371 if (z_name != NULL) {
372 if (strlen(z_name) > 0) {
396 if (z_name != NULL) {
397 if (strlen(z_name) > 0) {
423 assert(def->
dim == 1);
cs_xdef_t * cs_xdef_boundary_create(cs_xdef_type_t type, int dim, int z_id, cs_flag_t state, cs_flag_t meta, void *context)
Allocate and initialize a new cs_xdef_t structure based on boundary elements.
Definition: cs_xdef.c:287
cs_analytic_func_t * func
Definition: cs_xdef.h:268
cs_xdef_t * cs_xdef_timestep_create(cs_xdef_type_t type, cs_flag_t state, cs_flag_t meta, void *context)
Allocate and initialize a new cs_xdef_t structure for setting the time step.
Definition: cs_xdef.c:445
cs_quadrature_type_t cs_xdef_get_quadrature(cs_xdef_t *d)
Get the type of quadrature to use for evaluating the given description.
Definition: cs_xdef.c:883
cs_time_func_t * func
Definition: cs_xdef.h:336
cs_xdef_t * cs_xdef_free(cs_xdef_t *d)
Free a cs_xdef_t structure.
Definition: cs_xdef.c:515
Definition: cs_field.h:130
void cs_xdef_set_input_context(cs_xdef_t *d, void *input)
In the case of a definition by an analytic function, a time function or a function relying on degrees...
Definition: cs_xdef.c:655
Definition: cs_xdef.h:119
int id
Definition: cs_zone.h:59
Definition: cs_xdef.h:141
cs_real_t * values
Definition: cs_xdef.h:243
cs_real_t * cs_xdef_get_field_values(cs_xdef_t *def)
Get the current field values in case of definition by field.
Definition: cs_xdef.c:940
Definition: cs_defs.h:512
Definition: cs_xdef.h:114
Context structure when a time step function is used for the definition.
Definition: cs_xdef.h:330
cs_xdef_free_input_t * free_input
Definition: cs_xdef.h:321
const cs_zone_t * cs_volume_zone_by_name(const char *name)
Return a pointer to a volume zone based on its name if present.
Definition: cs_volume_zone.c:680
void * context
Definition: cs_xdef.h:199
cs_flag_t state
Definition: cs_xdef.h:194
Definition: cs_xdef.h:112
cs_xdef_type_t cs_xdef_get_type(const cs_xdef_t *d)
Retrieve the flag dedicated to the state.
Definition: cs_xdef.c:902
Definition: cs_xdef.h:143
Definition: cs_xdef.h:117
void cs_xdef_set_array_pointers(cs_xdef_t *d, const cs_lnum_t *index, const cs_lnum_t *ids)
In case of definition by array, set the optional index and ids arrays that may be useful when operati...
Definition: cs_xdef.c:833
cs_xdef_t * cs_xdef_copy(cs_xdef_t *src)
copy a cs_xdef_t structure
Definition: cs_xdef.c:594
void cs_xdef_set_array(cs_xdef_t *d, bool is_owner, cs_real_t *array)
In case of definition by array, set the array after having added this definition. ...
Definition: cs_xdef.c:767
Definition: cs_xdef.h:349
int z_id
Definition: cs_xdef.h:296
static cs_real_t * cs_xdef_get_array(cs_xdef_t *def)
Retrieve the values associated to the given definition. This should be a definition by array...
Definition: cs_xdef.h:443
cs_flag_t cs_xdef_get_state_flag(const cs_xdef_t *d)
Definition: cs_xdef.c:921
Definition: cs_defs.h:322
int dim
Definition: cs_xdef.h:189
cs_xdef_type_t type
Definition: cs_xdef.h:190
void * input
Definition: cs_xdef.h:315
static cs_real_t cs_xdef_get_scalar_value(cs_xdef_t *def)
Retrieve the value associated to the given definition. This should be a definition by value and the d...
Definition: cs_xdef.h:420
Context structure when a definition by analytic function is used.
