1 #ifndef __CS_GWF_PRIV_H__ 2 #define __CS_GWF_PRIV_H__ 840 void *update_context,
cs_gwf_darcy_update_t * update_func
Definition: cs_gwf_priv.h:106
cs_real_t * l_saturation_submesh
Definition: cs_gwf_priv.h:605
cs_property_t * moisture_content
Definition: cs_gwf_priv.h:159
bool use_properties_on_submesh
Consider a submesh to define the liquid saturation.
Definition: cs_gwf_priv.h:697
cs_adv_field_t * adv_field
Definition: cs_gwf_priv.h:100
void cs_gwf_darcy_flux_free(cs_gwf_darcy_flux_t **p_darcy)
Free a cs_gwf_darcy_flux_t structure.
Definition: cs_gwf_priv.c:308
cs_iter_algo_param_t nl_algo_param
Definition: cs_gwf_priv.h:701
cs_real_t * l_rel_permeability
Definition: cs_gwf_priv.h:596
cs_real_t * boundary_flux_val
Definition: cs_gwf_priv.h:103
Definition: cs_advection_field.h:150
cs_gwf_model_type_t model
Definition: cs_gwf_priv.h:738
cs_real_t * g_rel_permeability
Definition: cs_gwf_priv.h:597
cs_property_t * soil_porosity
Definition: cs_gwf_priv.h:760
cs_property_t * diff_wl_pty
Definition: cs_gwf_priv.h:435
Definition: cs_field.h:130
cs_param_nl_algo_t nl_algo_type
Definition: cs_gwf_priv.h:700
cs_property_t * diff_hg_pty
Definition: cs_gwf_priv.h:440
void() cs_gwf_darcy_update_t(const cs_real_t t_eval, const cs_equation_t *eq, bool cur2prev, void *input, cs_gwf_darcy_flux_t *darcy)
Update the advection field/arrays related to the Darcy flux.
Definition: cs_gwf_priv.h:63
void * model_context
Definition: cs_gwf_priv.h:773
void * update_input
Definition: cs_gwf_priv.h:105
Structure storing all the parameters to drive the algorithm called Anderson acceleration.
Definition: cs_iter_algo.h:177
void cs_gwf_darcy_flux_balance(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_equation_param_t *eqp, cs_gwf_darcy_flux_t *darcy)
Operate the balance by zone (relying on the splitting arising from the boundary settings) for the adv...
Definition: cs_gwf_priv.c:495
bool use_coupled_solver
When a model relies on several coupled equations, there are two main options to build and solve the s...
Definition: cs_gwf_priv.h:695
cs_property_t * reac_hg_pty
Definition: cs_gwf_priv.h:441
cs_gwf_darcy_flux_t * g_darcy
Definition: cs_gwf_priv.h:393
cs_property_t * soil_capacity
Definition: cs_gwf_priv.h:244
cs_param_nl_algo_t
Class of non-linear iterative algorithm.
Definition: cs_param_types.h:546
Structure to handle the modelling of miscible or immiscible two-phase flows in a porous media...
Definition: cs_gwf_priv.h:331
cs_property_t * time_wg_pty
Definition: cs_gwf_priv.h:437
Definition: cs_defs.h:512
bool use_explicit_dsldt_liquid
Consider an explicit treatment of the time derivative of the liquid saturation in the mass conservati...
Definition: cs_gwf_priv.h:698
cs_field_t * c_pressure
Definition: cs_gwf_priv.h:470
cs_real_t * diff_hg_array
Definition: cs_gwf_priv.h:589
cs_gwf_darcy_flux_t * cs_gwf_darcy_flux_create(cs_flag_t loc_flag)
Allocate and initialize a cs_gwf_darcy_flux_t structure.
Definition: cs_gwf_priv.c:285
cs_real_t * time_wg_array
Definition: cs_gwf_priv.h:586
cs_real_t g_viscosity
Definition: cs_gwf_priv.h:648
cs_real_t * time_wl_array
Definition: cs_gwf_priv.h:582
cs_gwf_darcy_flux_t * l_darcy
Definition: cs_gwf_priv.h:392
cs_real_t w_molar_mass
Definition: cs_gwf_priv.h:650
cs_real_t * srct_wl_array
Definition: cs_gwf_priv.h:584
cs_iter_algo_t * nl_algo
Definition: cs_gwf_priv.h:704
cs_gwf_model_type_t
Definition: cs_gwf_param.h:118
cs_real_t * g_cell_pressure
Definition: cs_gwf_priv.h:604
Definition: cs_defs.h:322
cs_real_t * flux_val
Definition: cs_gwf_priv.h:102
Definition: cs_cdo_quantities.h:132
void cs_gwf_darcy_flux_log(cs_gwf_darcy_flux_t *darcy)
Log a cs_gwf_darcy_flux_t structure.
