7.2
cs_equation_system.h
1 #ifndef __CS_EQUATION_SYSTEM_H__
2 #define __CS_EQUATION_SYSTEM_H__
5  * Functions to handle a set of coupled equations hinging on the cs_equation_t
6  * structure
8
9 /*
10  This file is part of code_saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2022 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
29 /*----------------------------------------------------------------------------
30  * Local headers
31  *----------------------------------------------------------------------------*/
32
33 #include "cs_equation.h"
34 #include "cs_equation_priv.h"
36 #include "cs_param_types.h"
43  * Macro definitions
45
47  * Type definitions
49
50 /*----------------------------------------------------------------------------*/
67
68 typedef void *
70  const cs_equation_system_param_t *sysp,
71  cs_equation_core_t **core_array,
72  cs_cdo_system_helper_t **p_sh);
73
91
92 typedef void *
94  cs_equation_core_t **core_array,
95  void *sys_context);
96
108 /*----------------------------------------------------------------------------*/
109
110 typedef void
112  int n_eqs,
114  cs_equation_core_t **blocks,
115  void *sys_context,
117
118
123 typedef struct {
124
135
137  int timer_id;
153
154  void *context;
155
172
198
223
226
232
233 /*============================================================================
234  * Public function prototypes
235  *============================================================================*/
236
237 /*----------------------------------------------------------------------------*/
243 /*----------------------------------------------------------------------------*/
244
245 int
247
248 /*----------------------------------------------------------------------------*/
258 /*----------------------------------------------------------------------------*/
259
261 cs_equation_system_add(const char *sysname,
262  int n_eqs,
263  int block_var_dim);
264
265 /*----------------------------------------------------------------------------*/
269 /*----------------------------------------------------------------------------*/
270
271 void
273
274 /*----------------------------------------------------------------------------*/
278 /*----------------------------------------------------------------------------*/
279
280 void
282
283 /*----------------------------------------------------------------------------*/
288 /*----------------------------------------------------------------------------*/
289
290 void
292
293 /*----------------------------------------------------------------------------*/
302 /*----------------------------------------------------------------------------*/
303
304 void
306  const cs_cdo_connect_t *connect,
307  const cs_cdo_quantities_t *quant,
308  const cs_time_step_t *time_step);
309
310 /*----------------------------------------------------------------------------*/
315 /*----------------------------------------------------------------------------*/
316
317 void
319
320 /*----------------------------------------------------------------------------*/
324 /*----------------------------------------------------------------------------*/
325
326 void
328
329 /*----------------------------------------------------------------------------*/
337 /*----------------------------------------------------------------------------*/
338
339 void
341
342 /*----------------------------------------------------------------------------*/
349 /*----------------------------------------------------------------------------*/
350
351 void
352 cs_equation_system_solve(bool cur2prev,
353  cs_equation_system_t *eqsys);
354
355 /*----------------------------------------------------------------------------*/
364 /*----------------------------------------------------------------------------*/
365
366 void
368  cs_equation_t *eq,
369  cs_equation_system_t *eqsys);
370
371 /*----------------------------------------------------------------------------*/
381 /*----------------------------------------------------------------------------*/
382
383 void
385  int col_id,
386  cs_equation_param_t *eqp,
387  cs_equation_system_t *eqsys);
388
389 /*----------------------------------------------------------------------------*/
390
392
393 #endif /* __CS_EQUATION_SYSTEM_H__ */
time step descriptor
Definition: cs_time_step.h:64
void cs_equation_system_define(void)
Define the builder and scheme context structures associated to all the systems of equations which hav...
Definition: cs_equation_system.c:610
void cs_equation_system_destroy_all(void)
Destroy all cs_equation_system_t structures.
Definition: cs_equation_system.c:312
cs_equation_system_t * cs_equation_system_add(const char *sysname, int n_eqs, int block_var_dim)
Add a new structure to handle system of coupled equations.
Definition: cs_equation_system.c:281
void * context
Definition: cs_equation_system.h:154
void cs_equation_system_set_functions(void)
Assign a set of pointer functions for managing all the systems of equations.
Definition: cs_equation_system.c:507
cs_cdo_system_helper_t * system_helper
Definition: cs_equation_system.h:152
Definition: cs_cdo_system.h:368
void cs_equation_system_set_sles(void)
Set the SLES associated to each system of equations.
Definition: cs_equation_system.c:571
Definition: cs_cdo_quantities.h:132
cs_timer_counter_t timer
Definition: cs_equation_system.h:136
Definition: cs_mesh.h:84
void cs_equation_system_solve(bool cur2prev, cs_equation_system_t *eqsys)
Solve of a system of coupled equations. Unsteady case.
Definition: cs_equation_system.c:666
cs_equation_core_t ** block_factories
Definition: cs_equation_system.h:197
void *() cs_equation_system_free_t(int n_eqs, cs_equation_core_t **core_array, void *sys_context)
Free an array of structures (equation parameters, equation builders or scheme context) for each equat...
Definition: cs_equation_system.h:93
void *() cs_equation_system_define_t(int n_eqs, const cs_equation_system_param_t *sysp, cs_equation_core_t **core_array, cs_cdo_system_helper_t **p_sh)
Create and initialize equation builders and scheme context for each equation which are in the extra-d...
Definition: cs_equation_system.h:69
Main structure storing the parameter settings.
Definition: cs_equation_system_param.h:71
Main structures composiing an equation structure.
Definition: cs_equation.h:82
void cs_equation_system_assign_equation(int row_id, cs_equation_t *eq, cs_equation_system_t *eqsys)
Assign the given equation to the diagonal block located at position (row_id, row_id) in the matrix of...
Definition: cs_equation_system.c:709
int n_equations
Definition: cs_equation_system.h:170
cs_equation_system_solve_t * solve_steady_state_system
Definition: cs_equation_system.h:225
Main structure to handle a set of coupled equations.
Definition: cs_equation_system.h:123
cs_equation_system_free_t * free
Definition: cs_equation_system.h:222
int timer_id
Definition: cs_equation_system.h:137
void cs_equation_system_log_setup(void)
Log the setup for all structures managing systems of equations.
Definition: cs_equation_system.c:329
void cs_equation_system_init_sharing(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Assign a set of shared pointer to the main structures.
Definition: cs_equation_system.c:440
cs_equation_system_define_t * define
Definition: cs_equation_system.h:221
void cs_equation_system_assign_param(int row_id, int col_id, cs_equation_param_t *eqp, cs_equation_system_t *eqsys)
Assign the given equation parameters to the block with ids (row_id, col_id) in the block matrix...
Definition: cs_equation_system.c:756
void() cs_equation_system_solve_t(bool c2p, int n_eqs, cs_equation_system_param_t *sysp, cs_equation_core_t **blocks, void *sys_context, cs_cdo_system_helper_t *sh)
Build and solve a linear system within the CDO framework.
Definition: cs_equation_system.h:111
cs_equation_system_param_t * param
Definition: cs_equation_system.h:134
cs_equation_system_solve_t * solve_system
Definition: cs_equation_system.h:224
cs_equation_t ** equations
Definition: cs_equation_system.h:171
void cs_equation_system_log_monitoring(void)
Print a synthesis of the monitoring information in the performance file.
Definition: cs_equation_system.c:408
Definition: mesh.f90:26
int cs_equation_system_get_n_systems(void)
Get the number of systems of equations.
Definition: cs_equation_system.c:263
Definition: cs_timer.h:55
