#include "cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "cs_log.h"#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_field.h"#include "cs_parall.h"#include "cs_physical_model.h"#include "cs_post.h"#include "cs_gas_mix.h"
Include dependency graph for cs_gas_mix.c:Functions | |
| int | cs_gas_mix_get_field_key (void) |
| Get the field key for gas mix properties. More... | |
| void | cs_gas_mix_add_species (int f_id) |
| Add a species field to the gas mix (set of fields). More... | |
| void | cs_gas_mix_add_species_with_properties (int f_id, cs_real_t mol_mass, cs_real_t cp, cs_real_t vol_diff, cs_real_t mu_a, cs_real_t mu_b, cs_real_t lambda_a, cs_real_t lambda_b, cs_real_t mu_ref, cs_real_t lambda_ref, cs_real_t tref_mu, cs_real_t tref_lambda, cs_real_t s_mu, cs_real_t s_lambda) |
| void | cs_gas_mix_add_property_fields (void) |
| Add property fields specific to a gas mix. More... | |
| void | cs_gas_mix_finalize (void) |
| Free array mapping gas mix species ids to field ids. More... | |
| static cs_gas_mix_species_prop_t | _gas_mix_species_prop |
| const cs_gas_mix_t * | cs_glob_gas_mix = &_gas_mix |
Base gas mix data.
| void cs_gas_mix_add_property_fields | ( | void | ) |
| void cs_gas_mix_add_species | ( | int | f_id | ) |
| [in] | f_id | field id of an already created scalar model field |
| void cs_gas_mix_add_species_with_properties | ( | int | f_id, |
| cs_real_t | mol_mass, | ||
| cs_real_t | cp, | ||
| cs_real_t | vol_diff, | ||
| cs_real_t | mu_a, | ||
| cs_real_t | mu_b, | ||
| cs_real_t | lambda_a, | ||
| cs_real_t | lambda_b, | ||
| cs_real_t | mu_ref, | ||
| cs_real_t | lambda_ref, | ||
| cs_real_t | tref_mu, | ||
| cs_real_t | tref_lambda, | ||
| cs_real_t | s_mu, | ||
| cs_real_t | s_lambda | ||
| [in] | f_id | id of field representing species mixture fraction. |
| [in] | mol_mass | molar mass |
| [in] | cp | specific heat |
| [in] | col_diff | volume diffusion |
| [in] | mu_a | dynamic viscosity a |
| [in] | mu_b | dynamic viscosity b |
| [in] | lambda_a | thermal conductivity a |
| [in] | lambda_b | thermal conductivity b |
| [in] | mu_ref | reference viscosity (Sutherland) |
| [in] | lambda_ref | reference conductivity (Sutherland) |
| [in] | tref_mu | reference temperature for viscosity |
| [in] | tref_lambda | reference temperature for conductivity |
| [in] | s_mu | Sutherland temperature for viscosity |
| [in] | s_lambda | Sutherland temperature for conductivity |
| void cs_gas_mix_finalize | ( | void | ) |
| int cs_gas_mix_get_field_key | ( | void | ) |
static |
| const cs_gas_mix_t* cs_glob_gas_mix = &_gas_mix |
