7.2
cs_paramedmem_remapper.cxx File Reference
#include <stdarg.h>
#include <mpi.h>
#include "cs_mesh_connect.h"
#include "cs_prototypes.h"
#include "cs_selector.h"
#include "cs_timer.h"
#include "fvm_defs.h"
#include "fvm_nodal_from_desc.h"
#include "cs_medcoupling_mesh.hxx"
#include "cs_paramedmem_remapper.h"
#include <MEDLoader.hxx>
#include <MEDCoupling_version.h>
#include <MEDFileField.hxx>
#include <MEDFileFieldMultiTS.hxx>
#include <MEDFileMesh.hxx>
#include <MEDCouplingUMesh.hxx>
#include <MEDCouplingField.hxx>
#include <MEDCouplingFieldDouble.hxx>
#include <ParaFIELD.hxx>
#include <ParaMESH.hxx>
#include <OverlapDEC.hxx>
#include <ParaMEDFileMesh.hxx>
+ Include dependency graph for cs_paramedmem_remapper.cxx:
static _mesh_transformation_t * _cs_paramedmem_create_transformation (int type, const cs_real_t center[3], const cs_real_t vector[3], const cs_real_t angle)
 Create a mesh transformation (rotation or translation) More...
static void _cs_paramedmem_reset_transformations (void)
 Reset all mesh transformations. More...
static void _cs_paramedmem_apply_transformations (MEDCouplingFieldDouble *field, cs_paramedmem_remapper_t *r)
 Apply the different mesh transformations and update the bounding sphere. More...
static int * _cs_paramedmem_get_mpi_comm_world_ranks (void)
 Returns an array containing the ranks of code_saturne processes in MPI_COMM_WORLD. More...
static cs_paramedmem_remapper_t * _cs_paramedmem_overlap_create (const char *name)
 Create the parallel remapper structure based on ParaMEDMEM OverlapDEC. More...
static void _cs_paramedmem_remapper_target_mesh (cs_paramedmem_remapper_t *r, const char *name, const char *select_criteria)
 Set the target mesh for interpolation. More...
static void _cs_paramedmem_load_paramesh (cs_paramedmem_remapper_t *r, char *file_name, char *mesh_name)
 Load the mesh parts on each process. More...
static void _cs_paramedmem_remapper_destroy (cs_paramedmem_remapper_t *r)
 Destroy a remapper. More...
cs_paramedmem_remapper_t * cs_paramedmem_remapper_create (char *name, const char *sel_criteria, char *file_name, char *mesh_name, cs_real_t center[3], cs_real_t radius)
 Creates a new cs_paramedmem_remapper_t instance. More...
cs_paramedmem_remapper_t * cs_paramedmem_remapper_by_name_try (const char *name)
 get a remapper by its name More...
cs_real_tcs_paramedmem_remap_field_one_time (cs_paramedmem_remapper_t *r, char *field_name, cs_real_t default_val, int dt, int it)
 Remaps a field from the med file to the local mesh for a given time. More...
cs_real_tcs_paramedmem_remap_field (cs_paramedmem_remapper_t *r, char *field_name, cs_real_t default_val, int time_choice, double tval)
 Interpolate a given field on the local mesh for a given time. More...
void cs_paramedmem_remapper_translate (cs_paramedmem_remapper_t *r, cs_real_t translation[3])
 translate the mesh using a given vector More...
void cs_paramedmem_remapper_rotate (cs_paramedmem_remapper_t *r, cs_real_t invariant[3], cs_real_t axis[3], cs_real_t angle)
 Rotate the mesh using a center point, axis and angle. More...
void cs_paramedmem_remapper_destroy_all (void)
 Destroy all remappers. More...
