#include "cs_defs.h"#include <assert.h>#include <math.h>#include <stdarg.h>#include <stdlib.h>#include <stdio.h>#include <string.h>#include "bft_error.h"#include "bft_mem.h"#include "bft_printf.h"#include "cs_property.h"#include "cs_physical_properties.h"#include "cs_eos.hxx"#include "cs_coolprop.hxx"
Include dependency graph for cs_physical_properties.c:Functions | |
| void | cs_thermal_table_set (const char *material, const char *method, const char *reference, cs_phys_prop_thermo_plane_type_t thermo_plane, int temp_scale) |
| Define thermal table. More... | |
| void | cs_thermal_table_finalize (void) |
| finalize thermal table. More... | |
| void | cs_phys_prop_compute (cs_phys_prop_type_t property, cs_lnum_t n_vals, cs_lnum_t var1_stride, cs_lnum_t var2_stride, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[]) |
| Compute a physical property. More... | |
| void | cs_phys_prop_freesteam (cs_phys_prop_thermo_plane_type_t thermo_plane, cs_phys_prop_type_t property, const cs_lnum_t n_vals, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[]) |
| Compute properties with Freesteam in a defined thermal plane. More... | |
| cs_real_t | cs_physical_property_get_ref_value (const char *name) |
| Get reference value of a physical property. More... | |
| void | cs_physical_property_set_ref_value (const char *name, const cs_real_t val) |
| Set reference value for a physical property. More... | |
| void | cs_physical_property_get_zone_values (const char *name, const char *zname, cs_real_t retval[]) |
| Get property reference values for a given zone. More... | |
| void | cs_physical_property_create (const char *name, const int dim, const cs_real_t refval) |
| Create a physical property. More... | |
| void | cs_physical_property_define_from_value (const char *name, const char *zname, const int dim, const cs_real_t val) |
| Add a property definition on a given zone using a single value. More... | |
| void | cs_physical_property_define_from_values (const char *name, const char *zname, const int dim, cs_real_t vals[]) |
| Add a property multi-diemnsional definition on a given zone. More... | |
| void | cs_physical_property_define_from_field (const char *name, int type_flag, int location_id, int dim, bool has_previous) |
| Add a property definition based on a cs_field_t. More... | |
| int | cs_physical_property_field_id_by_name (const char *name) |
| Return id of field associated to property. More... | |
| void | cs_physical_property_update_zone_values (const char *name, const char *zname, const cs_real_t vals[]) |
| Update reference values for a property on a given zone. More... | |
| void cs_phys_prop_compute | ( | cs_phys_prop_type_t | property, |
| cs_lnum_t | n_vals, | ||
| cs_lnum_t | var1_stride, | ||
| cs_lnum_t | var2_stride, | ||
| const cs_real_t | var1[], | ||
| const cs_real_t | var2[], | ||
| cs_real_t | val[] | ||
For values var1 and var2, we can use a stride so that accesses for a given element with id i will be of the form: var[i*stride]; this allows regular access with stride 1, and access to constant variables stored as a single-valued array with a stride of 0.
| [in] | property | property queried |
| [in] | n_vals | number of values |
| [in] | var1_stride | stride between successive values of var1 |
| [in] | var2_stride | stride between successive values of var2 |
| [in] | var1 | values on first plane axis |
| [in] | var2 | values on second plane axis |
| [out] | val | resulting property values |
| void cs_phys_prop_freesteam | ( | cs_phys_prop_thermo_plane_type_t | thermo_plane, |
| cs_phys_prop_type_t | property, | ||
| const cs_lnum_t | n_vals, | ||
| [in] | thermo_plane | thermodynamic plane |
| void cs_physical_property_create | ( | const char * | name, |
| const int | dim, | ||
| const cs_real_t | refval | ||
| [in] | name | property name |
| [in] | refval | reference value |
| void cs_physical_property_define_from_field | ( | const char * | name, |
| int | type_flag, | ||
| int | location_id, | ||
| int | dim, | ||
| bool | has_previous | ||
The field is created if needed
| [in] | type_flag | field type flag |
| [in] | location_id | location id flag |
| [in] | dim | field dimension |
| [in] | has_previous | does the field has val_pre |
| void cs_physical_property_define_from_value | ( | const char * | name, |
| const char * | zname, | ||
| const cs_real_t | val | ||
| [in] | zname | zone name |
| [in] | val | reference value for the zone |
| void cs_physical_property_define_from_values | ( | const char * | name, |
| cs_real_t | vals[] | ||
| [in] | dim | property dimension (>1) |
| [in] | vals | array of values to set |
| int cs_physical_property_field_id_by_name | ( | const char * | name | ) |
| cs_real_t cs_physical_property_get_ref_value | ( | const char * | name | ) |
| void cs_physical_property_get_zone_values | ( | const char * | name, |
| cs_real_t | retval[] | ||
| [in] | retval | array of values to return |
| void cs_physical_property_set_ref_value | ( | const char * | name, |
| [in] | val | new value to set |
| void cs_physical_property_update_zone_values | ( | const char * | name, |
| const cs_real_t | vals[] | ||
| void cs_thermal_table_finalize | ( | void | ) |
| void cs_thermal_table_set | ( | const char * | material, |
| const char * | method, | ||
| const char * | reference, | ||
| cs_phys_prop_thermo_plane_type_t | thermo_plane, | ||
| int | temp_scale | ||
