1 #ifndef __CS_EQUATION_SYSTEM_H__ 2 #define __CS_EQUATION_SYSTEM_H__ time step descriptor
Definition: cs_time_step.h:64
void cs_equation_system_define(void)
Define the builder and scheme context structures associated to all the systems of equations which hav...
Definition: cs_equation_system.c:610
void cs_equation_system_destroy_all(void)
Destroy all cs_equation_system_t structures.
Definition: cs_equation_system.c:312
cs_equation_system_t * cs_equation_system_add(const char *sysname, int n_eqs, int block_var_dim)
Add a new structure to handle system of coupled equations.
Definition: cs_equation_system.c:281
void * context
Definition: cs_equation_system.h:154
void cs_equation_system_set_functions(void)
Assign a set of pointer functions for managing all the systems of equations.
Definition: cs_equation_system.c:507
cs_cdo_system_helper_t * system_helper
Definition: cs_equation_system.h:152
Definition: cs_defs.h:512
Definition: cs_cdo_system.h:368
void cs_equation_system_set_sles(void)
Set the SLES associated to each system of equations.
Definition: cs_equation_system.c:571
Definition: cs_cdo_quantities.h:132
cs_timer_counter_t timer
Definition: cs_equation_system.h:136
void cs_equation_system_solve(bool cur2prev, cs_equation_system_t *eqsys)
Solve of a system of coupled equations. Unsteady case.
Definition: cs_equation_system.c:666
cs_equation_core_t ** block_factories
Definition: cs_equation_system.h:197
void *() cs_equation_system_free_t(int n_eqs, cs_equation_core_t **core_array, void *sys_context)
Free an array of structures (equation parameters, equation builders or scheme context) for each equat...
Definition: cs_equation_system.h:93
void *() cs_equation_system_define_t(int n_eqs, const cs_equation_system_param_t *sysp, cs_equation_core_t **core_array, cs_cdo_system_helper_t **p_sh)
Create and initialize equation builders and scheme context for each equation which are in the extra-d...
Definition: cs_equation_system.h:69
Main structure storing the parameter settings.
Definition: cs_equation_system_param.h:71
Main structures composiing an equation structure.
Definition: cs_equation.h:82
void cs_equation_system_assign_equation(int row_id, cs_equation_t *eq, cs_equation_system_t *eqsys)
Assign the given equation to the diagonal block located at position (row_id, row_id) in the matrix of...
Definition: cs_equation_system.c:709
int n_equations
Definition: cs_equation_system.h:170
cs_equation_system_solve_t * solve_steady_state_system
Definition: cs_equation_system.h:225
Main structure to handle a set of coupled equations.
Definition: cs_equation_system.h:123
cs_equation_system_free_t * free
Definition: cs_equation_system.h:222
int timer_id
Definition: cs_equation_system.h:137
void cs_equation_system_log_setup(void)
Log the setup for all structures managing systems of equations.
Definition: cs_equation_system.c:329
void cs_equation_system_init_sharing(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Assign a set of shared pointer to the main structures.
Definition: cs_equation_system.c:440
cs_equation_system_define_t * define
Definition: cs_equation_system.h:221
Definition: cs_defs.h:513
void cs_equation_system_assign_param(int row_id, int col_id, cs_equation_param_t *eqp, cs_equation_system_t *eqsys)
Assign the given equation parameters to the block with ids (row_id, col_id) in the block matrix...
Definition: cs_equation_system.c:756
void() cs_equation_system_solve_t(bool c2p, int n_eqs, cs_equation_system_param_t *sysp, cs_equation_core_t **blocks, void *sys_context, cs_cdo_system_helper_t *sh)
Build and solve a linear system within the CDO framework.
Definition: cs_equation_system.h:111
cs_equation_system_param_t * param
Definition: cs_equation_system.h:134
cs_equation_system_solve_t * solve_system
Definition: cs_equation_system.h:224
cs_equation_t ** equations
Definition: cs_equation_system.h:171
void cs_equation_system_log_monitoring(void)
Print a synthesis of the monitoring information in the performance file.
Definition: cs_equation_system.c:408
int cs_equation_system_get_n_systems(void)
Get the number of systems of equations.
Definition: cs_equation_system.c:263
Definition: cs_timer.h:55