static int _n_remappers = 0
static cs_paramedmem_remapper_t ** _remapper = NULL
static int _n_transformations = 0
static _mesh_transformation_t ** _transformations = NULL
static bool _transformations_applied = false
◆ _cs_paramedmem_apply_transformations()
static void _cs_paramedmem_apply_transformations ( MEDCouplingFieldDouble *  field,
cs_paramedmem_remapper_t *  r
static
◆ _cs_paramedmem_create_transformation()
static _mesh_transformation_t* _cs_paramedmem_create_transformation ( int  type,
static
a mesh_transformation pointer
◆ _cs_paramedmem_get_mpi_comm_world_ranks()
static int* _cs_paramedmem_get_mpi_comm_world_ranks ( void  )
static
array of ranks in MPI_COMM_WORLD
◆ _cs_paramedmem_load_paramesh()
static void _cs_paramedmem_load_paramesh ( cs_paramedmem_remapper_t *  r,
char *  file_name,
char *  mesh_name
static
[in]rpointer to cs_paramedmem_remapper_t struct
[in]file_namename of med file containing the data
[in]mesh_namename of the mesh to read in the med file
◆ _cs_paramedmem_overlap_create()
static cs_paramedmem_remapper_t* _cs_paramedmem_overlap_create ( const char *  name)
static
[in]namename of the remapper
◆ _cs_paramedmem_remapper_destroy()
static void _cs_paramedmem_remapper_destroy ( cs_paramedmem_remapper_t *  r)
static
Destroy a remapper.
[in]rremapper to destroy
◆ _cs_paramedmem_remapper_target_mesh()
static void _cs_paramedmem_remapper_target_mesh ( cs_paramedmem_remapper_t *  r,
const char *  name,
const char *  select_criteria
static
[in]namemesh name
[in]select_criteriaselection criteria for needed cells
◆ _cs_paramedmem_reset_transformations()
static void _cs_paramedmem_reset_transformations ( void  )
static
◆ cs_paramedmem_remap_field()
cs_real_t* cs_paramedmem_remap_field ( cs_paramedmem_remapper_t *  r,
char *  field_name,
int  time_choice,
double  tval
[in]field_namename of the field to remap from the file
[in]default_valdefault value for unmapped elements
[in]time_choiceChoice of the time interpolation. 0: Value of field interpolated at t=tval from the med file. 1: Returns field values for the first time step in the file. tval is then ignored. 2: Returns field values for the last time step in the file. tval is then ignored.
[in]tvalrequested time instant. If time choice is 0 and tval outside of the file time bounds, return value will be at the the first time step (if tval < tmin) or last time step (if tval > tmax)
cs_real_t pointer containing the new values on target mesh
◆ cs_paramedmem_remap_field_one_time()
cs_real_t* cs_paramedmem_remap_field_one_time ( cs_paramedmem_remapper_t *  r,
char *  field_name,
int  dt,
int  it
[in]dttime value to use from the file
[in]ittime iteration to use from the file
◆ cs_paramedmem_remapper_by_name_try()
cs_paramedmem_remapper_t* cs_paramedmem_remapper_by_name_try ( const char *  name)
◆ cs_paramedmem_remapper_create()
cs_paramedmem_remapper_t* cs_paramedmem_remapper_create ( char *  name,
const char *  sel_criteria,
char *  file_name,
char *  mesh_name,
cs_real_t  radius
[in]sel_criteriacells selection criteria
[in]file_namemed file name
[in]mesh_namename of the mesh in the med file
[in]centercenter of bounding sphere
[in]radiusradius of bounding sphere
◆ cs_paramedmem_remapper_destroy_all()
void cs_paramedmem_remapper_destroy_all ( void  )
◆ cs_paramedmem_remapper_rotate()
void cs_paramedmem_remapper_rotate ( cs_paramedmem_remapper_t *  r,
cs_real_t  axis[3],
cs_real_t  angle
[in]rpointer to the cs_paramedmem_remapper_t struct
[in]invariantcoordinates of the invariant point
[in]axisrotation axis vector
[in]anglerotation angle in radians
◆ cs_paramedmem_remapper_translate()
void cs_paramedmem_remapper_translate ( cs_paramedmem_remapper_t *  r,
[in]translationtranslation vector
◆ _n_remappers
static
◆ _n_transformations
static
◆ _remapper
cs_paramedmem_remapper_t** _remapper = NULL
static
◆ _transformations
_mesh_transformation_t** _transformations = NULL
static
◆ _transformations_applied
static
