7.3
cs_gwf_priv.h File Reference
#include "cs_advection_field.h"
#include "cs_equation_system.h"
#include "cs_gwf_param.h"
+ Include dependency graph for cs_gwf_priv.h:
Data Structures
struct  cs_gwf_darcy_flux_t
struct  cs_gwf_saturated_single_phase_t
 Structure to handle the modelling of a single-phase flows in a porous media considered as saturated. More...
struct  cs_gwf_unsaturated_single_phase_t
 Structure to handle the modelling of a single-phase flows in a porous media considered as saturated or not. Several simplifications can be be operated in this context. Only the liquid phase is taken into account. More...
struct  cs_gwf_two_phase_t
 Structure to handle the modelling of miscible or immiscible two-phase flows in a porous media. More...
struct  cs_gwf_t
 Main set of parameters/structures to manage the groundwater flow (GWF) module. This is an explicit definition of the structure cs_gwf_t. More...
Typedefs
typedef void() cs_gwf_darcy_update_t(const cs_real_t t_eval, const cs_equation_t *eq, bool cur2prev, void *input, cs_gwf_darcy_flux_t *darcy)
 Update the advection field/arrays related to the Darcy flux. More...
cs_gwf_darcy_flux_tcs_gwf_darcy_flux_create (cs_flag_t loc_flag)
 Allocate and initialize a cs_gwf_darcy_flux_t structure. More...
void cs_gwf_darcy_flux_free (cs_gwf_darcy_flux_t **p_darcy)
 Free a cs_gwf_darcy_flux_t structure. More...
void cs_gwf_darcy_flux_log (cs_gwf_darcy_flux_t *darcy)
 Log a cs_gwf_darcy_flux_t structure. More...
void cs_gwf_darcy_flux_define (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_param_space_scheme_t space_scheme, void *update_context, cs_gwf_darcy_update_t *update_func, cs_gwf_darcy_flux_t *darcy)
 Set the definition of the advection field attached to a cs_gwf_darcy_flux_t structure If the function pointer is set to NULL, then an automatic settings is done. More...
void cs_gwf_darcy_flux_balance (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_equation_param_t *eqp, cs_gwf_darcy_flux_t *darcy)
 Operate the balance by zone (relying on the splitting arising from the boundary settings) for the advection field attached to a cs_gwf_darcy_flux_t structure. More...
Typedef Documentation
◆ cs_gwf_darcy_update_t
[in]eqpointer to the equation related to this Darcy flux
[in]cur2prevtrue or false
[in]inputpointer to the context structure
[in,out]darcypointer to the darcy flux structure
◆ cs_gwf_darcy_flux_balance()
void cs_gwf_darcy_flux_balance ( const cs_cdo_connect_t connect,
const cs_equation_param_t eqp,
cs_gwf_darcy_flux_t darcy
[in]eqppointer to the set of equation parameters
[in,out]darcypointer to the darcy structure
◆ cs_gwf_darcy_flux_create()
cs_gwf_darcy_flux_t* cs_gwf_darcy_flux_create ( cs_flag_t  loc_flag)
[in]loc_flagflag to define where the flux is defined
a pointer to the newly allocated structure
◆ cs_gwf_darcy_flux_define()
void cs_gwf_darcy_flux_define ( const cs_cdo_connect_t connect,
void *  update_context,
cs_gwf_darcy_update_t update_func,
[in]space_schemespace discretization using this structure
[in]update_contextpointer to the context for the update step
[in]update_funcpointer to an update function or NULL
◆ cs_gwf_darcy_flux_free()
void cs_gwf_darcy_flux_free ( cs_gwf_darcy_flux_t **  p_darcy)
[in,out]p_darcypointer of pointer to the darcy structure
◆ cs_gwf_darcy_flux_log()
void cs_gwf_darcy_flux_log ( cs_gwf_darcy_flux_t darcy)
