7.2
cs_gas_mix.h
1 #ifndef __CS_GAS_MIX_H__
2 #define __CS_GAS_MIX_H__
5  * Base gas mix data.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
48 /* Gas mix types
49  ------------- */
50
51 typedef enum {
52
63
64 /* Gas mix descriptor
65  ------------------ */
66
67 typedef struct {
68
69  int n_species;
75 } cs_gas_mix_t;
76
77 /*
78  * Gas mix modelling physical properties
79  * ------------------------------------- */
80
81 typedef struct {
82
83  double mol_mas; /* molar mass */
84  double cp; /* specific heat at constant pressure */
85  double vol_dif; /* volume diffusion */
86  double mu_a; /* dynamic viscosity a */
87  double mu_b; /* dynamic viscosity a */
88  double lambda_a; /* thermal conductivity a */
89  double lambda_b; /* thermal conductivity b */
90  double muref; /* ref. viscosity for Sutherland law */
91  double lamref; /* ref. thermal conductivity for Sutherland law */
92  double trefmu; /* ref. temperature for viscosity in Sutherland law */
93  double treflam; /* ref. temperature for conductivity Sutherland law */
94  double smu; /* Sutherland temperature for viscosity */
95  double slam; /* Sutherland temperature for conductivity */
96
98
99 /*============================================================================
100  * Static global variables
101  *============================================================================*/
102
103 /* Pointer to main physical constants structure */
104
105 extern const cs_gas_mix_t *cs_glob_gas_mix;
106
107 /*=============================================================================
108  * Public function prototypes
109  *============================================================================*/
110
111 /*----------------------------------------------------------------------------*/
117 /*----------------------------------------------------------------------------*/
118
119 int
121
129
130 void
131 cs_gas_mix_add_species(int f_id);
132
133 /*----------------------------------------------------------------------------*/
152 /*----------------------------------------------------------------------------*/
153
154 void
157  cs_real_t cp,
158  cs_real_t vol_diff,
159  cs_real_t mu_a,
160  cs_real_t mu_b,
161  cs_real_t lambda_a,
162  cs_real_t lambda_b,
163  cs_real_t mu_ref,
164  cs_real_t lambda_ref,
165  cs_real_t tref_mu,
166  cs_real_t tref_lambda,
167  cs_real_t s_mu,
168  cs_real_t s_lambda);
169
170 /*----------------------------------------------------------------------------*/
174 /*----------------------------------------------------------------------------*/
175
176 void
178
179 /*----------------------------------------------------------------------------*/
183 /*----------------------------------------------------------------------------*/
184
185 void
186 cs_gas_mix_finalize(void);
187
188 /*----------------------------------------------------------------------------*/
189
191
192 #endif /* __CS_GAS_MIX_H__ */
void cs_gas_mix_finalize(void)
Free array mapping gas mix species ids to field ids.
Definition: cs_gas_mix.c:675
double mol_mas
Definition: cs_gas_mix.h:83
double slam
Definition: cs_gas_mix.h:95
double lambda_a
Definition: cs_gas_mix.h:88
double smu
Definition: cs_gas_mix.h:94
double lambda_b
Definition: cs_gas_mix.h:89
int * species_to_field_id
Definition: cs_gas_mix.h:72
Definition: cs_gas_mix.h:53
double trefmu
Definition: cs_gas_mix.h:92
Definition: cs_field_pointer.h:100
double cp
Definition: cs_gas_mix.h:84
Definition: cs_defs.h:322
cs_gas_mix_type_t
Definition: cs_gas_mix.h:51
Definition: cs_gas_mix.h:56
Definition: cs_gas_mix.h:81
int cs_gas_mix_get_field_key(void)
Get the field key for gas mix properties.
Definition: cs_gas_mix.c:432
Definition: cs_gas_mix.h:55
void cs_gas_mix_add_property_fields(void)
Add property fields specific to a gas mix.
Definition: cs_gas_mix.c:565
const cs_gas_mix_t * cs_glob_gas_mix
Definition: cs_gas_mix.c:139
Definition: cs_gas_mix.h:58
double vol_dif
Definition: cs_gas_mix.h:85
Definition: cs_field_pointer.h:194
double mu_a
Definition: cs_gas_mix.h:86
void cs_gas_mix_add_species_with_properties(int f_id, cs_real_t mol_mass, cs_real_t cp, cs_real_t vol_diff, cs_real_t mu_a, cs_real_t mu_b, cs_real_t lambda_a, cs_real_t lambda_b, cs_real_t mu_ref, cs_real_t lambda_ref, cs_real_t tref_mu, cs_real_t tref_lambda, cs_real_t s_mu, cs_real_t s_lambda)
Add a species field to the gas mix (set of fields).
Definition: cs_gas_mix.c:512
Definition: cs_gas_mix.h:60
Definition: cs_gas_mix.h:57
Definition: cs_gas_mix.h:59
int n_species_solved
Definition: cs_gas_mix.h:70
Definition: cs_gas_mix.h:54
void cs_gas_mix_add_species(int f_id)
Definition: cs_gas_mix.c:467
double lamref
Definition: cs_gas_mix.h:91
double muref
Definition: cs_gas_mix.h:90
double treflam
Definition: cs_gas_mix.h:93
Gas mix descriptor.
Definition: cs_gas_mix.h:67
double mu_b
Definition: cs_gas_mix.h:87
int n_species
Definition: cs_gas_mix.h:69