Definition: cs_xdef.h:256
const cs_lnum_t * ids
Definition: cs_xdef.h:247
Definition: cs_xdef.h:116
cs_xdef_support_t
Definition: cs_xdef.h:139
void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
Definition: cs_param_types.h:154
int z_id
Definition: cs_xdef.h:240
Definition: cs_quadrature.h:52
void cs_xdef_set_quadrature(cs_xdef_t *d, cs_quadrature_type_t qtype)
Set the type of quadrature to use for evaluating the given description.
Definition: cs_xdef.c:862
cs_flag_t loc
Definition: cs_xdef.h:242
Context structure when a definition by DoF function is used.
Definition: cs_xdef.h:290
cs_dof_func_t * func
Definition: cs_xdef.h:309
Definition: cs_xdef.h:197
cs_xdef_type_t
Definition: cs_xdef.h:109
Definition: cs_xdef.h:111
int z_id
Definition: cs_xdef.h:262
Definition: cs_xdef.h:118
void * input
Definition: cs_xdef.h:275
int stride
Definition: cs_xdef.h:241
Definition: cs_xdef.h:155
cs_log_t
Definition: cs_log.h:48
void cs_xdef_set_free_input_function(cs_xdef_t *d, cs_xdef_free_input_t *free_input)
In case of a definition by an analytic function, a time function or a function relying on degrees of ...
Definition: cs_xdef.c:712
Definition: cs_xdef.h:145
static int cs_get_vol_zone_id(const char *z_name)
Retrieve the volume zone if from the zone name (If name = NULL or has an empty length, all entities are selected)
Definition: cs_xdef.h:369
void cs_xdef_log_setup(const char *prefix, const cs_xdef_t *d)
Output the settings related to a cs_xdef_t structure in the setup logging file.
Definition: cs_xdef.c:967
Definition: cs_defs.h:316
cs_xdef_support_t support
Definition: cs_xdef.h:192
Definition: cs_xdef.h:115
Definition: cs_defs.h:513
void cs_xdef_set_array_zone_id(cs_xdef_t *d, int z_id)
In case of definition by array, set the zone id related to the size of the array. By default...
Definition: cs_xdef.c:805
unsigned short int cs_flag_t
Definition: cs_defs.h:324
void() cs_time_func_t(double time, void *input, cs_real_t *retval)
Function which defines the evolution of a quantity according to the current time and any structure gi...
Definition: cs_param_types.h:172
Definition: cs_xdef.h:281
bool is_owner
Definition: cs_xdef.h:244
cs_flag_t meta
Definition: cs_xdef.h:195
Definition: cs_xdef.h:113
const cs_lnum_t * index
Definition: cs_xdef.h:246
int z_id
Definition: cs_xdef.h:191
void * input
Definition: cs_xdef.h:343
Context structure when an array is used for the definition.
Definition: cs_xdef.h:208
const char * cs_xdef_type_get_name(cs_xdef_type_t xdef_type)
Retrieve a pointer to the cs_xdef_type's name string.
Definition: cs_xdef.c:1124
static int cs_get_bdy_zone_id(const char *z_name)
Retrieve the boundary zone if from the zone name (If name = NULL or has an empty length, all entities are selected)
Definition: cs_xdef.h:394
Definition: cs_xdef.h:121
Definition: cs_xdef.h:142
cs_xdef_t * cs_xdef_volume_create(cs_xdef_type_t type, int dim, int z_id, cs_flag_t state, cs_flag_t meta, void *context)
Allocate and initialize a new cs_xdef_t structure based on volumic elements.
Definition: cs_xdef.c:115
void *() cs_xdef_free_input_t(void *input)
Destroy an input data structure. Complex data structure can be used when a cs_xdef_t structure is def...
Definition: cs_xdef.h:71
void cs_xdef_log(cs_log_t log_type, const char *prefix, const cs_xdef_t *d)
Output the settings related to a cs_xdef_t structure.
Definition: cs_xdef.c:984
cs_flag_t loc
Definition: cs_xdef.h:303
static cs_field_t * cs_xdef_get_field(cs_xdef_t *def)
When the definition relies on a cs_field_t structure, return the pointer to the field structure...
Definition: cs_xdef.h:467
