7.3
cs_navsto_system_t Struct Reference
Structure managing the Navier-Stokes system. More...
#include <cs_navsto_system.h>
+ Collaboration diagram for cs_navsto_system_t:
Data Fields
cs_navsto_param_tparam
cs_adv_field_tadv_field
cs_real_tmass_flux_array
cs_real_tmass_flux_array_pre
cs_boundary_type_tbf_type
Variable fields
Set of fields (resolved variables): fields are created according to the choice of model for Navier-Stokes
cs_field_tvelocity
cs_field_tpressure
Related systems of equations
According to the modelling choice other systems of equations can be solved in a more or less coupled manner. For instance, the energy equation (with the thermal system) or the magneto-hydrodynamic equations (with the Maxwell system of equations)
cs_turbulence_tturbulence
Post-processing
Set of fields which are induced by the variable fields and which have meaningful information for understanding the flow. Structure managing the post-processing.
cs_time_plot_tplot_writer
cs_field_tvelocity_divergence
cs_field_tpressure_gradient
cs_field_tkinetic_energy
cs_field_tmass_density
cs_field_tmass_flux_balance
cs_field_tvorticity
cs_field_thelicity
cs_field_tenstrophy
cs_field_tvelocity_gradient
cs_equation_tstream_function_eq
Context structures to get a greater flexibility in what can be done
in the given framework
void * coupling_context
void * scheme_context
Pointer to functions handling specific tasks
cs_navsto_init_scheme_context_tinit_scheme_context
cs_navsto_free_scheme_context_tfree_scheme_context
cs_navsto_init_values_tinit_velocity
cs_navsto_init_values_tinit_pressure
cs_navsto_compute_tcompute_steady
Field Documentation
◆ adv_field
adv_field
Pointer to the cs_adv_field_t structure storing the advection field used in the Navier-Stokes equations
◆ bf_type
bf_type
Array storing the type of boundary for each boundary face
◆ compute
compute
Pointer of functions related to resolution of the Navier-Stokes unsteady system. Handle the build of the system and its resolution
◆ compute_steady
compute_steady
Pointer of functions related to resolution of the Navier-Stokes steady system. Handle the build of the system and its resolution
◆ coupling_context
coupling_context
Additional structure storing information according to the way equations of model for the Navier-Stokes system are coupled and thus solved
◆ enstrophy
enstrophy
Enstrophy is defined as $ \int_c vorticity \cdot $ vorticity Pointer to a scalar-valued cs_field_t
◆ free_scheme_context
free_scheme_context
Pointer of functions related to the destruction of the context structure related to a given discretization scheme for the resolution of the Navier-Stokes system
◆ helicity
helicity
Helicity is defined as $ \int_c velocity \cdot $ vorticity Pointer to a scalar-valued cs_field_t
◆ init_pressure
init_pressure
Pointer of functions related to the initialization of variable values Case of the pressure
◆ init_scheme_context
init_scheme_context
Pointer of functions related to the initialization of the context structure related to a given discretization scheme for the resolution of the Navier-Stokes system
◆ init_velocity
init_velocity
Pointer of functions related to the initialization of variable values Case of the velocity
◆ kinetic_energy
kinetic_energy
Kinetic energy defined as $ 1/2 velocity \cdot velocity $ Pointer to a scalar-valued cs_field_t
◆ mass_density
mass_density
Mass density Available when a Boussinesq approximation is on and a postprocessing has been requested. Pointer to a scalar-valued cs_field_t
◆ mass_flux_array
mass_flux_array
Current values of the mass flux (if this is a CDO Face-based scheme, array is allocated to the number of faces; first interior faces then boundary faces)
◆ mass_flux_array_pre
mass_flux_array_pre
Previous values of the mass flux (if this is a CDO Face-based scheme, array is allocated to the number of faces; first interior faces then boundary faces)
◆ mass_flux_balance
mass_flux_balance
Cellwise balance of the mass flux. Useful to check settings (injection/suction) or the expected behavior of the numerical algorithm.
◆ param
param
Set of parameters to handle the Navier-Stokes system
◆ plot_writer
plot_writer
Writer for monitoring the evolution of predefined global variables (the integral of the mass in the computational domain or the divergence of the velocity field for instance)
◆ pressure
pressure
Pressure, scalar-valued, pointer to cs_field_t
◆ pressure_gradient
pressure_gradient
Pressure gradient Pointer to a vector-valued cs_field_t
◆ scheme_context
scheme_context
Additional structure storing information according to the space discretization scheme used for solving the model for the Navier-Stokes system
◆ stream_function_eq
stream_function_eq
Pointer to a cs_equation_t structure related to the computation of the stream function -Laplacian(psi) = vorticity_z where psi is the scalar-valued stream function. This is relevant only for a 2D computation
◆ turbulence
turbulence
Structure storing all settings, fields or properties related to the turbulence modelling
◆ velocity
velocity
Velocity, vector-valued, pointer to cs_field_t
◆ velocity_divergence
velocity_divergence
Divergence of the velocity fied. Pointer to a scalar-valued cs_field_t
◆ velocity_gradient
velocity_gradient
Pointer to a tensor-valued cs_field_t
◆ vorticity
vorticity
Vorticity of the velocity field defined as curl(velocity) Pointer to a vector-valued cs_field_t
