7.2
cs_equation_t Struct Reference
#include <cs_equation_priv.h>
+ Collaboration diagram for cs_equation_t:
Data Fields
Metadata
int id
char *restrict varname
int field_id
int boundary_flux_id
int main_ts_id
cs_equation_param_tparam
Generic pointers to manage a cs_equation_t structure
Since each space discretization has its specificities, an operation is associated to a function pointer which is set during the setup phase according to the space discretization and then one calls this operation without the need to test in which case we are.
cs_equation_builder_tbuilder
void * scheme_context
cs_equation_init_context_tinit_context
cs_equation_free_context_tfree_context
cs_equation_init_values_tinit_field_values
cs_equation_solve_tsolve_steady_state
cs_equation_get_balance_tcompute_balance
cs_equation_apply_sitffness_tapply_stiffness
cs_equation_extra_op_tpostprocess
cs_equation_extra_op_tcurrent_to_previous
cs_equation_restart_tread_restart
cs_equation_restart_twrite_restart
cs_equation_get_values_tget_cell_values
cs_equation_get_values_tget_face_values
cs_equation_get_values_tget_edge_values
cs_equation_get_values_tget_vertex_values
cs_equation_get_builders_tget_cw_build_structures
cs_equation_set_dir_bc_tset_dir_bc
cs_equation_build_system_tbuild_system
cs_equation_prepare_solve_tprepare_solving
cs_equation_update_field_tupdate_field
Field Documentation
◆ apply_stiffness
apply_stiffness
Pointer of function given by the prototype cs_equation_apply_sitffness_t
◆ boundary_flux_id
boundary_flux_id
Id to the field storing the boundary flux asociated to variable field
◆ build_system
◆ builder
builder
Common members for building the algebraic system between the numerical schemes
◆ compute_balance
compute_balance
Pointer of function given by the prototype cs_equation_get_balance_t
◆ current_to_previous
current_to_previous
Pointer of function given by the prototype cs_equation_extra_op_t
◆ field_id
field_id
Id of the variable field related to this equation (cf. cs_field_t)
◆ free_context
free_context
Pointer of function given by the prototype cs_equation_free_context_t
◆ get_cell_values
get_cell_values
Pointer of function given by the prototype cs_equation_get_values_t
◆ get_cw_build_structures
Retrieve local structures used to build the algebraic system. Pointer of function given by the prototype cs_equation_get_builders_t
◆ get_edge_values
get_edge_values
◆ get_face_values
get_face_values
◆ get_vertex_values
get_vertex_values
◆ id
int id
Id of the current equation
◆ init_context
init_context
Pointer of function given by the prototype cs_equation_init_context_t
◆ init_field_values
init_field_values
Pointer of function given by the prototype cs_equation_init_values_t
◆ main_ts_id
int main_ts_id
Id of the main timer stats for this equation
◆ param
param
Set of parameters related to an equation
◆ postprocess
postprocess
Additional predefined post-processing. Pointer of function given by the prototype cs_equation_extra_op_t
◆ prepare_solving
cs_equation_prepare_solve_t* prepare_solving
◆ read_restart
read_restart
Pointer of function given by the prototype cs_equation_restart_t
◆ scheme_context
scheme_context
Data depending on the numerical scheme (cast on-the-fly)
◆ set_dir_bc
◆ solve
solve
Pointer to a function given by the generic prototype cs_equation_solve_t Case of an unsteady solution
◆ solve_steady_state
solve_steady_state
Case of steady-state solution. Pointer of function given by the prototype cs_equation_solve_t
◆ update_field
◆ varname
varname
Name of the field of type variable associated to this equation
◆ write_restart
write_restart
