#include <ple_locator.h>#include "fvm_nodal.h"#include "cs_base.h"#include "cs_halo.h"#include "cs_mesh.h"#include "cs_mesh_quantities.h"
Include dependency graph for cs_ctwr.h:Go to the source code of this file.
| struct | cs_ctwr_option_t |
| typedef struct _cs_ctwr_zone_t | cs_ctwr_zone_t |
Enumerations | |
| enum | cs_ctwr_model_t { CS_CTWR_NONE = 0, CS_CTWR_POPPE = 1, CS_CTWR_MERKEL = 2 } |
| enum | cs_ctwr_zone_type_t { CS_CTWR_COUNTER_CURRENT = 1, CS_CTWR_CROSS_CURRENT = 2 } |
| cs_ctwr_option_t * | cs_get_glob_ctwr_option (void) |
| void | cs_ctwr_define (const char zone_criteria[], cs_ctwr_zone_type_t zone_type, cs_real_t delta_t, cs_real_t relax, cs_real_t t_l_bc, cs_real_t q_l_bc, cs_real_t xap, cs_real_t xnp, cs_real_t surface, cs_real_t xleak_fac) |
| Define a cooling tower exchange zone. More... | |
| void | cs_ctwr_field_pointer_map (void) |
| Map fields used by the cooling tower module to pointers. More... | |
| void | cs_ctwr_bulk_mass_source_term (const cs_real_t p0, const cs_real_t molmassrat, cs_real_t mass_source[]) |
| Phase change mass source term from the evaporating liquid to the bulk, humid air. More... | |
| void | cs_ctwr_build_zones (void) |
| Define zones. More... | |
| void | cs_ctwr_build_all (void) |
| Define the cells belonging to the different packing zones. More... | |
| void | cs_ctwr_all_destroy (void) |
| Destroy cs_ctwr_t structures. More... | |
| void | cs_ctwr_log_setup (void) |
| Log Packing zone definition setup information. More... | |
| void | cs_ctwr_log_balance (void) |
| Perform balances in packing zones. More... | |
| void | cs_ctwr_init_field_vars (cs_real_t rho0, cs_real_t t0, cs_real_t p0, cs_real_t molmassrat) |
| Initialize the field variables. More... | |
| void | cs_ctwr_restart_field_vars (cs_real_t rho0, cs_real_t t0, cs_real_t p0, cs_real_t humidity0, cs_real_t molmassrat) |
| Reset the field variables based on the restart values. More... | |
| void | cs_ctwr_init_flow_vars (cs_real_t liq_mass_flow[]) |
| Initialize the flow variables relevant to the cooling tower scalars inside the packing zones. More... | |
| void | cs_ctwr_phyvar_update (cs_real_t rho0, cs_real_t t0, cs_real_t p0, cs_real_t molmassrat) |
| Update the thermo physical properties fields for the humid air and the liquid. More... | |
| void | cs_ctwr_source_term (int f_id, const cs_real_t p0, const cs_real_t molmassrat, cs_real_t exp_st[], cs_real_t imp_st[]) |
| Phase change source terms - Exchange terms between the injected liquid and the water vapor phase in the bulk, humid air. More... | |
| void | cs_ctwr_transport_vars (int iflag) |
| Convert injected liquid scalars from and to their transported form. More... | |
| cs_ctwr_zone_t * | cs_ctwr_by_id (int ct_id) |
| const cs_ctwr_option_t * | cs_glob_ctwr_option |
| typedef struct _cs_ctwr_zone_t cs_ctwr_zone_t |
| enum cs_ctwr_model_t |
| enum cs_ctwr_zone_type_t |
| void cs_ctwr_all_destroy | ( | void | ) |
| void cs_ctwr_build_all | ( | void | ) |
| void cs_ctwr_build_zones | ( | void | ) |
Define zones.
| void cs_ctwr_bulk_mass_source_term | ( | const cs_real_t | p0, |
| const cs_real_t | molmassrat, | ||
| cs_real_t | mass_source[] | ||
Careful, this is different from an injection source term, which would normally be handled with a 'cs_equation_add_volume_mass_injection_' function.
| [in] | p0 | Reference pressure |
| [in] | molmassrat | Dry air to water vapor molecular mass ratio |
| [out] | mass_source | Mass source term |
| cs_ctwr_zone_t* cs_ctwr_by_id | ( | int | ct_id | ) |
| void cs_ctwr_define | ( | const char | zone_criteria[], |
| cs_ctwr_zone_type_t | zone_type, | ||
| cs_real_t | delta_t, | ||
| cs_real_t | relax, | ||
| cs_real_t | t_l_bc, | ||
| cs_real_t | q_l_bc, | ||
| cs_real_t | xap, | ||
| cs_real_t | xnp, | ||
| cs_real_t | surface, | ||
| cs_real_t | xleak_fac | ||
| [in] | zone_criteria | zone selection criteria |
| [in] | zone_type | exchange zone type |
| [in] | delta_t | imposed delta temperature delta between inlet and oulet of the zone |
| [in] | relax | relaxation of the imposed delta temperature |
| [in] | t_l_bc | liquid water temperature at the inlet |
| [in] | q_l_bc | mass flow rate at the inlet |
| [in] | xap | beta_x_0 of the exchange law |
| [in] | xnp | exponent n of the exchange law |
| [in] | surface | total Surface of ingoing water |
| [in] | xleak_fac | leakage factor (ratio of outlet/inlet flow rate) |
| void cs_ctwr_field_pointer_map | ( | void | ) |
| [in] | rho0 | Reference density of humid air |
| [in] | t0 | Reference temperature of humid air |
| void cs_ctwr_init_flow_vars | ( | cs_real_t | liq_mass_flow[] | ) |
| [in,out] | liq_mass_flow | Liquid mass flow rate |
| void cs_ctwr_log_balance | ( | void | ) |
| void cs_ctwr_log_setup | ( | void | ) |
| void cs_ctwr_restart_field_vars | ( | cs_real_t | rho0, |
| cs_real_t | t0, | ||
| cs_real_t | p0, | ||
| cs_real_t | humidity0, | ||
| cs_real_t | molmassrat | ||
| [in] | humidity0 | Reference humidity |
| void cs_ctwr_source_term | ( | int | f_id, |
| const cs_real_t | p0, | ||
| cs_real_t | exp_st[], | ||
| cs_real_t | imp_st[] | ||
| [in] | f_id | field id |
| [in] | molmassrat | dry air to water vapor molecular mass ratio |
| [in,out] | exp_st | Explicit source term |
| [in,out] | imp_st | Implicit source term |
| void cs_ctwr_transport_vars | ( | int | iflag | ) |
| [in] | iflag | 1: Convert transported variables to physical variables 2: Convert physical variables to transported variables |
| cs_ctwr_option_t* cs_get_glob_ctwr_option | ( | void | ) |
| const cs_ctwr_option_t* cs_glob_ctwr_option |
