7.2
cs_equation_priv.h File Reference
#include "cs_cdo_toolbox.h"
#include "cs_equation_builder.h"
#include "cs_restart.h"
+ Include dependency graph for cs_equation_priv.h:
Data Structures
struct  cs_equation_t
Typedefs
typedef void *() cs_equation_init_context_t(const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
 Initialize a scheme data structure used during the building of the algebraic system. More...
typedef void *() cs_equation_free_context_t(void *scheme_context)
 Destroy a scheme data structure. More...
typedef void() cs_equation_init_values_t(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Initialize the variable field values related to an equation. More...
typedef void() cs_equation_solve_t(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *eqc)
 Build and solve a linear system within the CDO framework. More...
typedef void() cs_equation_set_dir_bc_t(cs_real_t t_eval, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context, cs_real_t field_val[])
 Set the Dirichlet boundary stemming from the settings. More...
typedef void() cs_equation_build_system_t(const cs_mesh_t *mesh, const cs_real_t *field_val, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Build a linear system within the CDO framework. More...
typedef void() cs_equation_prepare_solve_t(void *eq_to_cast, cs_real_t *p_x[])
 Carry out operations for allocating and/or initializing the solution array and the right hand side of the linear system to solve. Handle parallelism thanks to cs_range_set_t structure. More...
typedef void() cs_equation_update_field_t(const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context, cs_real_t *field_val)
 Store solution(s) of the linear system into a field structure Update extra-field values if required (for hybrid discretization) More...
typedef cs_cdo_balance_t *() cs_equation_get_balance_t(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Compute the balance for an equation over the full computational domain between time t_cur and t_cur + dt_cur. More...
typedef void() cs_equation_apply_sitffness_t(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context, const cs_property_t *property, const cs_real_t *pot, cs_flag_t loc_res, cs_real_t *res)
 Compute the cellwise stiffness matrix associated to the property given as a parameter and apply it to the pot array to define the resulting array associated to entities defined at loc_res. More...
typedef void() cs_equation_extra_op_t(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Generic prototype for extra-operations related to an equation. More...
typedef void() cs_equation_get_builders_t(cs_cell_sys_t **csys, cs_cell_builder_t **cb)
 Retrieve cellwise structure including work buffers used to build a CDO system cellwise. Generic prototype for all CDO schemes. More...
typedef cs_real_t *() cs_equation_get_values_t(void *scheme_context, bool previous)
 Compute or retrieve an array of values at a given mesh location Currently, vertices, cells or faces are possible locations The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More...
typedef void() cs_equation_restart_t(cs_restart_t *restart, const char *eqname, void *scheme_context)
 Generic prototype dedicated to read or write additional arrays (not defined as fields) useful for the checkpoint/restart process. More...
Typedef Documentation
◆ cs_equation_apply_sitffness_t
[in,out]contextpointer to a scheme builder structure
[in]propertypointer to the property related to the stiffness op.
[in]potarray to multiply with the stiffness matrix
[in]loc_reslocation of entities in the resulting array
[in,out]resresulting array
◆ cs_equation_build_system_t
[in]mpointer to a cs_mesh_t structure
[in]field_valpointer to the current value of the field
[in,out]contextpointer to a scheme context structure
◆ cs_equation_extra_op_t
[in,out]contextpointer to a generic data structure
◆ cs_equation_free_context_t
typedef void*() cs_equation_free_context_t(void *scheme_context)
[in,out]scheme_contextpointer to a structure cast on-the-fly
a NULL pointer
◆ cs_equation_get_balance_t
typedef cs_cdo_balance_t*() cs_equation_get_balance_t(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
a pointer to a cs_cdo_balance_t structure
◆ cs_equation_get_builders_t
◆ cs_equation_get_values_t
typedef cs_real_t*() cs_equation_get_values_t(void *scheme_context, bool previous)
[in,out]scheme_contextpointer to a data structure cast on-the-fly
a pointer to an array of cs_real_t
◆ cs_equation_init_context_t
typedef void*() cs_equation_init_context_t(const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
[in,out]eqbpointer to a cs_equation_builder_t struct.
a pointer to a new allocated scheme context structure
◆ cs_equation_init_values_t
◆ cs_equation_prepare_solve_t
[in,out]eq_castpointer to generic builder structure
[in,out]p_xpointer of pointer to the solution array
◆ cs_equation_restart_t
◆ cs_equation_set_dir_bc_t
[in,out]field_valpointer to the values of the variable field
◆ cs_equation_solve_t
[in,out]eqcpointer to a scheme context structure
◆ cs_equation_update_field_t
[in]solusolution array
[in]rhsrhs associated to this solution array
[in,out]contextpointer to a context structure
[in,out]field_valpointer to the current value of the field
