto_compute_t(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
 Compute for the current time step the new state for the Navier-Stokes system. This means that equations are built and then solved. More...
bool cs_navsto_system_is_activated (void)
 Check if the resolution of the Navier-Stokes system has been activated. More...
void cs_navsto_system_update_model (bool with_thermal)
 Update the flag associated to the modelling options. More...
cs_navsto_system_tcs_navsto_system_activate (const cs_boundary_t *boundaries, cs_navsto_param_model_t model, cs_navsto_param_model_flag_t model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t post_flag)
 Allocate and initialize the Navier-Stokes (NS) system. More...
void cs_navsto_system_destroy (void)
 Free the main structure related to the Navier-Stokes system. More...
cs_navsto_param_tcs_navsto_system_get_param (void)
 Retrieve the structure storing the parameters for the Navier–Stokes system. More...
cs_equation_tcs_navsto_system_get_momentum_eq (void)
 Retrieve a pointer to the equation related to the momentum equation. More...
cs_adv_field_tcs_navsto_get_adv_field (void)
 Retrieve the advection field structure (the mass flux) related to the Navier-Stokes system. More...
cs_real_tcs_navsto_get_mass_flux (bool previous)
 Retrieve the mass flux array related to the Navier-Stokes system. More...
void cs_navsto_system_init_setup (void)
 Start setting-up the Navier-Stokes system At this stage, numerical settings should be completely determined but connectivity and geometrical information is not yet available. More...
void cs_navsto_system_finalize_setup (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
 Last step of the setup of the Navier-Stokes system. More...
void cs_navsto_system_set_sles (void)
 Define the settings for SLES related to the Navier-Stokes system. More...
void cs_navsto_system_define_context (const cs_mesh_t *mesh)
 Initialize the scheme context structure used to build the algebraic system. This is done after the setup step. More...
void cs_navsto_system_init_values (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
 Set an initial value for the velocity and pressure fields as well as mass fluxes and tubulent quantities if needed. More...
void cs_navsto_system_set_solid_cells (cs_lnum_t n_solid_cells, cs_lnum_t solid_cell_ids[])
 Set a solid zone related to the Navier-Stokes equations. More...
void cs_navsto_system_update (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
 Update variables and related quantities when a new state of the Navier-Stokes system has been computed. More...
void cs_navsto_system_compute_steady_state (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
 Build, solve and update the Navier-Stokes system in case of a steady-state approach. More...
void cs_navsto_system_compute (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
 Build, solve and update the Navier-Stokes system. More...
void cs_navsto_system_extra_op (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
 Predefined extra-operations for the Navier-Stokes system. More...
void cs_navsto_system_extra_post (void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
 Predefined post-processing output for the Navier-Stokes system. The prototype of this function is fixed since it is a function pointer defined in cs_post.h (cs_post_time_mesh_dep_output_t) More...
void cs_navsto_system_log_setup (void)
 Summary of the main cs_navsto_system_t structure. More...
Typedef Documentation
◆ cs_navsto_compute_t
[in,out]scheme_contextpointer to a structure cast on-the-fly
◆ cs_navsto_free_scheme_context_t
typedef void*() cs_navsto_free_scheme_context_t(void *scheme_context)
a NULL pointer
◆ cs_navsto_init_scheme_context_t
typedef void*() cs_navsto_init_scheme_context_t(const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *fb_type, void *nscc)
[in]mfluxcurrent values of the mass flux
[in]mflux_precurrent values of the mass flux
[in]fb_typetype of boundary for each boundary face
[in,out]nsccNavier-Stokes coupling context: pointer to a structure cast on-the-fly
a pointer to a new allocated scheme context structure
◆ cs_navsto_init_values_t
[in]tspointer to a cs_time_step_t structure
[in,out]fieldpointer to a cs_field_t structure
◆ cs_navsto_get_adv_field()
cs_adv_field_t* cs_navsto_get_adv_field ( void  )
a pointer to the advection field structure
◆ cs_navsto_get_mass_flux()
cs_real_t* cs_navsto_get_mass_flux ( bool  previous)
[in]previousif true return the previous state otherwise the current state.
a pointer to an array of cs_real_t
◆ cs_navsto_system_activate()
cs_navsto_system_t* cs_navsto_system_activate ( const cs_boundary_t boundaries,
[in]boundariespointer to the domain boundaries
[in]modeltype of model related to the NS system
[in]model_flagadditional high-level model options
[in]algo_couplingalgorithm used for solving the NS system
[in]post_flagpredefined post-processings options
a pointer to a new allocated cs_navsto_system_t structure
◆ cs_navsto_system_compute()
void cs_navsto_system_compute ( const cs_mesh_t mesh,
const cs_time_step_t time_step
[in]time_stepstructure managing the time stepping
◆ cs_navsto_system_compute_steady_state()
void cs_navsto_system_compute_steady_state ( const cs_mesh_t mesh,
◆ cs_navsto_system_define_context()
void cs_navsto_system_define_context ( const cs_mesh_t mesh)
◆ cs_navsto_system_destroy()
void cs_navsto_system_destroy ( void  )
◆ cs_navsto_system_extra_op()
void cs_navsto_system_extra_op ( const cs_mesh_t mesh,
◆ cs_navsto_system_extra_post()
void cs_navsto_system_extra_post ( void *  input,
int  mesh_id,
int  cat_id,
int  ent_flag[5],
cs_lnum_t  n_cells,
[in,out]inputpointer to a optional structure (here a cs_navsto_system_t structure)
[in]mesh_idid of the output mesh for the current call
[in]cat_idcategory id of the output mesh for this call
[in]ent_flagindicate global presence of cells (ent_flag[0]), interior faces (ent_flag[1]), boundary faces (ent_flag[2]), particles (ent_flag[3]) or probes (ent_flag[4])
[in]n_cellslocal number of cells of post_mesh
[in]n_i_faceslocal number of interior faces of post_mesh
[in]n_b_faceslocal number of boundary faces of post_mesh
[in]cell_idslist of cells (0 to n-1)
[in]i_face_idslist of interior faces (0 to n-1)
[in]b_face_idslist of boundary faces (0 to n-1)
[in]time_steppointer to a cs_time_step_t struct.
◆ cs_navsto_system_finalize_setup()
void cs_navsto_system_finalize_setup ( const cs_mesh_t mesh,
◆ cs_navsto_system_get_momentum_eq()
cs_equation_t* cs_navsto_system_get_momentum_eq ( void  )
NULL or the pointer
◆ cs_navsto_system_get_param()
cs_navsto_param_t* cs_navsto_system_get_param ( void  )
NULL or the pointer to a cs_navsto_param_t structure
◆ cs_navsto_system_init_setup()
void cs_navsto_system_init_setup ( void  )
◆ cs_navsto_system_init_values()
void cs_navsto_system_init_values ( const cs_mesh_t mesh,
◆ cs_navsto_system_is_activated()
bool cs_navsto_system_is_activated ( void  )
true or false
◆ cs_navsto_system_log_setup()
void cs_navsto_system_log_setup ( void  )
◆ cs_navsto_system_set_sles()
void cs_navsto_system_set_sles ( void  )
◆ cs_navsto_system_set_solid_cells()
void cs_navsto_system_set_solid_cells ( cs_lnum_t  n_solid_cells,
[in]n_solid_cellsnumber of solid cells
[in]solid_cell_idslist of cell ids (local numbering)
◆ cs_navsto_system_update()
void cs_navsto_system_update ( const cs_mesh_t mesh,
◆ cs_navsto_system_update_model()
void cs_navsto_system_update_model ( bool  with_thermal)
[in]with_thermaltrue or false