Definition: cs_gwf_priv.c:339
cs_property_t * time_hg_pty
Definition: cs_gwf_priv.h:439
cs_equation_t * richards
Definition: cs_gwf_priv.h:209
cs_real_t henry_constant
Definition: cs_gwf_priv.h:653
cs_real_t l_diffusivity_h
Definition: cs_gwf_priv.h:649
cs_field_t * permeability_field
Definition: cs_gwf_priv.h:180
Definition: cs_gwf_priv.h:243
Set of common parameters to manage an iterative algorithm.
Definition: cs_iter_algo.h:101
cs_flag_t post_flag
Definition: cs_gwf_priv.h:740
Definition: cs_gwf_priv.h:133
Structure to handle the Darcy flux.
cs_field_t * l_saturation
Definition: cs_gwf_priv.h:469
cs_real_t * l_capacity
Definition: cs_gwf_priv.h:602
cs_param_space_scheme_t
Definition: cs_param_types.h:207
cs_property_t * time_wl_pty
Definition: cs_gwf_priv.h:434
cs_real_t * diff_wl_array
Definition: cs_gwf_priv.h:583
cs_real_t * srct_hg_array
Definition: cs_gwf_priv.h:591
cs_real_t l_viscosity
Definition: cs_gwf_priv.h:647
cs_equation_system_t * system
Definition: cs_gwf_priv.h:376
Main set of parameters/structures to manage the groundwater flow (GWF) module. This is an explicit de...
Definition: cs_gwf_priv.h:720
cs_equation_t * wl_eq
Definition: cs_gwf_priv.h:346
cs_field_t * capacity_field
Definition: cs_gwf_priv.h:283
cs_equation_t * hg_eq
Definition: cs_gwf_priv.h:354
Structure to handle the modelling of a single-phase flows in a porous media considered as saturated...
Definition: cs_gwf_priv.h:120
cs_real_t l_mass_density
Definition: cs_gwf_priv.h:646
Structure to handle the modelling of a single-phase flows in a porous media considered as saturated o...
Definition: cs_gwf_priv.h:197
Main structure to handle a set of coupled equations.
Definition: cs_equation_system.h:123
cs_property_t * time_hl_pty
Definition: cs_gwf_priv.h:443
cs_field_t * pressure_head
Definition: cs_gwf_priv.h:181
bool use_incremental_solver
When a model includes non-linearities it can be useful to formulate the problem using increment and t...
Definition: cs_gwf_priv.h:696
cs_property_t * abs_permeability
Definition: cs_gwf_priv.h:761
cs_equation_param_t * wg_eqp
Definition: cs_gwf_priv.h:361
cs_real_t * head_in_law
Definition: cs_gwf_priv.h:286
Definition: cs_defs.h:513
cs_real_t * time_hg_array
Definition: cs_gwf_priv.h:588
unsigned short int cs_flag_t
Definition: cs_defs.h:324
cs_real_t * l_saturation_submesh_pre
Definition: cs_gwf_priv.h:606
cs_equation_param_t * hl_eqp
Definition: cs_gwf_priv.h:369
cs_iter_algo_param_aa_t anderson_param
Definition: cs_gwf_priv.h:702
Definition: cs_iter_algo.h:53
cs_flag_t flag
Definition: cs_gwf_priv.h:739
cs_field_t * g_pressure
Definition: cs_gwf_priv.h:472
cs_gwf_darcy_flux_t * darcy
Definition: cs_gwf_priv.h:146
Definition: cs_gwf_priv.h:222
void cs_gwf_darcy_flux_define(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_param_space_scheme_t space_scheme, void *update_context, cs_gwf_darcy_update_t *update_func, cs_gwf_darcy_flux_t *darcy)
Set the definition of the advection field attached to a cs_gwf_darcy_flux_t structure If the function...
Definition: cs_gwf_priv.c:368
cs_property_t * permeability
Definition: cs_gwf_priv.h:242
cs_flag_t flux_location
Definition: cs_gwf_priv.h:101
Definition: cs_gwf_priv.h:284
cs_real_t h_molar_mass
Definition: cs_gwf_priv.h:651
cs_real_t * time_hl_array
Definition: cs_gwf_priv.h:593
cs_real_t * reac_hg_array
Definition: cs_gwf_priv.h:590
cs_field_t * moisture_field
Definition: cs_gwf_priv.h:282
Definition: cs_gwf_priv.h:281
cs_field_t * l_pressure
Definition: cs_gwf_priv.h:471
cs_real_t ref_temperature
Definition: cs_gwf_priv.h:652
cs_real_t * capillarity_cell_pressure
Definition: cs_gwf_priv.h:603
cs_property_t * diff_hl_pty
Definition: cs_gwf_priv.h:444
cs_real_t * diff_hl_array
Definition: cs_gwf_priv.h:594
