7.2
fvm_nodal_from_desc.h
1 #ifndef __FVM_NODAL_FROM_DESC_H__
2 #define __FVM_NODAL_FROM_DESC_H__
5  * Initialization of a nodal connectivity definition based upon
6  * a (possibly partial) descending connectivity
8
9 /*
10  This file is part of code_saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2022 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 #include "cs_defs.h"
32
33 /*----------------------------------------------------------------------------
34  * Local headers
35  *----------------------------------------------------------------------------*/
36
37 #include "fvm_defs.h"
38 #include "fvm_nodal.h"
45  * Public function prototypes
48 /*----------------------------------------------------------------------------
49  * Convert and add cells from an descending connectivity mesh to a nodal mesh.
50  *
51  * An optional parent_cell_num[] array may also be given, in
52  * case the descending connectivity mesh definition is based on a temporary
53  * subset of a parent mesh, (corresponding to the parent_cell_num[] list,
54  * using 1 to n numbering), and the final nodal mesh element parent numbering
55  * should correspond to that parent mesh and not the temporary subset.
56  *
57  * parameters:
58  * this_nodal <-> nodal mesh structure
59  * n_extr_cells <-- count of cells to add
60  * n_face_lists <-- number of face lists
61  * face_list_shift <-- face list to common number index shifts;
62  * size: n_face_lists
63  * face_vertex_idx <-- face -> vertex indexes (per face list)
64  * face_vertex <-- face -> vertex ids (per face list)
65  * cell_face_idx <-- cell -> face indexes (1 to n)
66  * cell_face_num <-- cell -> face numbers (1 to n)
67  * cell_gc_id <-- cell -> group class ids, or NULL
68  * parent_cell_num <-- cell -> parent cell number (1 to n) if non-trivial
69  * (i.e. if cell definitions correspond to a subset
70  * of the parent mesh), NULL otherwise.
71  * cell_face_list --> numbers of faces defining polyhedra
72  *----------------------------------------------------------------------------*/
73
74 void
75 fvm_nodal_from_desc_add_cells(fvm_nodal_t *this_nodal,
76  const cs_lnum_t n_extr_cells,
77  const int n_face_lists,
78  const cs_lnum_t face_list_shift[],
79  const cs_lnum_t *face_vertex_idx[],
80  const cs_lnum_t *face_vertex_num[],
81  const cs_lnum_t cell_face_idx[],
82  const cs_lnum_t cell_face_num[],
83  const int cell_gc_id[],
84  const cs_lnum_t parent_cell_num[],
85  cs_lnum_t *cell_face_list[]);
86
87 /*----------------------------------------------------------------------------
88  * Convert and add faces from an descending connectivity mesh to a nodal mesh.
89  *
90  * If the optional filter list extr_faces[] argument is non-NULL, faces
91  * {extr_faces[0], extr_faces[1], extr_faces[n_extr_faces - 1]} are converted
92  * and added to the nodal mesh. If this filter is set to NULL, faces
93  * {1, 2, ..., n_extr_faces} are considered.
94  *
95  * In addition, an optional parent_face_num[] array may also be given, in
96  * case the descending connectivity mesh definition is based on a temporary
97  * subset of a parent mesh, (corresponding to the parent_face_num[] list,
98  * using 1 to n numbering), and the final nodal mesh element parent numbering
99  * should correspond to that parent mesh and not the temporary subset.
100  *
101  * parameters:
102  * this_nodal <-> nodal mesh structure
103  * boundary_flag <-- -1 if unspecified, 0 if faces are not on boundary,
104  * 1 if faces are on boundary
105  * n_extr_faces <-- count of faces to add
106  * extr_faces <-- optional filter list of faces to extract (1 to n)
107  * n_face_lists <-- number of face lists
108  * face_list_shift <-- face list to common number index shifts;
109  * size: n_face_lists
110  * face_vertex_idx <-- face -> vertex indexes (per face list)
111  * face_vertex <-- face -> vertex ids (per face list)
112  * face_gc_id <-- face -> group class ids, or NULL (per face list)
113  * parent_face_num <-- face -> parent face number (1 to n) if non-trivial
114  * (i.e. if face definitions correspond to a subset
115  * of the parent mesh), NULL otherwise.
116  *----------------------------------------------------------------------------*/
117
118 void
119 fvm_nodal_from_desc_add_faces(fvm_nodal_t *this_nodal,
120  int boundary_flag,
121  const cs_lnum_t n_extr_faces,
122  const cs_lnum_t extr_faces[],
123  const int n_face_lists,
124  const cs_lnum_t face_list_shift[],
125  const cs_lnum_t *face_vertex_idx[],
126  const cs_lnum_t *face_vertex_num[],
127  const int *face_gc_id[],
128  const cs_lnum_t parent_face_num[]);
129
130 /*----------------------------------------------------------------------------
131  * Determination of a given cell's type.
132  *
133  * If the optional cell_vtx[8] array is given, it is filled with the vertex
134  * indexes of cell's vertices, unless the cell is a general polyhedron.
135  *
136  * parameters:
137  * cell_id <-- cell id (0 to n-1)
138  * n_face_lists <-- number of face lists
139  * face_list_shift <-- face list to common number index shifts;
140  * size: n_face_lists
141  * face_vertex_idx <-- face -> vertex indexes (per face list)
142  * face_vertex <-- face -> vertex ids (per face list)
143  * cell_face_idx <-- cell -> face indexes (1 to n)
144  * cell_face_num <-- cell -> face numbers (1 to n)
145  * vertex_num --> nodal connectivity of cell, if not a general
146  * polyhedron
147  *
148  * returns:
149  * type of cell defined by cell_id
150  *----------------------------------------------------------------------------*/
151
153 fvm_nodal_from_desc_cell(const cs_lnum_t cell_id,
154  const int n_face_lists,
155  const cs_lnum_t face_list_shift[],
156  const cs_lnum_t *face_vertex_idx[],
157  const cs_lnum_t *face_vertex_num[],
158  const cs_lnum_t cell_face_idx[],
159  const cs_lnum_t cell_face_num[],
160  cs_lnum_t vertex_num[8]);
161
162 /*----------------------------------------------------------------------------*/
163
165
166 #endif /* __FVM_NODAL_FROM_DESC_H__ */
void fvm_nodal_from_desc_add_faces(fvm_nodal_t *this_nodal, int boundary_flag, const cs_lnum_t n_extr_faces, const cs_lnum_t extr_faces[], const int n_face_lists, const cs_lnum_t face_list_shift[], const cs_lnum_t *face_vertex_idx[], const cs_lnum_t *face_vertex_num[], const int *face_gc_id[], const cs_lnum_t parent_face_num[])
Definition: fvm_nodal_from_desc.c:1537
fvm_element_t
Definition: fvm_defs.h:48
void fvm_nodal_from_desc_add_cells(fvm_nodal_t *this_nodal, const cs_lnum_t n_extr_cells, const int n_face_lists, const cs_lnum_t face_list_shift[], const cs_lnum_t *face_vertex_idx[], const cs_lnum_t *face_vertex_num[], const cs_lnum_t cell_face_idx[], const cs_lnum_t cell_face_num[], const int cell_gc_id[], const cs_lnum_t parent_cell_num[], cs_lnum_t *cell_face_list[])
Definition: fvm_nodal_from_desc.c:1275
Definition: cs_defs.h:316
fvm_element_t fvm_nodal_from_desc_cell(const cs_lnum_t cell_id, const int n_face_lists, const cs_lnum_t face_list_shift[], const cs_lnum_t *face_vertex_idx[], const cs_lnum_t *face_vertex_num[], const cs_lnum_t cell_face_idx[], const cs_lnum_t cell_face_num[], cs_lnum_t vertex_num[8])
Definition: fvm_nodal_from_desc.c:1786
